Old 08-06-2009, 03:06 AM   #5386
kest's Avatar
Trader Rating: 1 (67%+)
Thanx 4 the info mate..really appreciate it.
K..Y..O..S..H..O..I..S..H..O..B..B..Y
JBRCC
BCRT
kest is offline   Reply With Quote
Old 08-06-2009, 07:22 AM   #5387
NiMo's Avatar
Originally Posted by Kyo83 View Post
Any of you Kyosho FW-05R or RR owners find a need to upgrade to the 4mm chassis or is the orginal 3mm chassis sturdy enough for racing?
If racing with Foams then use 4mm, unless you race on a low grip surface then use 3mm.
If racing with Rubber then only 3mm chassis and soft springs.
NiMo is offline   Reply With Quote
Old 08-16-2009, 07:51 AM   #5388
Default Upgrades
Hey guys,
So the storey is that I have taken the plunge to purchase a OS .12 TZ and purchased a bunch of parts also and realised some of the parts I purchased was for the FW-06 and was told by the seller that they wont fit?
3 Racing Graphite Radio Tray For Kyosho FW06
3 Racing Servo Mount For FW06
3 Racing Aluminum Main Chassis For Kyosho FW05R
3 Racing Aluminum One Way Hub For FW05R
Can anyone here confirm this is true?
Cheers,
Pete
psykosonik is offline   Reply With Quote
Old 08-18-2009, 08:56 AM   #5389
Originally Posted by psykosonik View Post
Hey guys,
Cheers,
Pete
Can you give me the part numbers...I bought the radio tray and chassis from 3Racign and used them on my FW05 RR with no problem. From just eyeballing Pictures...the servo mounts look the same as well...just blue.
Kyo83 is offline   Reply With Quote
Old 08-18-2009, 05:46 PM   #5390
Thanks Kyo83,
The carbon upper chassis part number is FW06-11 and the servo mounts are FW06-15.
I have been told directly from 3-racing that the part would not suit the fw-05t but on rcmart a user left a comment that he purchased the same part for his fw-05t and suprisingly fitted.
I have eyeballed both parts from 3-racing and the only differeance is the additional battery/reciever plate.
Cheers,
Pete
Old 08-19-2009, 11:05 AM   #5391
Thanks Kyo83,
Cheers,
Pete
Look again the the carbon radio tray for the FW05 has extending arms on the front.
You need to get this: FW05-RR004 or FW05-RR004A
or this
again, the server mounts look the same except for color but if you want to be sure get these:FW05-023 and FW05-023A
Old 08-19-2009, 12:26 PM   #5392
NiMo's Avatar
or this
Those radio trays are for the FW05RR model, the R model is the same except for the front extended arms
Old 08-19-2009, 12:55 PM   #5393
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
NiMo is on top of this car... he ran it for a looong time with great success.
psykosonik,
I know you asked what the differences are in a couple places... but I'll answer here because of the pics of the radio tray.
Here goes... I'll try to give you the major things... off the top of my head.
05S to 05T, engine change (now slide carb) 2speed, and brake hub.
05T to 05T+, rear suspension (same as 05RR minus CF parts)
05T+ to 06, front shock tower, radio tray, fuel tank.
looks like to convert a T+ to an 06 you need
VS111 front shock tower
VS112 radio tray with servo mounts
VS113 fuel tank
mis hardware
I don't think you can change the tank without the radio tray
The radio tray pictured is for an RR and requires other parts... VS037 (I think...maybe more)
The radio trays between all the others should swap out.
Ed Anderson is offline   Reply With Quote
Old 08-19-2009, 01:00 PM   #5394
Thanks for the insight...I thought the main different between the the FW05 R and RR was the rear setup.....learned something new today.
Old 08-19-2009, 01:29 PM   #5395
NiMo's Avatar
RR had extra fixing points at the front to stiffen it for Foam use, I actually chopped them off again as it made me slower, and made taking the radio tray off a much bigger job as you had to separate the front diff housing each time.
Best way to strengthen front was to run longer bolts through the bottom of the diff centre shaft output and then use nuts to secure deck.
(make sure bolts do not touch steering rack)
Samer trick could also be done at rear.
I may rebuild my FW05 one of these days, and fit the 4-stroke conversion i have for it.
Still the best IC car I ever had, just a shame the National series went to Foam, as the FW05 worked better than the belt cars on Rubber.
Old 08-19-2009, 10:18 PM   #5396
Thanks Guys,
Your help has made my day!
I will change the subject on the other thread with progress of the conversion.
I'll wait till the parts I have orderd to arrive, then look at the other parts Kyo83 mentioned.
NiMo - what is the 4-stroke conversion? I tried to google it.
Old 08-20-2009, 06:00 AM   #5397
Four stroke kit is PN# VSW-023
Old 08-20-2009, 07:50 AM   #5398
NiMo's Avatar
Thanks Guys,
The project that got put on hold, cos my local club refused to allow any motor over a .12 race or .18 pull start.
Old 08-23-2009, 05:56 PM   #5399
Thats is really cool - I would like to see how that thing runs!
p.s All 3 racing parts fit perfectly!
Check out thread http://www.rctech.net/forum/nitro-ro...ml#post6245394 for pictures. (will be posting tonight)
Old 08-24-2009, 01:09 AM   #5400
NiMo's Avatar
My FW05R before Foam Tyres and High Cost took over.
This was before 2.4Ghz was thought of and used in RC racing
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
