Old 11-27-2005, 11:07 PM   #5251
Im2lazy's Avatar
Personally, the RR conversion is worth it. For 60-80$ US you make the steering a good deal more confident and consistent with the high-speed steering improved and more precise. Rear camber-gain adjustment is a great adjustable point that subtly changes the rear grip. A bit more work concerning the upper deck now connected to the front upper suspension making some small tasks more of a bitch, but overall better.
Im2lazy is offline   Reply With Quote
Old 11-29-2005, 01:18 PM   #5252
Default rr
absolutely worth the effort for the conversion. definately steers better and is a lot more predictable
nugz is offline   Reply With Quote
Old 11-29-2005, 04:12 PM   #5253
Default Winternats
Hello Guys,
Just Chiming in from down here in PR.... Planning on visiting Florida for the WinterNats... I'll be heading down w/ my friend Geloman (also running FW05RR) and was wondering who would be down there and if anyone has any set-up tips for the track.
Looking forward to seeing some of the Fw05 crew down there.
Havy
havy is offline   Reply With Quote
Old 12-04-2005, 04:27 PM   #5254
Cool
Pretty funny, ...never mind, I can hold my own, I'm no pro, but looking forward to learning from the pros
havy
Old 12-05-2005, 07:49 AM   #5255
NiMo's Avatar
havy
Site has gone quiet hasn't it.
I wont be there as I do not currently have the funds to travel, it would possibly cost me around $5000 to get me and my stuff to the event, and that is only if I could get the time off from work.
I have just installed the Spektrum set up in to my car, and I don't quiet know how to explain this but I am sure the throttle and steering action feels smoother, also not a single glitch from the glowstart or a screw driver (used to be real cronick (badder than bad))
NiMo is offline   Reply With Quote
Old 12-05-2005, 03:42 PM   #5256
Yeah this thread seams to have gone quiet, I wish the that meant the parts wouldn't go out of stock so fast!
I have the spektrum mounted as well, really saves alot of hassle w/ the frequencies also.
I got lucky enough to have the boss give me the week off, and had some spare doe for the trip... but it's not cheap for me either. I'll get some video for ya.
Thanks though Nimo.
havy
Old 12-13-2005, 06:06 AM   #5257
hardrider's Avatar
Trader Rating: 39 (100%+)
Just picked up a used FW05R(rubber tyre version).
Planning to get the FW05RR conversion kit for it.
I've read from the Kyosho site that the conversion kit is for the FW05R(foam tyre version)
Looking at the online manuals, the foam and rubber tyre version have a different chasis Foam version chasis is same as the RR.
So, the million dollar question.... Will this conversion kit work with my rubber tyre version? Or will I have to pick up a RR chasis too?
Please advise so that I can order the right stuff or put my pennies aside for something else.
hardrider is offline   Reply With Quote
Old 12-13-2005, 07:36 AM   #5258
NiMo's Avatar
Conversion kit will fit all FW05 range, including the FW05T.
The Foam version uses the Shimo Chassis, but I used the blue FW05S chassis as it gave more chassis flex, I have just fitted the 3racing chassis.
Old 12-13-2005, 08:54 AM   #5259
hardrider's Avatar
Thanks Nimo. I will go ahead and order the conversion kit!
Old 12-13-2005, 09:08 AM   #5260
NiMo's Avatar
If you cannot get the Conversion kit, then at least get the RRR front hubs
They will give you so much more power on steering which is more noticable if you are running Rubber tyres.
The RRR rear hubs do not work so well with Rubber tyres but are needed if you run Foam.
It is also possible to fit the FW05RR front end and still use the R top deck (which I have now done), this gives the much needed chassis flex for running on slippery and wet tracks.
Old 12-13-2005, 04:07 PM   #5261
hardrider's Avatar
OK here's the strange bit... It's a FW05R rubber as stated in the instruction that came with the car. Plastic upper deck and all. But the car came with foam tyres. I assume the former owner fitted on the foam tyres without doing anything else.
An email to a LHS told me that they could order the conversion kit for me.
With all the aftermarket brands, it's pretty confusing what's hot and what's not. So I will stick with the Kyosho kit. Hope the LHS doesn't pull a "sold out" stunt on me.
Old 12-15-2005, 03:34 AM   #5262
Jez81's Avatar
Default Fw05R
If anyone interested in buying an FW05R - with full Kawahara conversion in immaculate condition check this: http://www.rctech.net/forum/showthread.php?t=93924
Jez81 is offline   Reply With Quote
Old 12-15-2005, 10:14 AM   #5263
impalabob64's Avatar
Send a message via AIM to impalabob64
Default havy
hey havy bobby i ran my fwo5 at last years winternats i used josh cyrul ohio setup with 37shore all 4 corners ,won the h-main could bumpup blew frt ringgear,oh an i used 39t ringgear with mugen clutchbell 22/29 50/45. i race with the rrr now. hope this will point you in the right direction.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 12-16-2005, 06:31 AM   #5264
4 stroke conversion kits. I'm gonna get one for sure. Check out the link, you will have to translate www.kyosho.co.jp/web/products/car_bike/ pureten_vone/common/4cycle/4cycle-j.html - 19k
zulu is offline   Reply With Quote
Old 12-16-2005, 07:34 PM   #5265
Cool, I'm planning on taking the car w/ 37t ringgear and playin w/ a 21-22/46-47 pinions. I heard it's not a fast long track but very technical. Thanks for the help.
havy
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
