Old 11-12-2005, 01:33 AM   #5236
NiMo's Avatar
Originally Posted by k617nu-b
Hi Guys,
Does anybody know where I can get parts for a conversion of my 05R to 05RR especially the front upper suspension arm holder without changing my carbon upper deck, ive seen something like it before here in RCTech but cant find the pics anymore...
Thanks,
K6
VS037
http://www.rcmart.com/catalog/produc...ducts_id=11438
NiMo is offline   Reply With Quote
Old 11-14-2005, 10:58 AM   #5237
NiMo's Avatar
heh heh heh what a laugh
put the new OS18TZ small block in my FW05 for testing last weekend, and boy does it fly.
Even with a 23/27 pinion gears and 37T diff rings I had ample acceleration and felt I could run a 28T 2nd gear, and that's on a 155ft main straight, best fun I've had in ages.
Only problem is that it sits 1mm higher so a little tricky to get the starter box to reach the flywheel so I had to enlarge the hole.
Old 11-17-2005, 05:04 AM   #5238
k617nu-b's Avatar
Hi guys,
Anybody knows where I can get this part, its the front upper suspension holder of the FW05RR but using the upper deck of the 05R...like a conversion part....
k617nu-b is offline   Reply With Quote
Old 11-17-2005, 06:55 AM   #5239
NiMo's Avatar
Hi guys,
That's the Kawahara option parts, You'll need to shop around for that now as it was out a few years back.
Old 11-17-2005, 07:07 PM   #5240
Trader Rating: 14 (100%+)
who sells this car online?
chrisw is offline   Reply With Quote
Old 11-18-2005, 01:27 AM   #5241
Im2lazy's Avatar
Hi guys,
Well, the RR conversion is cheaper and better to boot.
And any overseas online shop that deals with nitro will likely have the FW. If you live USA, Kyosho America doesn't bring over the FW kit opting instead to focus on the RRR kits. You can get FW parts though, just no kits.
Im2lazy is offline   Reply With Quote
Old 11-18-2005, 06:46 AM   #5242
Tim Johnson's Avatar
This has since changed. In January, Kyosho America will be releasing RR's with Option parts included.
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 11-19-2005, 02:53 AM   #5243
NiMo's Avatar
Now for my next fun project
Old 11-19-2005, 05:46 AM   #5244
Is it IFMAR legal? :
Post some pics. when its finish painted.
zulu is offline   Reply With Quote
Old 11-21-2005, 12:34 AM   #5245
Default shocks
Does anyone have the shock ratings for the fw-05rr. And a good place to buy them.
bandit528 is offline   Reply With Quote
Old 11-21-2005, 06:14 AM   #5246
Hoggy's Avatar
Trader Rating: 26 (100%+)
Originally Posted by cars.cars.cars
hey guys. im looking at getting a FW-05RR and i was wondering if the OS TZ .12 3-port will fit in it and what are all the things i need to get in order to get the chassis kit on the street?
The O.S. TZ Will fit in and is a very good choice for The FW. I am running a Sirio EVO 2 at the moment. but the O.S is a very good choice. alot of people that race the FW Use that engine or the model bfore the OS Tr
pretty much all that u need to get the car running after the engine is the normal stuff. Radio gear, starter box etc.
Hoggy is offline   Reply With Quote
Old 11-23-2005, 04:19 AM   #5247
Hoggy's Avatar
This is a question for people who have converted to A R From A RR
Did you notice a huge difference when u upgraded Handling wise and lap times? i have heard it gives you more rear bite.
Am thinking bout upgrading but want to know if it going to be worthwhile.
Old 11-23-2005, 10:14 PM   #5248
Default Pull Start for FW-05R/RR
Does anyone know if a side exhaust pull start motor can be fitted to the FW-05R/RR without too much modification?
mwa1980 is offline   Reply With Quote
Old 11-24-2005, 10:14 AM   #5249
NiMo's Avatar
Yes, you will need to place spacers between the motor mounts and the motor lugs (in effect, lifting the motor) so that the pull-start unit clears the chassis.
Space in plenty between motor and rear bulk head assembly for a pull-start unit.
Old 11-24-2005, 10:22 AM   #5250
NiMo's Avatar
I found no real difference in rear grip, just the ability to fine tune the camber change angle.
I did find it had more front end on power bite out of corners.
If you do not want the full converion then at least use the RRR front hubs, gives more steering angle.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
