Old 10-20-2005, 07:51 PM   #5191
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by jeff whiting
I know this has been discussed before but which ring gear is the best all a round option. I run on quite a mix of tracks from parking lot to monster permanent facilities. If I used say the 37t ring gear for the big tracks and for small tracks just went down to the smallest pinions they make would that still have some punch out of the corners? I don't think I want to be swapping ring gears all the time.
37T or 38T are both good. You can always change your pinion gears if necessary. However, my experience has been that I've never found myself lacking punch out of corner with this car whatever the size of track, but sometime I do wish for more top end. So I'd gear on the tall side just to be safe.
jeffreylin is offline   Reply With Quote
Old 10-20-2005, 08:02 PM   #5192
Send a message via AIM to jeff whiting
Thanks Jeffrey. That is what I was thinking. I will run the 37's and just swap pinions and spurs as I need to. Maybe I will set up my RRR for the biggest tracks and use the 05RR on meduim tracks that have super high bite.
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 10-21-2005, 01:34 AM   #5193
NiMo's Avatar
I agree with Jeffreylin although I have yet to find a place where I could use either 23T or 28T gears, but at some I do use the 20T gear (mostly I use 21/26), this is using the 37T rings so maybe the 38T rings would be the better option.
NiMo is offline   Reply With Quote
Old 10-21-2005, 01:54 AM   #5194
Secret_weapon's Avatar
Hi
Im using 40 in the front and 39 ring in the rear. Is it better if i change them to 38 or 37 ?
Here is a the layout of my local track. By the way this is kyosho 5th world cup track in Dubai.
Secret_weapon is offline   Reply With Quote
Old 10-21-2005, 01:55 AM   #5195
Old 10-21-2005, 02:10 AM   #5196
NiMo's Avatar
Originally Posted by Secret_weapon
Hi
How does your car get out of the corners? if you fell like you have too much punch then use the 37/38 option, but if you are bogging out of the corners then stay where you are, clutch set up also makes a difference.
I am running 37 but the 2 tightest hairpins (4inch kerbs) at my track means having the clutch bite a little later but at my 2nd track the tightest in radius is 2feet so I have plenty of punch there.
I like using the 37 as it gives me a much longer 1st gear for the infield sections.
Old 10-21-2005, 04:52 AM   #5197
Im2lazy's Avatar
I already have the 39t hardened bevel gears, and with my motor, I could probably use the 23t gear, and I already use the 28t Mugen gear (Mugen gears last a heck of a lot longer than Kyosho gears) and with my habit of running tiny tires, the 23/28 combo would probably work well.
Using the standard gearing (and 39t bevel gears) the low-end was so powerful that it just spun the tires if I pegged the trigger, and the straight was almost painful. I found going to the 22t pinion gear gave me what seemed to be much quicker acceleration from just about every corner... and sometimes with the 22t gear, I still feel the motor could pull a taller gear.
I'm just voicing my experience with this car (for no reason in particular). I still love the way this car has so much punch! Its a ballsey-blast motoring around the track, lighting the tires at will .
Im2lazy is offline   Reply With Quote
Old 10-21-2005, 06:42 AM   #5198
Thanks everyone for the imput. I have 39t steel gears now but I think I am going to get the 37's and go from there.
JEFF
Old 10-23-2005, 05:14 PM   #5199
edseb's Avatar
Just got a FW05R andd and planning on running a Sirio EVO2 motor with it, but need some advice on a pipe to choose and where to get it from. Thanks fo the help in advance.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 10-23-2005, 05:18 PM   #5200
jeffreylin's Avatar
Hey Carl long time no see. Are you back in LA? The best pipe for the FW is the Skyline VR12S. I tried just about all of them and this one works best.
Old 10-24-2005, 07:09 PM   #5201
Quietroit's Avatar
steering bracket
What is the different between the A,B,C steer
Quietroit is offline   Reply With Quote
Old 10-24-2005, 07:23 PM   #5202
Quietroit's Avatar
Angry Tracks
Is the FW 05R is for small or big track because I'm getting run down on the big track straight way (225feet). I have all the O Ring,opion,spur gear. Need help!
Old 10-24-2005, 08:07 PM   #5203
Are you running the Blue Kyosho 23/28 pinions?
Old 10-25-2005, 10:33 AM   #5204
NiMo's Avatar
With the 37T diff rings fitted your top speed should be faster than an RRR.
I dont even rev out with a 27T gear on a 24ft straight.
Old 10-25-2005, 05:16 PM   #5205
jeffreylin's Avatar
The RRR will have a faster top end. I've ran 37T with 23/28 on a 200ft straight and the RRR come up on top everytime. The pipe you use for the FW makes a big difference. The best I've tried is the skyline pipe.
I know in theory if the FDR is the same they should have the same top speed at the same RPM. However, I think the way the FW's exhaust is oriented (i.e., 180 degree as opposed to 90 degree like most belt cars) limits the engine's output at the top. The FW also has a heavier drivetrain. While it has less rolling resistance thus accelerates faster, the heavier drivetrain eventually saps up more HP at the top end too.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
