Old 10-16-2005, 02:50 AM   #5146
Hi!
I am looking for some weight saving options for next season. I already equipped my fw with rr-conversion, vsw-05b chassis plate (as light as shimo) and titanium pivot balls.
Are there any reasonable titanium screw set out there which will fit nearly all screws of the fw? How is the 3racing first-speed-holder compared to the shimo one? The original free way seems to be quite "tight" but last long. Any thoughts on the 3racing titanium main shaft and second speed holder? The last 3racing main shaft i got was way to small in diametre and had play.
Beside buying parts i thought about replacing some shafts. When i replaced the suspension shafts with titanium they bent to easily so this is no option. But the smaller 2mm "cross-shafts" used all allround the fw could perhaps be replaced with titanium or even carbon composite?
Most interesting: Kyosho offers titanium bevel shafts for the diffs (vzw211). I am tempted to try carbon composite instead of titanium. This should be even lighter (8g steel, 4g titanium, 2g carbon composite). As there are only side loads and no radial forces a solid 4mm carbon composite shaft should be able to do the job. The only thing is wear, but this should be no problem because of the lubing with the thick silicon oil and the broad alignment with the bevel gears!?
The only thing i am wondering about is that no manufacturer is offering things like this?
Comments on this ideas would be really appreciated!
Best regards,
Robert
Robert-FW05 is offline   Reply With Quote
Old 10-16-2005, 03:26 AM   #5147
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by Robert-FW05
Hi!
Best regards,
Robert
I would recommend Shimo and Kyosho original upgrade parts over 3Racing. As to the screws, Speedmind makes a titanium screw set for the FW05R.
jeffreylin is offline   Reply With Quote
Old 10-16-2005, 06:37 AM   #5148
Send a message via ICQ to noobatron
Hey guys,
I'm giving up nitro racing for a while so i'm selling my beloved FW-05R. The car has been fully converted over to the Kawahara ZT-1. THat includes the chassis, centre, front and rear conversions. I've only got the rolling chassis, no clutch or spares. However i do have the orginal box and all the Kawahara instructions.
PM me if you're interested, i'm lookin' to get rid of it fairly quickly.
noobatron is offline   Reply With Quote
Old 10-16-2005, 08:02 PM   #5149
ch4dwick's Avatar
Can you elaborate why, jeffreylin? I'm in the process of buying some parts for my 05RR from an online store and most of their hop-ups are 3R Racing. It was good I came across your post when I did.
When you ban paying customers instead of non-paying ones (with outstanding debts) you're liable to have closed race track. Lugi kasi. ;) O, closed tuloy!
ch4dwick is offline   Reply With Quote
Old 10-16-2005, 08:34 PM   #5150
jeffreylin's Avatar
Shimo/Kyosho has higher and more consistent quality. Kawahara is good too.
Old 10-16-2005, 08:36 PM   #5151
coldeye's Avatar
Default 3R
My experience with 3R is that the quality isn't up to par. The material used seemed to be very porous thus making the parts weaker. Kyosho uses very qaulity material, but will also relate in a higher cost. Some of the 3r stuff is decent. I had bad luck with their universals and shock towers. Good Luck!!
coldeye is offline   Reply With Quote
Old 10-16-2005, 09:05 PM   #5152
ch4dwick's Avatar
Hmm... cheaper actually means expensive and expensive is cheaper. hehehe... confused? coz if it's cheaper it breaks and you have to buy it twice or thrice, which worth more than an pricey brand.
Of course, there are a lot of cases where the quality are just the same. But due to branding mentality we may have the belief that expensive is better.
Old 10-17-2005, 12:15 AM   #5153
coldeye's Avatar
Default 3r
Well put, less expensive usually means more expensive in the end.
Old 10-17-2005, 01:22 AM   #5154
ch4dwick's Avatar
and that was the reason i shiftd to GP from EP.
here's another question:
I've noticed in most sites they don't sell the carbon shock stay (front) for the 05RR (VSW037) but they do have it for the 05R (VSW004).
Do these parts fit the same or not? It would be nice if anyone actually saw these.
Regarding hop-ups:
My friend warned me not to get carried away with hop-ups. Some of them are just "bling-bling" stuff for the kit and don't pose any actual advantage with them installed. He already recommended only the shock stay, muffler holder, and spare gears in case it breaks.
Can anyone recommend parts I should keep in stock as well as parts to hop-up?
Old 10-17-2005, 01:27 AM   #5155
jeffreylin's Avatar
They are different and not compatible.
Old 10-17-2005, 01:32 AM   #5156
ch4dwick's Avatar
How do they differ? I'm looking at their pictures and they don't have any evident difference.
Old 10-17-2005, 01:48 AM   #5157
NiMo's Avatar
Regarding hop-ups:
FW05-RR002 Centre Bulk Head, is a part worth getting. I have been running one for a good while now and it has not distorted in any way.
It also allows better acces to the gears for adjusting the changing point, it seems to let the drive train run smoother, and best of all it lifts the brake pads to the top horizontal position which keeps it away from fuel spillage (pit stops) and also appears to eliminate the sticky brake feel.
For other parts, I have tried other brands but Kyosho/Shimo are the only ones that last.
NiMo is offline   Reply With Quote
Old 10-17-2005, 01:59 AM   #5158
ch4dwick's Avatar
what about the front and rear gearbox? Does it break easily? I was told to stock up on the ring gears as well. But before that, how would you know they were broken when you can't see them?
I guess this is the real prob with shaft cars because of the gearboxes that are enclosed. But common sense tells me this is far tougher than an exposed gearbox. But belt driven is easier to tinker with.
Old 10-17-2005, 02:04 AM   #5159
misel's Avatar
Originally Posted by NiMo
....also removed the throttle servo mount to the chassis to give it more chassis flex thus more chassis grip.
Nimo, did it obviously give more grip?
May be you would share your current setup and tips?
thank's
misel is offline   Reply With Quote
Old 10-17-2005, 02:24 AM   #5160
NiMo's Avatar
Buy a pair of 37T Machined Steel Gear Diffs (VSW025), these will last a long time where as the kit Cast Steel ones wear very quickly.
Gears are available in 37t/38t/39t/40t but I found the 37t to work best for me.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
