Old 09-25-2005, 05:02 PM   #5101
Suspended
Send a message via MSN to rinkeberg
thats not all true, you have seen the growth of prices of touring cars havent you? well i read in this web site that running a 235mm car is cheaper than a touring car in a 12month period, for touring cars there are in a 12months many parts that are replaced and wheels most definatly, the wheels dont last long with that amount of foam so id say that you would be replacing them every race meeting or every second meeting where as in 235mm class wheels can last up to 3 race meets and they handle better and the body styles are not bad at all so in the long run 235mm class is better to be in when it comes to spending money and if no one makes the move back to 235mm then the class wont grow, if you do or anyone else it will and you ll see that this class will become as it was once, the class to be in if you want acceleration,speed and great handling, i know ill be supporting the class, end of this yr im going into 235mm with my brother who owns a NEO Attack MX2 which doesnt exist anymore yes so have a good think about it.
rinkeberg is offline   Reply With Quote
Old 09-25-2005, 11:18 PM   #5102
esham's Avatar
Almost a year now... and if i can recall back my FW journey was -
2004 Before
FW05R, Diff, Original Chasis, Rear loose on power, Hard to drive
2005 Now
FW05RR, OneWay, Shimo Chasis, Rear grip on power, Easy to drive
Now almost every weekend i run FW05RR. Running strong and it nail those apex on my local technical parking lot track. My FW still running strong and fast
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 09-26-2005, 12:41 AM   #5103
ch4dwick's Avatar
i agree with you esham. She's a dream to drive. I'm no racing expert but i don't have a problem driving this car.
When you ban paying customers instead of non-paying ones (with outstanding debts) you're liable to have closed race track. Lugi kasi. ;) O, closed tuloy!
ch4dwick is offline   Reply With Quote
Old 09-26-2005, 04:37 AM   #5104
bulletdays's Avatar
Default Some problem
Hi guys,
I hope someone can give me an idea how to overcome this, the engine always die when after several laps, ive tried to replace a new glow plug, and its still the same thing. I wonder why, but it runs normally i could run for several laps, but the engine die and i cant finish even a tank without this problem. Im using 16%, and Hot glow plug.(Even tried the medium plug but still the same).
Hope you can help solve this out. Thanks a lot.
bulletdays is offline   Reply With Quote
Old 09-26-2005, 08:53 AM   #5105
NiMo's Avatar
Originally Posted by bulletdays
Hi guys,
I've just had a similar problem trying to get an old STS Dragon S3 to sing, it would run fine for about 1/3rd tank then just fade and die, yet when richened 1/4 turn it would not rev enough to even change gear, but someone suggested playing with the head shims, found this at 5 thou, so I reduced it to 3 thou and had loads more torque which actually made it go faster on a richer mixture but it was still not enough, so I reduced to 2 thou, richened another 1/4 and it was loads better, so much so that I now need to up the 2nd gear pinion by a tooth, and it runs the full tank no problems.
Motor is still down on straight line speed as it is only a 1hp motor but the torque now makes it very drivable on the infield.
When money improves I'll get a new one again, possibly a Rossi RR.
NiMo is offline   Reply With Quote
Old 09-27-2005, 12:14 AM   #5106
bulletdays's Avatar
Default Hi Nimo
HI Nimo,
Im just a begginer, do you mean that replacing the cylinder head shims might solve the problem? and also what is 5 thou?
Thanks really.
Old 09-27-2005, 04:40 AM   #5107
esham's Avatar
HI Nimo,
Thanks really.
Bulletdays, it can be very subjective cause of problems. I do suggest you to refer to your local rc friends or your hobbyshop to give you an advise on this matter. It can be due to engine tuning, engine quality, plug etc. because sometime it's easier to a person to diagnose the engine problem by physically listen, tune etc.
Old 09-27-2005, 06:32 AM   #5108
bulletdays's Avatar
Default thanks for that
Thanks but i want to learn it myself..
Old 09-27-2005, 06:37 AM   #5109
bulletdays's Avatar
Actually ive already made it running fine, the only thing is that it wont able to finish the tank.. i think that it just need a little more adjustment, maybe what they've said is right the bottom end is a bit rich..thanks a lot esham
Old 09-27-2005, 07:04 PM   #5110
esham's Avatar
Ok then you might need to look into these articles. The bottom needle shouldn't set too lean or too rich. ( Lean will cause more damage then rich setting). And to check if your bottom needle is set about correct pls. refer to belows articles or come to a level is by the engine idle charateristic. On high speed the throttle / bottom needle is open wide and the amount of fuel goes to carburator is determine by high speed needle. And when at the end of the speed straight come to corner if you release the throttle, the bottom needle will be back to close up to initial idle screw gap setting, during this time the amount of fuel left in the carburateor will be next control by the bottom needle setting. If the bottom setting is too rich it will bog the engine and the engine can stall but if the bottom needle is too lean the engine will rev high ( even you already release the throttle) starving for fuel. For the pinch test i recommend 3-5 second is safe and good initial setting.
Josh Cyrul 101 tuning
pinch test for bottom needle
How to tune engine
All about carburator
Old 09-28-2005, 01:40 AM   #5111
bulletdays's Avatar
Default Hi there esham
Thanks for all these articles, i will read it and learn from it...and see how it goes..ill let you know..thanks a lot.
Old 09-29-2005, 09:16 PM   #5112
hey guys my fw05rr is for sale. please see the getting out of the hobby sale in the northwest forums. thanks, doug
rc.hackmaster is offline   Reply With Quote
Old 09-30-2005, 04:21 AM   #5113
ch4dwick's Avatar
Default front anti-rollbar adjustment
Before anyone will say it: YES I've read the manual on the setup sheet. I still don't get how to adjust the front anti-rollbar. Darn, japanese documentation english! Since I'm the only guy on the racetrack with an 05RR (the rest are NTC3s and V1RRRs) I'm not sure if anyone there can help. How do you adjust the front anti-rollbar? In spite of how they describe it on the manual i can't imagine how it is done.
Old 09-30-2005, 09:56 AM   #5114
NiMo's Avatar
It is easier if you remove the foam bumper, them undo the grub screws then use plyers (or something similar) to rotate the bars.
Do make sure the two parts of the bar are not pushed together too tightly, squashing the front suspension helps this setting.
Flat (horizontal) is softest and upright (vertical) is stiffest, so choose a setting between the two that you want.
Old 10-05-2005, 09:00 AM   #5115
Default Muffler?
Does anyone owns a FW05RR kit that comes with Sirio S12TUP Evo2 engine?
Does it comes with a tuned pipe and manifold. Someone told me it comes with a muffler, what type of pipe is that, anyone care to share the pics of this muffler?
superon is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
