Old 08-10-2005, 07:55 PM   #4981
Originally Posted by NiMo
Spacers on throttle - yes that is correct, I used some little red O rings to also reduce the vibration.
Rear diff - not heard of anyone stripping the Machined Steel ones, you sure they are the Machined Steel ones and not the Cast Steel ones?
See below..
coldfusion is offline   Reply With Quote
Old 08-10-2005, 07:58 PM   #4982
Originally Posted by JoeGlover
by running a smaller ring gear are you lowering the internal ratio and essentially gearing up?
Absolutely
Old 08-10-2005, 08:07 PM   #4983
[QUOTE=coldfusion]Dun know if they are cast or machined. But they are def option steel ring gears from kyosho. Is it written on the tag whether cast or machined? will go back and check tonite.
Anyways, i know the manual in the pack says you don't need to shim the steel option gears but after running once i chipped one of the tooth on the small gear and damaged the ring gear at the front. From that experience, i diregarded instructions and decided to add shims to keep the free play at minimum without binding of course and it seems to work for a few meets. This is with two small shims just after the big bearing before the pin and the small gear.
But the last time i serviced the gears i noticed some freeplay even with the two shims at the rear and added another small shim. Not sure if it was binding but after last weekend's race i found out i damaged both the ring and small gear at the rear again. It was razor sharp! Serviced it last night and changed the god damn ring and small gear again for the third time, removed the third shim and left just two shims in there. added some ring gear grease and packed it back. will test it again this weekend. The front seems to only need one shim. If this @#$$ ring gear strips again i'm going to sell the car and get a RRR!!!
Old 08-10-2005, 08:51 PM   #4984
BundyMan's Avatar
Dude, I think you shouldn't use different ring gears (ie; 40T-F, 39T-R), that could be da problem
BundyMan is offline   Reply With Quote
Old 08-10-2005, 09:42 PM   #4985
esham's Avatar
Please get the V1RRR
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 08-10-2005, 10:34 PM   #4986
ch4dwick's Avatar
Well if this is an isolated incident you could be doing something wrong. never had this problem either. My problem is a lot different. I've been experiencing worn screw heads in my kyosho screws. I'm using the Tamiya (*ahem*) mini toolkit to screw them in place. So far I've worn out 3-4 screw heads just adjusting stuff here and there.
When you ban paying customers instead of non-paying ones (with outstanding debts) you're liable to have closed race track. Lugi kasi. ;) O, closed tuloy!
ch4dwick is offline   Reply With Quote
Old 08-11-2005, 12:07 AM   #4987
Maybe uh? But then it didn't happen for ahwhile until lately?? Whassup wit tat??
You got any steel ring gears for sale? 39 & 40?
Old 08-11-2005, 01:17 AM   #4988
jeffreylin's Avatar
R/C Tech Charter Subscriber
I have a barely used set of 39 I think let me check for sure tonight and I'll let you know.
jeffreylin is offline   Reply With Quote
Old 08-11-2005, 05:26 AM   #4989
Hey man I've got a whole car with 37T and 39T for sale at RM650
cow buster is offline   Reply With Quote
Old 08-11-2005, 06:46 AM   #4990
NiMo's Avatar
Originally Posted by chumanji
Just wondering what kind of body is everyone running on there FW05.
Foam - Proto Mazda6
Rubber - Proto MG ZS
NiMo is offline   Reply With Quote
Old 08-11-2005, 10:08 AM   #4991
jeffreylin's Avatar
Coldfusion, I do have a set of little used 39T ring gears and bevel gears that I will sell for US$20 plus shipping if you are interested. They are in good condition. PM me if you are interested.
Old 08-13-2005, 04:40 AM   #4992
Trader Rating: 13 (93%+)
Default FS: complete front spool, used once
complete, drop in and run
includes 40t ring gear
offers ?? will post worldwide
mrgsr is offline   Reply With Quote
Old 08-15-2005, 02:18 AM   #4993
Jeff, thanks for the offer. Will consider and get back to you.
Mgsr - is this an after market solid spool for the FW or self made version? Also is the 40t ring gear machined steel?
Cow - thanks but i don't need another car - would you like to trade your ring gears for an all day pass at Pudu spa?
Old 08-16-2005, 08:00 PM   #4994
ch4dwick's Avatar
Originally Posted by tigg
got a big prob with keepin the front dogbones in the car, every time i have a slight tangle it throws a bone. runnin the standard setup, even put o rings on both sides,still didn't work. any tip would be handy. cheers tigg
Dude, I finally experienced what you're talking about. I didn't even notice that my dogbone fell off until at least 3 days. Good thing it was still in front of my house but got rusty due to the rain for 3 days.
I also found the cause for it. It turns out if you do a subtrim that is 45 degrees or more on the car's turning angle the dogbone gets exposed on the wheel end. So if you're turning while accelerating this will definitely kick the darn thing out. Try using standard subtrim of 100% because mine was set at 125%. Btw, add the extra oring on the outdrive and not on the wheel end. This will push the dog bone deeper into the wheel. There's ample space in the outdrive and it won't fall off.
Old 08-18-2005, 07:40 PM   #4995
misel's Avatar
Default Kyosho's red clutch shoe
Jeffreylin, would you recomend the use of the kyosho red clutch shoe? I am using NSR5 on medium traction asphalt.
Thank's Jeff.
misel is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
