Old 07-29-2005, 01:13 PM   #4951
dct147's Avatar
Hi guys, if i get a "standard" engine mount for the FW05, should it fit all engines?
dct147 is offline   Reply With Quote
Old 07-29-2005, 01:19 PM   #4952
Im2lazy's Avatar
Originally Posted by coldfusion
On the point of 'trigger control' and driving smoothly which produces the best lap times and better mileage - does you guys mean to say punch when on the straight and release before it comes to a corner, letting it glide in and gradually increase throttle when exiting the corner or like me, i have the tendency to blimp/rev before going into the corner and sometimes blimp even during mid corner - that's not necessarily faster right?
Just need to know how to used the advantages of the FW and the right driving style for better lap times.
On the Kawahara tires bit, yes the front seems to have more offset than any of the other makes (GQ, Jaco, Ellegi) the back is definitely more by 1 or 2mm. I reconfirmed that last night. swapped tires on the the setup board and the front/rear width changed.
One thing you will often see from newer racers going around the infield, they often use too much throttle when you almost never really need to hold full throttle if the infield isn't huge. If you were to drive through the infield without going past 75% throttle, you might notice that with your car more settled (and still going just as fast or faster) that by the end of five minutes you'll see some gained time, as well as lower fuel consumption, less tire wear and fewer crashes. Still open it up as needed, but treat that trigger finger with guarded respect so you don't have to struggle to get the right driving line.
Im2lazy is offline   Reply With Quote
Old 07-30-2005, 04:30 AM   #4953
Thanks for the tips especially the 75% throttle control at the infields. Will try it next time out on the track and check lap times.
Would the front spool really help in giving more tighter lines? What's the part no. or will putting 100k oil in the front diff give similar effect?
coldfusion is offline   Reply With Quote
Old 07-30-2005, 08:03 AM   #4954
impalabob64's Avatar
Send a message via AIM to impalabob64
Default spool
you can run serpents cleaning clay,or 120,000 ofna difflock. works perfect.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 07-30-2005, 11:19 AM   #4955
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
hey bobby call me if you can!
Old 07-31-2005, 11:45 PM   #4956
Default Fw-05R to RR conversion worth it?
Saw a conversion kit...that converts 05R to 05RR...is it worth it. What's in the kit and what does the parts do for ya.
chumanji is offline   Reply With Quote
Old 07-31-2005, 11:54 PM   #4957
jeffreylin's Avatar
R/C Tech Charter Subscriber
It has all the parts to convert a FW05R to a FW05RR.
jeffreylin is offline   Reply With Quote
Old 08-01-2005, 04:31 AM   #4958
hi whats the part no 4 the conversion kit??
tigg is offline   Reply With Quote
Old 08-01-2005, 02:04 PM   #4959
kt racing's Avatar
Send a message via AIM to kt racing
If anyone is interested I have a FW-05R for sale check out my post.
http://www.rctech.net/forum/showthread.php?t=79557
kt racing is offline   Reply With Quote
Old 08-02-2005, 10:15 AM   #4960
The conversion kit part # for FW05R to RR is 36501
Old 08-02-2005, 11:07 AM   #4961
Rob Phillips's Avatar
KT Racing has an awesome deal on a barely ran FW05. Chech it out.
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 08-06-2005, 10:26 AM   #4962
uaerc's Avatar
Anyone knows how good is the VSW016 - and does it really help in improving the tunrin ?
uaerc is offline   Reply With Quote
Old 08-06-2005, 11:07 PM   #4963
Im2lazy's Avatar
That is the optional steering plate right? I used to use it... bent it one day and went back to the original steering plate. The change is subtle, and trying both, I don't mind the fixed ackerman position of the stock plate because it is a tad easier to drive. If you really want to tweak your ride to be as fast as possible, and you think a change in your ackerman might work, I say go for it. But it isn't needed.
And yes, I found position A to increase the turn-in a bit...
Old 08-07-2005, 01:11 AM   #4964
Trader Rating: 13 (93%+)
Default fw-05rr for sale on ebay
i drove a rrr yesterday at my local track and i loved it, stock setup drove like a dream and i wasnt fighting the torque coming in and out of corners.
selling my fw-05rr to buy a rrr
ebay link
mrgsr is offline   Reply With Quote
Old 08-07-2005, 10:39 PM   #4965
Yes i would agree with Im2lazy... Initially i ran with stock front upper+lower arms and the stock steeing plate.. was having a bit or difficulty turning in. After i changed to the optioned graphite steering plate with 'A' ackerman setting and also the option graphite arms which are stiffer - i have one of the best steering controlled FW05s at the local track. Good investment and makes driving a breeze. Would highly recommend.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
