Kyosho FW-05R
#4906
Moderator
I recommend it, I think it's, and pretty easy to drive and get the hang of. Its also durrable as a cinder block... Ive never seen cars take hits like this one can and not show any damage. hits that would have shattered a NTC3
#4908
Hi guys, anyone here with a spare 05RR conversion kit for sale? Or, a spare kyosho 05RR CF upper deck for sale? Thanks.
#4909
Moderator
Originally Posted by Juan C Munoz
Yeah! I know what you mean. I had a NTC3, in my opinion is a good car, but to fragile ! I was hoping on maybe buying a RR and see how it is.
Where in the U.S. can I find it online ?
#4910
http://www.kyosho.co.jp/web/products..._sponge-e.html
You won't find it in the kyosho america site for some unknown reason. Rumor has it that Kyosho Japan & America are not in good terms and that's why newer products of kyosho aren't in circulation in America.
#4911
Snagged a conversion kit the other day, waiting to get it to put it on...
Looking forward to see how the car improves handeling wise, right now the car seems to be handeling superbly though, can't wait to see what improves.
It's a shame if the rumors are true about the Kyosho distributor disputes (if it's true). Luckly the RR shares some of the crucial parts w/ it's cusin, the RRR, so at least these parts will be available.
havy
havy
#4912
havy
havy
#4913
I use 3Racing CVDs, easier to find over here. I hope they fit the RR the same.
havy
havy
#4914
i keep breaking front bottom bulkhead ??
hey team
had an awesome run yesterday coming 5th in the a final out of 38 total people runinng gas.
however in the a main i smacked into a car stopping in the back street and i later found that the front bulkhead broke off with the bumper where the droop screws are.
this also happened to me abouth a month ago. what would happen if i ran the car without this part of the bulkhead in ?
is it possible to strengthen this part ? i was thinking about not screwing in the top 2 screws for the bumper to allow some flex ?
what do you guys think ?
thanks
Jhn
thanks
Jhn
#4915
mrgs, for rough club racing like that, I run the V-one RR lola lower bumper. It helps with tracks that have boards and with cars that are parked like boards. I wish people would actually call their car dead on the straights more often than not. I also fitted my FW with a RRR upper bumper (stock). It seems a little stronger than the stock 05 bumper brace, but I haven't hit anything to really see how it holds up. It screws on perfect. but I did Dremel it a little so I could access my droop screws easier. Try using longer screw to mount the upper bumper to the bulk head. You can also try the PDub foam bumper for the RRR.
#4917
IF You do make sure you go and finde some Racer's Choise One Way bearing grease.
#4918
mrgsr, try using the G4 bumper set on the FW, it fits in nicely and its a whole lot stronger. Alternatively, if you can find some carbon fibre sheet, try cutting it and reinforced the bulkhead (where the droop screws are mounted). I have seen it being done. Yup, that's the weakest point of the FW, otherwise the car is a tank!
Rgds
Rgds
#4919
stock setup question
hello
i run my fw 05rr stock out of the box. the only change i hve made is swapped the springs back to front to help with my lowere traction track.
the stock setup sheet says 1degree negative camber all round. isnt this very little camber ?
when i ran it with 2 deegrees negative my tyres starte dto cone outward instead of inward ..
i guess a softer rear spring would mean more negative camber ?
can someone please clear this up for me
thank you heaps
thank you heaps
#4920
Originally Posted by mrgsr
hello
thank you heaps
thank you heaps
