Old 06-27-2005, 01:29 AM   #4846
BundyMan's Avatar
It all depends on the track which you will be driving your car.
BundyMan is offline   Reply With Quote
Old 06-27-2005, 01:43 AM   #4847
Trader Rating: 13 (93%+)
Default 37t ring gears
hey guys
do the 37t ring gears make much difference to the cars low end take off ?
mrgsr is offline   Reply With Quote
Old 06-27-2005, 04:54 AM   #4848
Depends on the motor, but since it runs very freely, it's not much. I run a Mugen X-12, not going back to 40t. 37t works ecellent in all conditions for me.
havy
havy is offline   Reply With Quote
Old 06-27-2005, 06:08 AM   #4849
im using an os .12 tz
was using the r sec tr
i got the 37t ring gears so i could race at this larger track in my area so i wa shoping i could just keep them installed in the car
what do you think ?
my local track has a pretty shor straight about 50 metres
the other track has a much much longer straight
Old 06-27-2005, 06:18 AM   #4850
NiMo's Avatar
Originally Posted by mrgsr
hey guys
I have the 37T gears in an FW05 running the kit GS15R motor with default 2-speed 21/26 pinions, it still pulls better than standard FW05S's 39T gears with same default gears.
Cars is only 1 lap slower with the GS15R than it was with a JP FX T03, and it upsets many other Scale Rubber racers who cannot match the lap times with supposively better full race RRR's,710's,MTX3's,NTC3's,R40's.
NiMo is offline   Reply With Quote
Old 06-27-2005, 06:36 AM   #4851
awesome im gonna install them and see how it goes at the next club meet
thanks for that
Old 06-27-2005, 11:05 PM   #4852
Default fw-05rr setup sheet in english ?
hey guys
does anyone have the fw05rr setup sheets in english ?
the japanese one looks like it has so much information i just wish i could read it haha
thanks
john
Old 06-28-2005, 04:09 AM   #4853
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
hey guys
thanks
john
try using altavista babelfish it will translate those japanese characters into english language
buboy28 is offline   Reply With Quote
Old 06-28-2005, 07:29 AM   #4854
NiMo's Avatar
hey guys
thanks
john
try here:
http://www.kyosho.co.jp/web/download...g/index-e.html
Old 06-30-2005, 11:22 PM   #4855
Default front blade bar set up help please
hey team
just wanted some help on adjusting the front blade bar
the question is, you know the weird shape plastic part on either sode of the blade bar that adjusts the height of the steering arm ?
should they both be in the same to eachother ? what do these things adjust ?
are they adjusted accordingly to set the droop or are the droop screw in the front bulkhead used for droop ?
should the blade bar be set before droop ? the right adjuster part points out to the side where the one on the left points updwards.. weird
just a bit confused about this
thanks
John
Old 07-01-2005, 01:51 AM   #4856
The two plastic holders on the sides of your front anti-roll blade are meant to equalise your left and right droop height. First you have to ensure the spacing between the two droop set screws are equal and then use these plastic ears to adjust so that the droop is equal right and left. Yes, it is common for the 'ears' to be asymmetrical i.e. not the same but that doesn't matter.
Hope this is clear enough.
coldfusion is offline   Reply With Quote
Old 07-01-2005, 11:14 AM   #4857
j03s4y's Avatar
Send a message via AIM to j03s4y
How would you know if a car "looks fast" just by looking at it? Looks light? heavy? size?
j03s4y is offline   Reply With Quote
Old 07-01-2005, 11:44 AM   #4858
jeffreylin's Avatar
R/C Tech Charter Subscriber
I'd guess the same way a Ferrari looks fast but a Dodge Caravan looks slow.
jeffreylin is offline   Reply With Quote
Old 07-01-2005, 12:05 PM   #4859
Moderator
Clegg's Avatar
Because one associates good engineering with good performance. A well engineered peice of hardware is as beautiful as a painting. I honestly believe for the issues Kyosho's do have, they are beautifully engineered in all the right places.
my FW-05RR is a work of art as far as I am concerned, and just looking at it, it looks fast
A friend who is into cars (real cars) was looking at my RR and asked me "so how does this thing scale?" I explained that if it were full scale for displacement at this power output it would be on par with a top fuel dragster plant crammed into a sub 800lb chassis. that put a smile on his face (thats 5000+ Hp to 800lbs chassis)
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 07-03-2005, 05:39 AM   #4860
Default 37t ring gears on small to medium track ??
hey guys
how does the fw drive on small to medium size tracks with stock gearing and 37t ring gears ?
i tried the car today on a larger track with 37t gears and it ran sweet but the track i mostly run at is much smaller. the track today has a straight of about 50 metres with a 20 meter sweeper at the end.
the track i normally run at has a straight of no more than 30meters.
i read someone on here that the stock 40t ring gears are good enough. im yet to try the 40t at the long straight
thanks
john
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
