Old 06-19-2005, 11:43 PM   #4801
ah ok. Must be only the cheaper cars then are sprung by default - its in my manual and the pad springs to use came with the kit. A pen spring also works
Originally Posted by Clegg
nope, infact I havent owned a car yet that has had pads sprung by default.
au_Nightmare is offline   Reply With Quote
Old 06-19-2005, 11:45 PM   #4802
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by OrAnGe PoWeR
using a thicker diff oil in the rear might help..
Thicker diff oil will increase on power steering and worsen the rear traction problem. Thinner diff is the way to go. If you are using 10k now try 7k. You should also increase your toe-in the rear and perhaps lower your roll center also.
jeffreylin is offline   Reply With Quote
Old 06-19-2005, 11:47 PM   #4803
Trader Rating: 13 (93%+)
my rear toe in is at 2degrees negative
im using the H roll centre so you think is hould jump to the L ?
ill try it out this friday as its the warm up day to the winternationals
thanks heaps
mrgsr is offline   Reply With Quote
Old 06-20-2005, 03:47 AM   #4804
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
Arrow
check the chart attached
jeffreylin: do you have a chart for a 39T ring gear or its just the same as the 40T ring gear, thanks
buboy28 is offline   Reply With Quote
Old 06-20-2005, 03:53 AM   #4805
jeffreylin's Avatar
The Excel spreadsheet includes 40, 39, & 37T ring gear charts. Look at the tab in the bottom to switch between different ring gears.
Old 06-20-2005, 04:25 AM   #4806
Originally Posted by mrgsr
hey team
trying to get my fw-05rr setup on my local track but im having a hard time getting rear end traction.
i race on a good traction track, sometimes its just below good.
i tried the car with stock setup and had the rear taily, so i tried softer rear springs and it got better, less rear droop and more front droop now the car is more manageable.
however im still having problems with on power rear traction. the car has sooo much steering so im trying to get the traction to the rear.
i tried a 37shore front tyre and 35 rear, car was doing good but the 35 shore died 13 minutes into the final.
are there any tips you guys can offer ? the fast guys at my track are using 40 shore tyres all round with awesome grip .. my car is very taily on 40 shore tyres.
thanks
John
hi john! assuming that you are using a front one-way on your car (fwo5rr setup like you said..) and i understand that you are having a very loose rear end already (fishtailing as you have described it..) and considering that you are running on a good traction track like you said.. and have done all these changes to your setup (tried softer rear springs and it got better, less rear droop and more front droop).. putting thinner oil in the rear diff will equate to a looser rear end = sharktailing
OrAnGe PoWeR is offline   Reply With Quote
Old 06-20-2005, 12:18 PM   #4807
kidDynomite's Avatar
Actually a looser rear diff will help the rear from kicking out on low-trac tracks.
kidDynomite is offline   Reply With Quote
Old 06-20-2005, 03:01 PM   #4808
ziggy12345's Avatar
NiMo you said you fitted the FW 05S chassis to your FW. Where can i get one? Can you tell me the advantages?
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 06-20-2005, 03:36 PM   #4809
NiMo's Avatar
Cheers
VS053
It is wider than an R/RR chassis, but it appears to have more flex in it, and using it with the 3racing RR top deck gives chassis flex that gives more grip on a lower grip surface.
NiMo is offline   Reply With Quote
Old 06-20-2005, 04:32 PM   #4810
impalabob64's Avatar
Send a message via AIM to impalabob64
Default hey
bobby here ,i hve to let my fwo5 go ,i hey the rrr i wont be able to maintain 2cars so its going for 600.00 obo with enough parts to build 2 more complete fwo,s .comes with manuel,setup sheets,
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 06-20-2005, 04:33 PM   #4811
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
WHAT!!!!!!!!
Old 06-20-2005, 04:33 PM   #4812
Super Moderator
Marcos.J's Avatar
are you sure bobby???
Old 06-20-2005, 04:34 PM   #4813
Super Moderator
Marcos.J's Avatar
i guess you are tired of going fast
Old 06-20-2005, 04:34 PM   #4814
buboy28's Avatar
ok found it i overlooked itthank you very much
Old 06-20-2005, 05:25 PM   #4815
Moderator
Clegg's Avatar
WTF is the deal with everyone selling off the RR's!?
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
