Old 06-08-2005, 10:19 PM   #4771
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by impalabob64
cant get to come up
hey bobby i got a copy of the gear chart i give it to you on sunday!
Old 06-08-2005, 10:20 PM   #4772
impalabob64's Avatar
Send a message via AIM to impalabob64
Default i understand now
thank you
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 06-08-2005, 10:21 PM   #4773
Super Moderator
Marcos.J's Avatar
thank you
get your car ready im bringing the r12 out of retirement
Old 06-08-2005, 10:24 PM   #4774
Default Ok
Just need to get alittle more speed,to out run ab,an austin
RoninRc.com
Basher BT-4
Old 06-08-2005, 10:26 PM   #4775
Super Moderator
Marcos.J's Avatar
i need it on my car , your car flies!!
Old 06-10-2005, 09:40 AM   #4776
Trader Rating: 13 (93%+)
Default switch wiring
hi guys
just wanted to know what the best way was to set up the wiring for the servos, switch etc ??
i never used to run a switch but i hated the idea of having to always plug and unplug the battery from the receiver
some pics would be great ??
thanks
john
mrgsr is offline   Reply With Quote
Old 06-12-2005, 05:43 AM   #4777
Default first time prob with fw-05rr - dogbones~!!
hey team
i took my fw-05rr out today for its first race meeting
car was built exactly as it was from the box with stock setup
handling - car had so much front end grip that the ass would be all over the place. move dto 37 front and tyres and 35 rears helped a bit but im still having rear end problems
front dog bones - i dropped both my front dogbones just by exiting the pits and taking my first turn. what is the key to keeping the dogbones in ?
i had to screw in the pivot ballstill i had 2mm gap between the arm so the dogbones wouldnt pop out. now my front track width is 197mm
what have i done wrong ?
thanks guys
John
Old 06-12-2005, 08:32 AM   #4778
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally Posted by mrgsr
hey team
thanks guys
John
try to turn down your steering travel and change the front anti-roll bar to the vertical (hardest) position. Also try to add some camber and toe-in in the rear.
On the dog bones, did you miss the plastic spacer you are suppose to use between the front one way and the one-way outdrive?
jeffreylin is offline   Reply With Quote
Old 06-12-2005, 07:08 PM   #4779
plastic spacer ??
ooops yes i did miss that
Old 06-13-2005, 12:14 PM   #4780
kidDynomite's Avatar
Just an FYI for a last min. fix, if you ever happen to loose the plastic spacers for the front outdrive, you can use an aluminum 2mm spacers that are normally used on the rear axle. It's a perfect fit so you don't have to worry about it causing glitching.
kidDynomite is offline   Reply With Quote
Old 06-13-2005, 05:12 PM   #4781
Default front adjustable turnbuckles ?
thanks for all your help with the frint dogbones
I just wanted to know if it was possible to replace the front turnbuckles with adjustable ones that fit the existing ball ends ??
what turnbuckles are you guys using ?
i want to be able to adjust them without having to take them off each time
thanks
Old 06-13-2005, 06:31 PM   #4782
jeffreylin's Avatar
thanks
If you look in the back pages of the manul, you will see that Kyosho makes a titanium tune buckle for the FW05. However, to use it you would need to cut your ball cup so the steering linkage is not too long.
Old 06-14-2005, 12:12 AM   #4783
thanks
here's another option.. use the stock adjustable turnbuckle supplied for the rear anti-roll bar on your steering linkage, you don't have to adjust the rear anti-roll bar as often as the steering linkages anyway.. mine worked! Im using the medium and short ball cups on each end.
OrAnGe PoWeR is offline   Reply With Quote
Old 06-14-2005, 05:14 PM   #4784
I know this isn't the for sale forum but I'm really looking for a set of spur gears for my car. If you have any extra you wouldn't mind selling it would be appreciated greatly.
I called in an order of parts from Kyosho today and they didn't have any in stock(46tooth second gear) . Kind of desperate here-again sorry for posting it here but I thought I should go straight to the source.
Thanks,
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 06-14-2005, 09:13 PM   #4785
Default spur
45t spur will work alittle more topend speed
RoninRc.com
Basher BT-4
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
