Old 05-15-2005, 04:49 PM   #4606
impalabob64's Avatar
Send a message via AIM to impalabob64
Default thx
you see the battle between my fwo5r an abners rrr. what did you think.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 05-15-2005, 06:04 PM   #4607
roadrage's Avatar
Trader Rating: 14 (100%+)
Default Re: thx
I think the mugen was faster than both
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 05-15-2005, 07:28 PM   #4608
BundyMan's Avatar
Default Re: droop
hey i run 0 droop frt,3droop rear 60mm,frt an rear ,i also use the serpent cleaning clay in my frt diff ,so i can get the spool effect but also has alittle diff action.
Bobby, how the front "solid" compared say to the one-way or diff?
Rgds
BundyMan is offline   Reply With Quote
Old 05-15-2005, 10:40 PM   #4609
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Re: thx
thats why you finished behind bobby
Old 05-15-2005, 11:11 PM   #4610
Moderator
Clegg's Avatar
Man the first weeeknd of racing was canceled because it was rainy and cold. But the day turned out to be sunny and not too bad...
So itching to get some running in. Hopefully I get my 3R center bulkhead and other goodies in by the end of the coming week so I can run in proper shape next weekend
One thing I am regretting with this Kyosho is it seems Kyosho is killing off the FW cars in the US. the R and RR isnt even on the US page for their offerings. Tower Hobbies has dumped all VOne RRR and FW-05R parts from their listing (infact nearly all non heli Kyosho items have been dropped). Meaning you need to order from HK for parts or Japan... What a pain in the ass. also that info from Kyosho is as easy to access as it is flying a plane into restricted air space in the US...
Makes me almost wish I went with a NTC3 just so I can get shit when I want it...
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 05-16-2005, 07:40 AM   #4611
Trader Rating: 13 (93%+)
Default stock final drive ?
hello
just wanted to know what the stock final drive ratio is for the fw05r with 40t ring gears
thank you
just trying to get more speed from my car
and yeh the skyline vr12s pipe is awesome!
mrgsr is offline   Reply With Quote
Old 05-16-2005, 07:49 AM   #4612
Super Moderator
Marcos.J's Avatar
Default Re: stock final drive ?
Originally posted by mrgsr
hello
thank you
you can go with the 39 t ring gears and change the pinions (2nd gear) to 27 or 28. How long is the straight at your track? I ran the 39t with the 21/27 pinion combo with the Skyline pipe and had plenty of speed at the end of the 237ft straight.
Old 05-16-2005, 07:55 AM   #4613
Default Re: Re: stock final drive ?
well my local track that i race at has a straight of about 70ft plus another 20 ft with the sweeper at the end of the track
I see some guys with so much speed that the car is picking up more and more speed down the straight.
Another track that iw ould like to race at soon has a straight of 170ft !!
Old 05-16-2005, 08:02 AM   #4614
Super Moderator
Marcos.J's Avatar
Default Re: Re: Re: stock final drive ?
the 39t should work great another track that i raced at was 175ft and had plenty at the end , you can also get the kawahara center conversion, i installed that and the car had alot of lowend power and it had plenty of speed at the end , i ran the center conversion with 57mm front tyres and 59 mm rear tyres and still had plenty of speed. With the center conversion you have to run a 1 to 2mm split.
Old 05-16-2005, 08:11 AM   #4615
i currenyly cut my rear down to 62 and the front to 61mm
however im trying to sort out my rear from spinning out in corners
impretty sure ic ured the problem tonight when i fitted the alumium front blade. i noticed the droop was on 3 front and 4 rear so i made the front 0 and the rear 3
i hope that works, ill know this saturday when i go race again
wats the best place to get 39t ring gears from ?
Old 05-16-2005, 09:26 AM   #4616
NiMo's Avatar
Man you are lucky to have had such a wide choice.
The UK importer is still selling the V-one R, and in the pull-start range the V-one S2 and Alpha 3 (with lousy spares support).
FW05 / V1RRR cars and parts in the UK have all been sourced from Japan or HK by privateer racers.
NiMo is offline   Reply With Quote
Old 05-16-2005, 09:56 AM   #4617
jeffreylin's Avatar
R/C Tech Charter Subscriber
A Kyosho FW05R (not RR) just TQed and won the STS cup held in Hong Kong over the weekend.
jeffreylin is offline   Reply With Quote
Old 05-16-2005, 10:16 AM   #4618
NiMo's Avatar
I have been running an FW05S with RR conversion and a GS15R motor at the last 2 club meetings running with the more powerful rubber shod .12 cars, both times I've qualified 2nd and finished 2nd in the finals.
Just goes to show that this car does not need a high powered motor to get the results.
Only major change in the car is the fitment of the Machined 37T diff rings, standard kit supplied gears are used.
Old 05-16-2005, 01:16 PM   #4619
Default final drive ratio
hey run 37t ring gears, thats what i run everywhere big track, small track.what engine do you run.oh i forgot, my fwo5 brothers,i pickup another fwo5 from my buddy austin.now back to your 70ft plus.if you motor has the hp, run this gear combo 21/50 27/46 0r 45 this should put you right beside the guys,an show em what the fwo5 is all about.here at my tracks im the only fwo5r.besides my buddy abner.this is the car that i prefer to drive.hey jeff,nimo how is it going, gettin hot here in fla. 38t ring gear what be the final drive ratio thinking of trying it out.FWO5R.
RoninRc.com
Basher BT-4
Old 05-16-2005, 01:44 PM   #4620
jeffreylin's Avatar
Hi Bobby, have not run nitro for the last couple of weeks. I am selling my FW as I am trying to downsize...
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
