Old 04-26-2005, 04:37 AM   #4501
Hi John!
You have to insert a black o-ring (supplied with your kit) in the inner outdrives to prevent the dogbones from popping out. Check your manual to see that.
To everybody:
I have a big problem with the weight distribution on my fw-05rs (rr with s-type motor and rubber tires). I use a small lipo-pack for weight reduction and therefore have about 60-65g more weigth on the rigth tires as on the left tires. Last weekend i grip-rolled about six times to right and i doubt that one factor is the little weigth on the left side of the car. Can someone give me some tipps how to work it out? This problem should have every racer using a lighter battery-pack than the 5 2/3A-cells (about 100g).
Robert
Robert-FW05 is offline   Reply With Quote
Old 04-26-2005, 04:39 AM   #4502
Trader Rating: 13 (93%+)
thanks for that robert but that was making my wheels bind when the suspension was compressed
i guess ill just lightly increase the track width and put the dogbones back in
what do you guys think about the 3 racing front unis ??
mrgsr is offline   Reply With Quote
Old 04-26-2005, 12:25 PM   #4503
NiMo's Avatar
Eerm! how do I say this?
I have placed an order for a V-one RRR WC kit !!!
I saw a video of one at my local track and could see them put the power down harder and earlier then I can ever hope to with my FW05RR, so I've got to give the RRR a go.
NiMo is offline   Reply With Quote
Old 04-26-2005, 01:26 PM   #4504
jeffreylin's Avatar
R/C Tech Charter Subscriber
NiMo, I too loved the FW05 but the RRR will work better 80% of the time. It's a different kind of driving and you will need to get use to it, but at the end you would be gald with your decision. See you at the RRR thread.
jeffreylin is offline   Reply With Quote
Old 04-26-2005, 01:34 PM   #4505
NiMo's Avatar
Ha ha, just had a quick look, lots of pages to catch up on.
Hope the fuel tank issue is now solved.
Old 04-26-2005, 01:56 PM   #4506
jeffreylin's Avatar
If you get the WC kit it will have the updated upper deck which has elongated holes that hold the tank. Make sure your tank is loose so that it can move back and forth if you push it. Just to be safe you should also run a soldering iron around the seam of the tank to seal the tank further.
Having done the above, I haven't had a problem since.
Old 04-26-2005, 02:04 PM   #4507
NiMo's Avatar
Thanks for the tip, car is being shipped as we talk, just need to find who's selling the Kawahara pinion gears for it as I'm told the Kyosho ones are a little on the soft side.
Old 04-26-2005, 02:21 PM   #4508
jeffreylin's Avatar
Yeah but the Kawahara ones are made with steel so it's heavier.
But while you're at it, I strongly recommend picking up the Kawahara brake disc and the Kyosho aluminum brake lever.
Both should be available from Pro Shop Futaba.
Old 04-26-2005, 02:45 PM   #4509
NiMo's Avatar
I was looking at that disc and the rear blade roll bar, hadn't though about the brake arm.
Does Pro Shop have a section with the parts listed? if so I have yet to locate it, as it is I'm having to email them to ask if they have a part in stock, then wait a couple of days for the reply.
Old 04-26-2005, 03:29 PM   #4510
jeffreylin's Avatar
No you have to email them. They usually get back to me in a day.
The brake arm is important as the stock plastic one does wear off and causes fade.
VZW063 Kyosho Aluminum Brake Lever
Z-1815/16/17 Kawahara pinion
K-496 Kawahara Brake Disc
Old 04-27-2005, 08:55 AM   #4511
NiMo's Avatar
It's here already
I only ordered it 64 hours ago from Dimball.
Old 04-27-2005, 10:56 AM   #4512
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
It's here already
that was fast!
Old 04-27-2005, 12:13 PM   #4513
kidDynomite's Avatar
My local permanent track (200x80) won't open til July and we'll have organized racing in a newly asphalted parking lot (160x60). The traction is medium grip, but does come up by the mains. I was wondering if someone had a good setup for medium traction tracks. You can see the suspension work, so it's not totally flat, but it is smooth.
I'd like a little more on-power steering. Should I go softer front springs (Silver Rear) and stiffer back (Black Rear)? I'd hate to have to wait to race it on the permanent high traction track.
Thanks in advance for any help or setup info.
Tommy
kidDynomite is offline   Reply With Quote
Old 04-27-2005, 12:23 PM   #4514
Super Moderator
Marcos.J's Avatar
Tommy
Old 04-27-2005, 01:08 PM   #4515
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Tommy
Yes, you can do that. You can also increase the caster angle if you haven't already and increase the droop in the front to say..."-2" on a droop gauge. Experiment with the droop because it makes a huge difference on this car.
Racing4Evo is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
