Old 04-23-2005, 06:33 AM   #4486
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: gearing
Originally posted by impalabob64
hey i found a good 22/50 28/46 top is good.hey nimo i hve run the serpent cleaning clay, in my front diff it works pretty good . at the winternats i saw murnan running the solid frt in his RRR at Fort Meyers.I think on a high traction track it works well, an i think to if dial out some steering it would help if you run on high flowing tracks.thats if you running the rrr frt hubs.thats just my two cents.
bobby what ring gears are you running?
Old 04-23-2005, 06:53 AM   #4487
impalabob64's Avatar
Send a message via AIM to impalabob64
Default 37t
37t ring gears
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 04-23-2005, 06:55 AM   #4488
Super Moderator
Marcos.J's Avatar
Default Re: 37t
37t ring gears
you will be overgeared with the 37t ,lakeland is not that long of a straight, (about 170) i was overgeard with stock pinions with the kawahara conversion
Old 04-23-2005, 07:35 AM   #4489
Trader Rating: 13 (93%+)
Default slak in front steering
hello
how is it possible to get rid of the slack in the front steering ?
thanks
John
mrgsr is offline   Reply With Quote
Old 04-23-2005, 08:03 AM   #4490
Default gearing
so what would 20/51 25/46, with 37t i ran this at SpaceCoast
RoninRc.com
Basher BT-4
Old 04-23-2005, 08:08 AM   #4491
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: slak in front steering
Originally posted by mrgsr
hello
thanks
John
You need to replace the ball studs and the ball cups on a regualr basis as they do wear and create slop.
jeffreylin is offline   Reply With Quote
Old 04-23-2005, 08:23 AM   #4492
the slack seams to be coming from the bell crank though however ive tightened that all up
Old 04-23-2005, 08:27 AM   #4493
Default hey
marcos whats your #so i can call
RoninRc.com
Basher BT-4
Old 04-23-2005, 12:28 PM   #4494
NiMo's Avatar
Default Re: gearing
The only time I now consider running a solid front is in the wet or on a greasy track, it allows for harder braking and removes diffing out.
NiMo is offline   Reply With Quote
Old 04-24-2005, 07:14 AM   #4495
Default front dog bone problem
hey guys
had a problem with my front dogbone popping out on the weekend in a race...
im using front rrr hubs on a fw-05r, im also using the rrr dogbones as they are longer and dont have as much slack
however in a slight hit my dogbone jammed and the wheel got stuck ...
i think its best to upgrade to front unis so would it be best to order the front rrr unis ? as im using the rr hubs
thanks
JOhn
Old 04-24-2005, 07:42 AM   #4496
Default what pipes do you guy suse for the fw-05r ?
i currently use the kyosho pipe and manifold kit
however the pipe has a couple of small dents in it, does this affect the performance ? or anything ?
would it be best to buy a new pipe or go with a 1 piece setup ?
thanks!
Old 04-24-2005, 08:58 AM   #4497
Super Moderator
Marcos.J's Avatar
Default Re: front dog bone problem
hey guys
thanks
JOhn
what is your track width?
Old 04-24-2005, 08:59 PM   #4498
jeffreylin's Avatar
Default Re: what pipes do you guy suse for the fw-05r ?
thanks!
Get the Skyline one piece pipe. It cost the same as a Kyosho pipe without the manifold and performs better in my opinion.
Old 04-25-2005, 01:16 PM   #4499
Trader Rating: 43 (100%+)
Check if you put too much o ring or fuel line within the outdrive.
MK
hey guys
thanks
JOhn
monokenny is offline   Reply With Quote
Old 04-26-2005, 04:26 AM   #4500
my front track width is 199mm
i am using front rrr hubs with rrr dogbones as they are longer than the fw05 ones
i am not using o rings inside the outdrive cups either
i guess ive done something wrong ?
John
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
