Old 04-04-2005, 11:39 AM   #4411
jeffreylin's Avatar
R/C Tech Charter Subscriber
i personally just keep messing with it until it doesn't suck...
but seriously, i think the only way to decide is to try. the stock setting is usually pretty good to start, then you'd compensate for things like size of tire, size of in field, etc. how you tune your engine matters too, as that affects your power band and 2nd speed kick in point.
jeffreylin is offline   Reply With Quote
Old 04-04-2005, 03:56 PM   #4412
ziggy12345's Avatar
Anybody interested in the bits left from my FW-05R?
I have the 705 chassis, the centre conversion and the alloy centre bulk with all the drive train plus the roll bar.
The rear has the Mugen hubs and most of the bits.
The shock are missing as I have stripped all the stuff off that I can use on the RRR. everything thats left is for sale.
Anybody?
Ill be away for a few weeks so ill check back later.
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 04-05-2005, 04:33 AM   #4413
impalabob64's Avatar
Send a message via AIM to impalabob64
Default hey
what all do you hve
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 04-06-2005, 07:36 PM   #4414
Trader Rating: 13 (93%+)
Default aluminium upgrade parts ??
hi all
i was wanting to upgrade some parts on my fw-05r foam tyre version
i was thinking of upgrading the following:
aluminium front stabiliser
aluminium brake stopper
aluminium steering servo saver
are these upgrde worth it ?
what are some other upgrades that i should be doing ?
thank you
john
mrgsr is offline   Reply With Quote
Old 04-06-2005, 08:03 PM   #4415
jeffreylin's Avatar
Default Re: aluminium upgrade parts ??
aluminium front stabiliser: I assume you meant the aluminum front anti-roll bar holder? This is a must as the stock plastic ones will not hold your droop setting.
aluminium brake stopper: Another important upgrade as the pins comes out of the stock plastic one easily. But the aluminum brake holder does wobble after awhile. You'd be better off getting the K-Factory one if you can find it.
aluminium steering servo saver: Never tried it. I don't think you need it though.
The best upgrade if you haven't already got it is the harden steel ring gears.
Old 04-06-2005, 08:27 PM   #4416
Default aluminium steering servo saver
I upgraded the servo saver, but only used the arm the connects to the steering servo (top left one). Its not lighter and the only reason was the origional plastic one didn't stay fixed when tightening the servo saver spring.
I changed to the 3racing center bulk head, it's pretty nice.
About the front droop screws, the front case has bent where the screws srew in, no more droop settings for me.
i think the Alu Rear arm mounts is a good option too, I've broken 3 of those (bad bearing had me crashing often- good excuse huh? )
Center CVDs isn't a good option, the pins have broken several times, I like to use brakes.
37t ring gears, way good up-grade, very happy w/ it, run the smaller pinions on small tracks and still hangs in there.
Brake upgrade is also very good. don't remember the model number, but even though it's a couple of bucks, brakes are awsome.
havy
havy is offline   Reply With Quote
Old 04-06-2005, 10:10 PM   #4417
get the rear arm mounts, brake stopper, front sway bar, front lower arm mounts. stay with the plastic servo saver you need something to give instead of your servo getting trashed. brake upgrade is a must with the soft pads but be carefull if you run a one way. use the abs feature if your radio has it. mine works great.
rc.hackmaster is offline   Reply With Quote
Old 04-06-2005, 10:39 PM   #4418
BundyMan's Avatar
The lower mounts are great to have especially if you are crash prone
I find that lightening the transmission gives the biggest bang for the buck. Try getting the light weight clutch bell, titanium center shaft, lightened 2 speed adapter & first speed holder and Kfactory pinions. The rest of the stuff are just for cosmestic purposes and seriously doubt if it will improve the performance of this car.
BundyMan is offline   Reply With Quote
Old 04-06-2005, 11:00 PM   #4419
jeffreylin's Avatar
And if you can find one, the Square titanium 2 speed shaft.
Old 04-10-2005, 12:45 PM   #4420
Kurly's Avatar
Default Fw-05R
heres one for you guys if you need a spare car and parts.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Kurly is offline   Reply With Quote
Old 04-12-2005, 08:16 AM   #4421
Default FWO5R
soem pics of my FWO5R.
NovaKing is offline   Reply With Quote
Old 04-12-2005, 08:18 AM   #4422
Default FWO5R
other pic...
Old 04-12-2005, 08:19 AM   #4423
Default FWO5R
last pic...
Old 04-12-2005, 08:34 AM   #4424
What pipe/manifold combo are you guys running?
RTolle is offline   Reply With Quote
Old 04-12-2005, 09:04 AM   #4425
jeffreylin's Avatar
Skyline VR12! It works better than the black Kyosho 5.2mm pipe and the Kyosho pipe was good!
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
