Old 03-06-2005, 02:56 PM   #4276
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Re: Re: Pipe
Originally posted by Buggy Master
hmmm.... with all this positive feedback about the skyline pipe, i think i'll buy it to compare or replace my rd logics turbo 2 outlaw
try you wont be disappointed!
Old 03-06-2005, 02:56 PM   #4277
NiMo's Avatar
Got round to racing with the new 3racing RR SSG top deck and gearbox today and boy! did I have the grip, I felt I could have taking the banking flat (lack of bottle prevented this), Nitro Shoe 38's with a PF Mazda6 was awesome today, even if my face did get burnt from the icy cold wind (wind chill was a good -10c).
NiMo is offline   Reply With Quote
Old 03-06-2005, 05:57 PM   #4278
Default Springs
Dear all, is the kyosho black springs softer than the gold springs?
cow buster is offline   Reply With Quote
Old 03-06-2005, 07:29 PM   #4279
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Springs
silver = soft, black = medium, gold = hard
jeffreylin is offline   Reply With Quote
Old 03-06-2005, 07:30 PM   #4280
InitialD's Avatar
Default Re: Springs
Not all Uncle Cow... Black front springs are harder than Gold rears. A list of hardness from gold, black and silver springs are as follows...
Front
VZ072-2517 Gold = 863 g/mm (48.3 pounds / inch)
VZ072-3017 Black = 719 g/mm (40.3 pounds / inch)
VZ072-3517 Silver = 617 g/mm (34.6 pounds / inch)
Rear
VZ073-3516 Gold = 493 g/mm (27.6 pounds / inch)
VZ073-4016 Gold = 432 g/mm (24.2 pounds / inch)
VZ073-4516 Gold = 384 g/mm (21.5 pounds / inch)
Old 03-06-2005, 07:33 PM   #4281
misel's Avatar
Default Re: Pipe
Originally posted by jeffreylin
Folks, I've been running the Kyosho 5.2mm black pipe on my FW05RR and have been quite happy with it. It works well and gives me plenty of top end. They only thing I don't like about it is the coupler which is prone to come apart in a crash.
So when it did come apart this afternoon during practice, my friend at the track gave me a Skyline V12 to try. Boy was it an eye opener! I had probably 15-20% more top end with this pipe. I thought my car was fast enough at the straight (Novarossi NS3) and now it's absolutly ballistic! And it's not just the top end, the low end had more power as well! I was surprised that a pipe could make that much of a difference.
By the way, the car was working real good too. I had so much steering I had to turn it down and add toe-in in the rear--something I almost never did with the FW05R.
Hey jeffreylin,
I am running fwo5rr and I've been thinking of getting the rrr too. I will preferably stick with my fw05rr if I can only get it competitive with the rrr.
Do you think your fwo5r with Skyline V12 is competitive with your rrr? You mentioned before that your rrr was faster by 0.2s.
thank's
misel is offline   Reply With Quote
Old 03-06-2005, 07:44 PM   #4282
jeffreylin's Avatar
Default Re: Re: Pipe
Originally posted by misel
Hey jeffreylin,
thank's
I think it depends on track condition, one chassis could work better than the other. The pipe gives you more power but it does not help the other aspect of the car. Power is never the problem. A properly set up car with a slow motor will beat a fast but bad handling car almost always.
I was going to switch to the RRR all together but I am keeping both now for different conditions. The 0.2 sec I mentioned was just one time at that particular track. It does not mean the RRR is always faster.
Old 03-06-2005, 07:54 PM   #4283
misel's Avatar
Sorry, I thought you got so much steering when you used Skyline V12. How did you get so much steering from?
Old 03-06-2005, 08:00 PM   #4284
jeffreylin's Avatar
Default Re: Re: Re: Re: Pipe
WHAT! how do i get steering from a pipe?
i guess i had steering because my car was set up right. perhaps the RR conversion helps too.
Old 03-06-2005, 08:18 PM   #4285
misel's Avatar
Default Re: Re: Re: Re: Re: Pipe
Yeah, my bad.
Could you give your latest set up? I know we are running on different track, I just want to try on something and your set up might possibly gives more steering on my car.
My car is getting more and more steering after experimenting with setups, but now I ended up with 35 shore (front) and 37 (rear) tires. My friends said it's a no no to have rear tire at a higher shore. What do you think?
thank's jeffreylin.
Old 03-06-2005, 08:34 PM   #4286
jeffreylin's Avatar
Default Re: Re: Re: Re: Re: Re: Pipe
Yeah, my bad.
thank's jeffreylin.
I think whatever works good you should stick with it. I think 35F 37R sounds fine.
Here is my latest setup:
Front
500 wt black long
inner most shock mount
2 degree camber
0 degree toe
1mm droop using hudy gauge to the bottom of wheel hub
flat front sway bar
56mm kawahara 37 tire
10 degree caster
ackerman position b
4mm rideheight
Rear:
10k diff
500 wt gold long
3.5 degree camber
2 degree toe
6mm droop using hudy gauge to the bottom of wheel hub
black sway bar
roll center position H
4.5mm rideheight
gears
39T steel ring gear
22/50 27/45
Old 03-06-2005, 08:42 PM   #4287
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Race it at Airtronics Jeff! Race Expert too!
Racing4Evo is offline   Reply With Quote
Old 03-06-2005, 08:45 PM   #4288
InitialD's Avatar
Not necessary so... By doing that, you can even make the front and rear tires wear the same which is a good thing.
Old 03-06-2005, 08:45 PM   #4289
jeffreylin's Avatar
Maybe, I will probably run both cars and see which works better.
Old 03-06-2005, 08:46 PM   #4290
Super Moderator
Marcos.J's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Pipe
Front
500 wt black long
2 degree camber
0 degree toe
flat front sway bar
10 degree caster
ackerman position b
4mm rideheight
Rear:
10k diff
500 wt gold long
3.5 degree camber
2 degree toe
black sway bar
4.5mm rideheight
gears
39T steel ring gear
22/50 27/45
are you running one-way or diff in the front?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
