Old 02-09-2005, 01:16 PM   #4036
Default Re: Re: RR Conversion Kit Manual
Originally posted by Marcos.J
for the RR
VS023 SWING SHAFT
VSO37 FRONT UPPER BRACKET
VS038 FRONT UPPER SUS. SHAFT
VS039 CARBON DECK
VZ004C REAR SUS ARM SET - not the vz004ch you said.
VZ 013 WHEEL SHAFT
VZ 201 & 202 - FRONT AND REAR HUBS
Hi Marcos,
Thanks for the info. As far as screws, do I need any special screws? or the screws that came with the regular kit will suffice.
cvccsi is offline   Reply With Quote
Old 02-09-2005, 01:19 PM   #4037
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Re: Re: RR Conversion Kit Manual
Originally posted by cvccsi
Hi Marcos,
i think that they are the same
Old 02-09-2005, 10:07 PM   #4038
Moderator
Clegg's Avatar
just noticed that Kyosho lists the FW-05R as discontinued already
I also just ordered the 3R chassis. my logic is, if its cheap and flimsy and sucks I can just get the Shimo one later. 32$ is nothing in this hobby and if it works fine, then coo, I saved 40$.
I just did the math, with my 3 orders of parts from HK, the total for this car is CHEAPER still than what a new RR costs. I got my 05R for 140$ w/o engine. It was used for an entire season. Now I have done the RR upgrade, replaced a fair bit of the driveline, replaced most of the screws (most with Stainless Steel, some with Ti) , went with the Al servo mounts (because the plastic ones were MISSING with this car!), and a CF rear shock tower.
Total so far is like 350$ if you count the 140$ and the 190 in other parts I have purchased for the car. A bit less than the $385 price for the RR kit and has many upgrades the RR doesnt have (such as CV's on the front and rear, the hardened gears, etc..)
So now I have another question to the 05R tuners of the world. My car is going to have a pretty steep ratio. 7.28 in first and 5.52 in second, I am going to be running an OS .12TR 5P Turbo plant. Any recommendations on clutch shoe to use? the course will be pretty technical and I would like something to give a smooth but solid engagement at a higher RPM (to keep torque up in the power band when bliping the throttle around a tight corner). is the Grey the prefered shoe for that kind of engagement?
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 02-09-2005, 10:48 PM   #4039
Super Moderator
Marcos.J's Avatar
thats because kit #31581B has been replaced by the foam edition(31582B with the one-way) and the FW-05RR
Old 02-10-2005, 09:06 AM   #4040
NiMo's Avatar
You will still get all the FW05R parts as they are now used on the 05S and 05T.
Black clutch is standard
Grey is softer than Black
Red is Sharper than Black
NiMo is offline   Reply With Quote
Old 02-10-2005, 09:37 AM   #4041
Super Moderator
Marcos.J's Avatar
Have you tried the red yet?
Old 02-10-2005, 09:43 AM   #4042
Hi Nimo, Do you run your FW05RR on rubber tyres, if you do could you please tell me your front end set up to eliminate the grove on the inside of the tyre. Is it a toe-in,toe-out or camber/caster issue ? Thanks .
ernie is offline   Reply With Quote
Old 02-10-2005, 09:58 AM   #4043
Super Moderator
Marcos.J's Avatar
i hear that he is the master with rubber tyres!
Old 02-10-2005, 10:00 AM   #4044
NiMo's Avatar
You will always get more wear on the inside of the front tyres, this is normal for this car, but if you're getting a groove it is probably down to using a too smaller insert, you will need one that fills the tyre, I use Echo 4430S inserts (S = soft, M & H available) sometimes I might use the 4432S in the front to reduce inside wear but this looses a little grip.
If you can get them, use the ING wheel (T24MMS), it's a 0.8 inch up wheel so the tyre seats better.
Old 02-10-2005, 10:07 AM   #4045
NiMo's Avatar
Forgot to say:
When using Rubber tyres you will need to enlarge the breather holes in the wheels.
Drill two 5mm holes in each wheel, one 180 opposite the other
Old 02-10-2005, 02:41 PM   #4046
Forgot to say:
Thanks for the reply Nimo. Have you ever used the kyosho 92014 tyres and 92013 inserts ? What were your thoughts ? Thanks again.
Old 02-10-2005, 02:53 PM   #4047
Hi ernie!
The 92014 tyres ("V-Compound") are the standard-tyres for the kwc-expert-class. Try 30 Shore front and rear or 35 front and 30 rear. The V-Slicks are much better than the older 92902 ("Z-Compound" and last longer. Also there are 92141 around ("G-compound") which are intended for use on carpet but are also good on asphalt. The 92013 inserts are way to thin!
Regards
Robert
Robert-FW05 is offline   Reply With Quote
Old 02-10-2005, 03:02 PM   #4048
Originally posted by Robert-FW05
Hi ernie!
Regards
Robert
Thanks Robert-FW05 .What inserts would you use with the 92014 tyres. Thanks again.
Old 02-10-2005, 03:19 PM   #4049
Super Moderator
Marcos.J's Avatar
Forgot to say:
how are your lap times between the foam v/s rubber?
Old 02-10-2005, 03:38 PM   #4050
NiMo's Avatar
Tricky track this time of year so it's a lottery whether to use Foam or Rubber, but I have found Sorex 24 to be as good as Foam on cold tracks.
Last Sundays meeting I took FTQ, and in the 2-leg 5 minute sprint finals I got a clear win in leg 1, and a 2nd in Leg 2 to a Foam shod MTX3.
(meeting results - PDF files)
Heats Finals Overall
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
