Old 01-31-2005, 07:06 PM   #3901
Moderator
Clegg's Avatar
Thats what the rear ring looks like out of the 05R I bought used a few months ago
note the weight savings on this gear in the lower left, the previous owner seemed to have removed a tooth from the gear via some miracle of driving hehe.
Needless to say this gear is not going back in.
Since I am pricing out the steels. it seems a Kawahara center conversion costs just a tad more than 2 kyosho steel gear sets.
The gear that was in this car is a 40 front and rear for the ring, It was perfectly setup for the course I drive on in the summer. I am a bit worried that the Kawahara conversion would be a bit too much high end on the FDR than what I want for this course.
Its either that or I am going to buy 2 39 or 40 tooth steel ring gear sets.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 01-31-2005, 07:21 PM   #3902
jeffreylin's Avatar
R/C Tech Charter Subscriber
I'd sugget get 2 39T steel ring gears. They really free up the drivetrain and will last almost forever.
jeffreylin is offline   Reply With Quote
Old 01-31-2005, 07:25 PM   #3903
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
thats pretty worn!
Old 01-31-2005, 08:08 PM   #3904
rjl
rjl's Avatar
Originally posted by NiMo
There is more to consider than just the gear ratio.
The Kawahara runs much freer, and feels less overgeared than the 39T Kyosho rings.
Also an STS and a Rossi could not pull the Kawahara gearing, but the JP has so much torque it can still spin the wheels with a 21T 1st, and having such a long 1st gear makes running the infield much easier (check the videos on 3hobby.net)
I'm looking in to getting the grey clutch as this would hopefully give a smoother power take up making the car even easier to drive.
You also say anything more than 7 minutes is a cooked motor, well I've been doing 8/9 minutes since October and it's not cooked yet (and I'm running a Touring shell) so what am I doing wrong?
It's not necessarily wrong it's just that you can't make horsepower without burning fuel. Oh and you have a lack of air temperature in old blighty too.
rjl is offline   Reply With Quote
Old 01-31-2005, 08:17 PM   #3905
Moderator
Clegg's Avatar
Well amazingly 2 sets of them will be on their way to me tomorrow
Old 01-31-2005, 08:21 PM   #3906
jeffreylin's Avatar
Dang that is a fast reacting driver!
Old 01-31-2005, 10:46 PM   #3907
esham's Avatar
Mine both rear diff joint and rear center gear joint are worn. It not happen to the front diff joint cup and the front center gear cup. Probably too much torque / power to the rear for FW.
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 01-31-2005, 10:47 PM   #3908
esham's Avatar
the picture..
Old 01-31-2005, 10:52 PM   #3909
Moderator
Clegg's Avatar
I am guessing english isnt your native language?
From what I could make out from that (and your pic) is that the rear outdrives from the diff are wearing worse in the rear than the front.
its pretty common in nitro for that to happen due to the fact when you accelerate out of a corner, more weight is on the rear end, causing it to grip more, and less wheel spin. This makes the small bit of lash thats in the drive line there beat on the outdrives in power transitions more. The fronts spin much easier on power transitions and wear much less because of that. Theres also teh fact that the back of the car is covered in oil residue normally and this can cause dust and particles to stick to surfaces like the outdrives and help the dog bone pin wear on the outdrives easier.
You dont want to let too much wear build up, if you do, the lash in the drive line will build up and start to break dog bones, or teeth off gears (the sudden instant engagement caused by lots of lash is quite destructive)
Old 01-31-2005, 10:58 PM   #3910
InitialD's Avatar
Not only that... Handlng of the car will suck. The rear end of the car will "hop" and will bounce when accelerating out of the corners because the rear dogbones will bind and not move freely in lateral movement as a result of the dogbone pins getting trapped in the notches.
Old 01-31-2005, 11:28 PM   #3911
esham's Avatar
No, no it's not.
Got your point - Clegg and D, thank you and i do plan to replace those "outdrive".
Old 02-01-2005, 07:33 AM   #3912
NiMo's Avatar
Clegg: the standard Diff Ring Gears are made from softer cast steel, the upgrade items are made from machined steel.
The pitch pattern is smoother on the machined gear so the don't have to be meshed so tightly.
The Kawahara set up has moved the inner bearing closer to the diff so the meshing can be looser still, giving even more performance.
This is the front Kawahara diff after a good 50+ hours of running, (the rear looks similar) as you can see, very little wear, if any at all.
Also note the extra black plastic ring, that holds the larger inner bearing closer to the diff.
NiMo is offline   Reply With Quote
Old 02-01-2005, 08:30 AM   #3913
Super Moderator
Marcos.J's Avatar
Hey Nimo did the gears sound funny the first time you put them on?I check and double check the mesh and the mesh is good,let me know,
thanks
Old 02-01-2005, 08:50 AM   #3914
NiMo's Avatar
thanks
They do sound different, and you will notice it more if you brake heavy.
They sound like they don't mesh, but they don't half perform.
Old 02-01-2005, 09:03 AM   #3915
Super Moderator
Marcos.J's Avatar
thanks alot !
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
