Old 01-03-2004, 11:13 AM   #376
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally posted by coldeye
Are you by chance running at revelation in Ontario, Ca.? Thats where I first experienced our cars undergearing. It sounds like you have the right answer, will order my 39's.
Yes, I run at Revelation. I let my friend try the car and he thought it handled really good compared to his RR Evo. This car is seriously geared too low. The new track layout does help also.
You should adjust the tie rods for toe. They will pop off before they break.
Racing4Evo is offline   Reply With Quote
Old 01-04-2004, 08:46 PM   #377
Send a message via Skype™ to JordanC
Originally posted by jeffreylin
Did you adjust the front toe by lengthening the steering rods or did you screw in the pillow ball ends? Lengthing the steering rod might weaken the rods but screwing the pillow ball ends reduce the front track width...
I modified the steering arms to get the length i wanted with a 199 track width. Just used spacers.
JordanC is offline   Reply With Quote
Old 01-04-2004, 09:26 PM   #378
jeffreylin's Avatar
R/C Tech Charter Subscriber
So you kept the steering rod stock, screwed in the pillow ball screws, then put wheel spacer between the bearing and the wheel nut like the rear set up? Thanks.
jeffreylin is offline   Reply With Quote
Old 01-04-2004, 09:50 PM   #379
No, you would need shorter doggies to do that.... I unwound the ball ends on the steering arms, and made 1mm spacer to go between them.
Old 01-05-2004, 08:32 AM   #380
prawntoe's Avatar
Another big race (see the trophy it has to be big race) won by our very helpful *unofficial* kyosho track-side (and forum) support "staff".
Noneotherthan . . the one and only . . .(drumssss rolllllll). . .
Congrats to JoeHwee (FW05R) . .
updates : http://203.117.178.232/gallery
prawntoe is offline   Reply With Quote
Old 01-05-2004, 10:44 AM   #381
jeffreylin's Avatar
That's an interesting surface for the track. Is that a temporary or permanant track? Where is it in Singapore? Maybe I will stop by next time I visit.
Old 01-05-2004, 07:16 PM   #382
vones's Avatar
The racing track is actually a temporary track....it is of interlocking bricks n very high grip...it is situated in Malaysia, Johor Bahru.
vones is offline   Reply With Quote
Old 01-07-2004, 11:38 PM   #383
Looks good
Old 01-07-2004, 11:39 PM   #384
What are those rear tyres?
Old 01-07-2004, 11:39 PM   #385
Has anybody else found the car needs a softer rear spring?
Old 01-07-2004, 11:55 PM   #386
Joehwee's Avatar
JordanC: Those rear tyres on DoctorJ FW05R with orange wheel are GQ tyres, not too sure about the shore. I used 40 shore all round during the final, qualifying I used try both 35 and 37 shore, but they wear really fast especially the 35.
As for spring I usually run harder spring for the rear, so that my car will have more steering. For this race I was running Kyosho Red 4517 (front) and Blue 5317 (rear).
Joehwee is offline   Reply With Quote
Old 01-08-2004, 12:05 AM   #387
Haven't tried different springs yet. Thought the rears felt ok.
Old 01-08-2004, 12:06 AM   #388
was that motor an active?
Old 01-08-2004, 01:18 AM   #389
Racing4Evo's Avatar
On the Kyosho website where they give an overview of the "foam tire version" of the car they list the use of the rear Gold springs and the "long" black springs in the front which are basically the rear stock springs. I had already done this to my car with the exception of leaving the short black springs in the front. It helped out tremendously and I was running 42F/40R. The use of the longer front springs sounds like the hot ticket since they would inherently be softer than the shorter short blacks. I'm putting the car away for the time being until I can find a 22tooth pinion. I'm just not fast enough with the car with the stock gearing and 39t ring gears.
Old 01-08-2004, 03:07 AM   #390
You mean to actually try the rear springs on the front?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
