Old 01-30-2005, 01:46 AM   #3811
NiMo's Avatar
Originally posted by TRAJ
hi Guys
To those who have the FW05RR does the car come with any other carbon parts appart from the top deck?
Thanks in advance
No.
You can use the R rear shock tower, but you cannot use the R front tower.
The Carbon RR front shock tower was released from the factory earlier this week.
NiMo is offline   Reply With Quote
Old 01-30-2005, 01:57 AM   #3812
NiMo's Avatar
For those who may be interested, here is 3racing's home page for the FW05RR
3racing home page - FW05RR parts
Old 01-30-2005, 02:00 AM   #3813
TRAJ's Avatar
Thank You
TRAJ is offline   Reply With Quote
Old 01-30-2005, 03:23 AM   #3814
Has somebody experience with the 3racing supension pin set for the FW-05RR (FW05-RR003)? Good tolerances (exact diameter), smooth finish? Hardness compared to the stock ones?
What is the difference with SSG-Carbon compared to the normal Carbon except the silver look?
Thank you for your comments!
Regards
Robert
Robert-FW05 is offline   Reply With Quote
Old 01-30-2005, 03:46 AM   #3815
BrainTeased's Avatar
Regards
Robert
SSG parts are lighter
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-30-2005, 04:02 AM   #3816
Team-RTR's Avatar
but also have a bit more flex then then black graphite
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 01-30-2005, 04:11 AM   #3817
Yes, i think so. I googled abit and it says that it is normal carbon coated with aluminium fibers. Therefore it should'nt be lighter when used in the same dimensions? - So - is it only for the look (that i don't like btw)?
Old 01-30-2005, 05:13 AM   #3818
ttso's Avatar
SSG is mainly for UV protection. Graphite will deteriorate under UV. exposure. A layer of aluminium fiber will help to protect graphite from UV.
ttso is offline   Reply With Quote
Old 01-30-2005, 06:57 AM   #3819
InitialD's Avatar
Correct me if I'm wrong... SSG is softer and more flexible and they are always slightly thicker than their normal CF counterparts.
Old 01-30-2005, 07:02 AM   #3820
uaerc's Avatar
hi Guys
Thanks in advance
Hey Traj
No..
uaerc is offline   Reply With Quote
Old 01-30-2005, 07:21 AM   #3821
uaerc's Avatar
If this is the case, the carbon parts are usually under the hood while in the sun so there wont be a major problem with the UV deterioration, moreover it might break earlier than getting damaged by the UV..
If SSG is softer or flexible as the guys said, I wouldnt want to compromise strenght for looks !
pposted by Robert////
Nothing to be curious about. I think your weight is quite normal. Taking into consideration that your foams should weight less than my rubber-tires it will be ok. Maybe you are using a oneway which saves up another 19 grams (page 22 on this thread). At least nimo's car seems to be some kind of heavy.
Robert
As i said earlier i didnt weigh my car since i bought it back in sept. 04, only when u guys were talking that i thought of doing so...... as i wanted to find out how much did my car weigh !!
I am using Kyosho rubbers,inners &wheels. I am on stock so no front one way.....Front one way comes stock with the hop up version of fw05r which comes with a carbon top and sp chassis aswell.
But hey as Nimo said
"""Doesn't it feel good to beat the other racers with a car that's a good 100g+ overweight """
Which is quite true...... infact the wieght might be just giving you the grip !!
Old 01-30-2005, 07:43 AM   #3822
impalabob64's Avatar
Send a message via AIM to impalabob64
Default 100g+overweight
impalabob here i 2nd that also, raced at my body marcos,s club track in lakeland ,the thing was on rails i was running 39t frt 40t rear with a modded ns3 race wicked fast .Yesterday dropped a modded mugen x12.2 times as fast as my ns3.waiting for the 38t anyone know if it is out yet.go to try 38t frt 39t.here is my gearing 22/50 27/45 with the x12 the car keeps on pulling.tires 61mm frt 63 rear im using josh cyrul toledo setup.With frt diff 100,000 30,000rear.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 01-30-2005, 07:52 AM   #3823
Default ps
sorry ,forgot to say hi , to everyone sup D how is everything fwo is abit quicker then my 710, hit 17.0 at lakeland an was running against serpent ,an mugen cars which i know was alot heavier than the were ,the fwo is quickest car i,ve driven.
RoninRc.com
Basher BT-4
Old 01-30-2005, 07:53 AM   #3824
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: 100g+overweight
hey Bobby dont give away all of the secrets!
Old 01-30-2005, 07:54 AM   #3825
Super Moderator
Marcos.J's Avatar
Default Re: ps
i told you so! now you know why i changed 9 months ago
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
