Old 01-23-2005, 05:48 AM   #3751
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by cow buster
Anyone have problem with the throttle servos? there seem to be a lot of em' burning up at our track. The guys experiencing this are using sanwa radios.
Nimo, have you got that problem?
Whether it is digital or analogue it burns. I personally have not burn one yet (hope not anyway) and I was previously using a futaba radio with futaba servos. Just changed to a sanwa radio M8. Any advise is much appreciated
I've had a lot of problems with the FW05R throttle servo. I've had 3 gone bad and I suspect it's because of the heat from the engine. All happened during long mains in hot weather. I've had any problems with the steering servo nor throttle servo on my RRR.
jeffreylin is offline   Reply With Quote
Old 01-23-2005, 06:26 AM   #3752
InitialD's Avatar
To Uncle Cow, time to go for a belt car !
Old 01-23-2005, 06:29 AM   #3753
InitialD's Avatar
Are you sure? If there's anything to go by, the analogue ones would last better than digital...
The old school of thought : Analogue servos for throttle, digital servos for steering
Old 01-23-2005, 06:30 AM   #3754
InitialD's Avatar
Perhaps it's the angle and the way the throttle servo is installed on the FW05R gives a lot of strain to the servo...
Old 01-23-2005, 07:36 AM   #3755
ziggy12345's Avatar
Originally posted by SlayerFan
Nobody has the manual for the ZT-1 conversion kit???
NiMo built one so should have a manual. Hes not back from the track until later
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 01-23-2005, 12:31 PM   #3756
NiMo's Avatar
I did have that once.
I placed an extra o ring under each screw and left it so it had a little movement, also I put a 5mm piece of full tube on the full open side of the throttle linkage to prevent the motor in the servo fighting something solid.
latest servo (KO) has been in there since Feb.
NiMo is offline   Reply With Quote
Old 01-23-2005, 12:35 PM   #3757
NiMo's Avatar
Cheers
I think I have a version in English in the back of the van, give me a day or so and I'll try to scan it.
(Monday/Tuesday busy at work)
Old 01-23-2005, 01:37 PM   #3758
SlayerFan's Avatar
Thanks ziggy and NiMo. Good, at least someone has it!!
SlayerFan is offline   Reply With Quote
Old 01-23-2005, 04:50 PM   #3759
Thanks nimo. Will try the o ring. Don't quite understand the throttle linkage part. I have a piece of fuel tube at the end of the brake linkage, the throttle linkage is much shorter, so if you say put a fuel tube there, it would be after the spring right?
cow buster is offline   Reply With Quote
Old 01-23-2005, 06:58 PM   #3760
BundyMan's Avatar
You place the o-rings between the servo and the upper deck. This will also raise the servo's height marginally and prevent it from touching the chassis plate (hot).
BundyMan is offline   Reply With Quote
Old 01-24-2005, 12:36 AM   #3761
BundyMan's Avatar
Default Ackerman
I saw the the kawahara carbon steering plate option and there are these small holes (ackerman?). How to utilise these holes?
Old 01-24-2005, 02:48 AM   #3762
BrainTeased's Avatar
very good idea!
i never had a prob with any slide carbs but my new sirio seems very hard to pull out at the very end!
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-24-2005, 05:24 AM   #3763
spawn's Avatar
Default Re: Ackerman
the holes towards the front of the car will make the steering more aggresive i.e. more steering during mid and corner exit.
spawn is offline   Reply With Quote
Old 01-24-2005, 10:15 AM   #3764
NiMo's Avatar
Other side from the spring, on the stopper side
Old 01-24-2005, 06:02 PM   #3765
TQ
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
