Old 01-18-2005, 04:34 AM   #3646
uaerc's Avatar
Thumbs up
Brain teased..
Thanks.....
Just a quick qs.. The 1st and 2nd gears I just saw on the net for the fwo5R are 24 and 28 1st and 2nd.....
Now these two gears would make the car fly on the Kaw. conver.
dont you think..
Cheer
ZiiZo.....
Ps nice avatar!
uaerc is offline   Reply With Quote
Old 01-18-2005, 04:53 AM   #3647
BrainTeased's Avatar
yea that i believe you'll never run out of gearing unless your on an airport strip!!!
how big is your track although i have never raced on big tracks only at my local club.
but i believe 22/50 27/45 is more than enough with karahara gears.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 01-18-2005, 05:19 AM   #3648
rice's Avatar
Originally posted by uaerc
Brain teased..
Thanks.....
dont you think..
Cheer
ZiiZo.....
Ps nice avatar!
just dont 4get to put on a parachute.
rice is offline   Reply With Quote
Old 01-18-2005, 06:00 AM   #3649
rjl
rjl's Avatar
I find 27z second is overgeared with the Kawahara conversion, lots of heat and no revs.
rjl is offline   Reply With Quote
Old 01-18-2005, 06:24 AM   #3650
ziggy12345's Avatar
20 26 is about the best combo for the conversion as long as you have a short pipe
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 01-18-2005, 07:34 AM   #3651
NiMo's Avatar
Running with a JP FX T03 (5.5mm carb) with Kyosho VSW024 one piece pipe (5.2mm), 16% fuel and Kawahara 45 Diff rings I can happily pull 21/50 26/45 (2nd only gets used on main straight).
With this set up I can get 8/9 minute tank runs, and the get up and go factor even has top UK drivers Darren Johnson, Chris Grainger and Samantha Barnard using my car as a performance gauge to judge their cars performance by.
NiMo is offline   Reply With Quote
Old 01-18-2005, 08:07 AM   #3652
InitialD's Avatar
No mention of Mark Green?
Old 01-18-2005, 08:19 AM   #3653
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Cheers
you got pm
Old 01-18-2005, 08:32 AM   #3654
NiMo's Avatar
That's easy to answer, I've only met him once since his return from Brazil, and I didn't have the car with me then.
(I had to do some work in the race control hut)
I did however find out some facts about the worlds, and in my opinion it shouldn't have run as the Customs thing was a total farce (Serpents tyres are still in Brazil Customs).
Old 01-18-2005, 08:40 AM   #3655
Super Moderator
Marcos.J's Avatar
Hey Nimo im in the process of getting the center conversion , do you shim them the same way as the stock ring gears?Is the Kawahara version less drag?Right now Im running 39 ring gears with 21/51 and 27/45 for second.
Old 01-18-2005, 09:58 AM   #3656
NiMo's Avatar
The Diff unit is shimed the same way, but the input shaft/small bevel has a new bearing holder that holds the inner bearing closer to the diff ring which reduces the flex in the input shaft, so in effect, more efficient drive train.
You will however have to drill a little hole for a grub screw in the Diff housing assebly, all is shown in the supplied diagrams.
Old 01-18-2005, 10:40 AM   #3657
Super Moderator
Marcos.J's Avatar
thanks, is the conversion better than the 37 ring gears?
Old 01-18-2005, 10:56 AM   #3658
NiMo's Avatar
37T was not around when I fitted the Kawahara kit.
Now there's the 38T.
Kawahara gears still show no wear.
Old 01-18-2005, 11:08 AM   #3659
Super Moderator
Marcos.J's Avatar
thanks alot !! is the Kawahara is a different pitch?
Old 01-18-2005, 11:15 AM   #3660
NiMo's Avatar
0.8 pitch, finer than Kyosho pitch.
Here's a picture of my Kawahara front diff, must be getting on to a year old, and still no wear.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
