Kyosho FW-05R
#3631
get the FW05-S
you can upgrade it to a pro car later on as ppl have mentioned
the v one S is a great begginer car and only that
the FW05S has the potential to become a race machine!
#3632
Originally posted by Marcos.J
hey ziggy i still wanted im just trying to sneak the money out of the bank with out my wife noticing ,
Cheers
#3634
Just added the RR conversion kit. Looks much nicer, particularly on the front end.
Noticed that you need to put alot of spacers in to use the inner holes on the new front shock tower.
Does anyone know what the difference is between the VZ004C and the conversion kits VZ004H? All the holes seem to be in the same spots, so I dont know why they are included.
For the cost, Kyosho could have included a FW-05RR sticker set!
#3635
Now before I found out about buying overseas I had to use the hopeless UK importer, which used to take me 4/5 months to supply a part, and for just a single Carbon Top Deck for a V-one R cost me £85.
#3636
Hi Nimo
Would you know the link to calulate the percentage of diff silicones need to be put to reach certain thickness of oil.
I had a link from the http://www.gesilicones.com/ but now i cant seem to find..
Actually the reason i need this is that i want to change the diff oil in my fw to 10k in the front and 5 k in the back.
The only available oils are 30k and 1k
this calculator will tell you how much parts of 30 and 1k you need to mix to get 10 k ...
cheers
ziizo
cheers
ziizo
#3637
Originally posted by uaerc
Hi Nimo
cheers
ziizo
Hi Nimo
cheers
ziizo
Try here for oils : Diff and Shock Oils
#3638
Nimo
Thanks for that.. I have already ordered from there ......
found the link... fluid finder
http://www.gesilicones.com/silicones.../default.shtml
Cheers
ZiiZo
Cheers
ZiiZo
#3639
#3640
Hi Empty..
I just converted my Fwo5 to the RR... Parts nos which come in the conversion kit..
VS023 SWING SHAFT
VSO37 FRONT UPPER BRACKET
VS038 FRONT UPPER SUS. SHAFT
VS039 CARBON DECK
VZ004C REAR SUS ARM SET - not the vz004ch you said.
VZ 013 WHEEL SHAFT
VZ 201 & 202 - FRONT AND REAR HUBS
Hope this clarifies...
Also, just check the setting data sheet.... the drawings show hole 1 but the sheets shows hole no.. 2 - front shock tower
and hole no. 3 in the rear shock tower
I think they just used the drawings not the actuals printed there..
Cheers
ZiiZo
VS023 SWING SHAFT
VS039 CARBON DECK
VZ 013 WHEEL SHAFT
Cheers
ZiiZo
#3641
Thanks uaerc,
With the conversion kits new front shock tower, if you connect the front shocks to the innermost holes, hole #1, the spring pre tension ring rubs on the shock tower, near the lower screw. I have put about 5mm of spacers in to move the shock away from the tower. Did you need to do this as well?
#3642
Thanks uaerc,
Thanks uaerc,
I am using the 2nd hole in the front shock as mentioned in the setupguide..i noticed what u said about the first hole as in the second hole the shock is mm away from the tower... why dont u just try the 2nd hole as said and later on make the move , if it doesnt suit your style.....usually i am happy with the stock setup sheet that comes with the kit....till i get racing where in our case we have to use softer springs and lighter weights oils front one way's are a no no here....i am using the softer silver springs with a lot of camber and toe in at the rear...and normal blacks in the front.. as we have a highly slippery track....
The local champ here was very impressed with my ride and adviced me to use the 10k up in the front diff. and 5k in the rear.... with even softer springs and approx..6- 7mm ride heights.... and he is quite good with that setup......
cheers
ZiiZo
#3643
New Parts coming soon
No.VSW038
64 titanium front upper suspension shaft ¥1,365 (including tax) The next few days sale
With the adoption of the light weight high rigid titanium material, it actualizes the light weight conversion of the chassis and contributes to the improvement of travelling efficiency.
* FW-05 RR exclusive use.
No.VSW043
3D ライトウェイトフライホイル (33mm/VS029) ¥2,100 (including tax) The next few days sale
While guaranteeing rigidity, the aluminum make lightweight fly foil which administers meat pulling out processing as much as possible.
Actualizing the pickup where the machine is sharp with the decrease of gyrating mass. You lighten also the burden to the engine.
* For FW-05R/RR.
* VS029 correspondence.
No.VSW045
Steel bevel gear set (38T) ¥3,990 (including tax) The next few days sale
With the adoption of the steel material, you are proud of preponderant durability. It is superior in abrasion resistance in comparison with standard.
* FW-05S/R/RR
No.VSW043
* For FW-05R/RR.
No.VSW045
* FW-05S/R/RR
#3644
Kawahara center conve..
Hi Nimo
Just need to clarify something ........
THe centre conversion from karwahara has 39T gears or 37T ?
Second if i used this set.........
would it be faster then the 37T Kyosho gears given that the gearing is 1st 22/50, 2nd 27/45.
cheers
ZiiZo
cheers
ZiiZo
