Old 01-07-2005, 08:08 PM   #3571
Default Rear diff
Originally posted by NiMo
I'm going to try something different this weekend.
I'm always looking for more power on steering, and reading throught various forum sites they seem to suggest a solid front diff will give more power on steering, so that is what I've done (using the RRR spool).
Will post results of test on Monday.
I have been told that you need to change the rear diff oil to compensate for the constant drive from the front.
If I remember correctly you need to stiffen considerably.
Interested to see your report
opposite lock is offline   Reply With Quote
Old 01-08-2005, 02:02 AM   #3572
NiMo's Avatar
Default Re: Rear diff
I've always run constant drive, just trying a solid front axle.
I'm told it reduces turn in, but gives more power on steering.
NiMo is offline   Reply With Quote
Old 01-08-2005, 11:26 AM   #3573
NiMo's Avatar
I managed to get some track time today before the light went (3 tanks).
Tank 1:
car felt strange and took most of the tank to understand what was going on, but by the end of the tank the car was flying although the rear was feeling loose, turn in was great and power on was better.
Tank 2:
removed the rear roll bar, car felt good, loads of turn in, good power on from hairpins (if not a little too much), power on through the sweeper was better but still lacking, braking was great and in a straight line, rear got loose towards end of run.
Checking car after tank ran dry I found the rear tyres 2mm smaller than the front, and one rear only had 1mm of foam left and the plastic wheel had been scraping the track (remember I run constant drive).
Tank 3:
New tyres fitted, rear end planted, front end turn in very quick and direction change through chicane quick and predictable. Car ran the bumps like they don't exist. Found I can hit the power much harder with no rear end kick, but still found I'm wanting more on the left turn sweeper.
On returning to the pits I realised I had not reset the ride height for new tyres, the last tank was done with a huge ride height of 9.5mm up front and 8.5 at rear, yet the car felt great.
The solid front axle does give more steering, both on and off power, would be a must for tight car park tracks, and you can run without a rear roll bar for more rear end grip.
Now for tomorrows test in race conditions.
Old 01-09-2005, 05:28 AM   #3574
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
Send a message via AIM to kyoshoBOY
Smile FW05R and not switching to any!
Hey peter this is dennis running an fw05r,hope u still remember me.anyways just wundrin if u still running an fw,its been long time I havnt played since RDlogics champ.,I planning on goin back again and run my fw and convert it to RR,I've heard that a lot of guys are runnin an rrr and mongoose and they said its a great car,I still believe on my FW and I will work on it till I got the best set up.well I guess ill see u sumtyms in revelation,what is the best body for the FW to use ryt now?
kyoshoBOY is offline   Reply With Quote
Old 01-09-2005, 02:56 PM   #3575
Hi ,
I am from Greece and very new to this excellent hobby!
I just bought an Fw05 T but a cant find any info on the web about this version not even in official Kyosho site only about S,R and V one series. My Local dealer said that are very minnor differences between versions!!!
Does any one knows why is that happens is this a very new model or something else?
Where can find the differenses between this versions?
Can I buy optional parts from S,R, or V-One and fit them to my FW05-T?
The car is aswome on the track very fast and lot of fun to drive BUT the others are faster
Thanks in advance for reading..
Kostas
Athens Greece
kkot is offline   Reply With Quote
Old 01-09-2005, 03:04 PM   #3576
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Default Re: FW05R and not switching to any!
Good luck!!
Walter Diaz
wad is offline   Reply With Quote
Old 01-09-2005, 03:29 PM   #3577
NiMo's Avatar
Originally posted by kkot
Hi ,
Kostas
Athens Greece
The FW05T is the base model RTR car, but you haven't wasted your money as it can be upgraded fully to the FW05RR or to any stage in between.
FW05T comes with plastic central shafts and a solid spool in the front diff housing, but the diff housing and central driveshaft lengths are the same as the S/R/RR range.
Old 01-09-2005, 04:45 PM   #3578
Smile team RC Industria!!!!
Hey walter dis is dennis!!wat're u doin here on fw05r forum?aniweys,too bad it rains last sat,I was ready to practice,well ill try dis wikend again.
Old 01-09-2005, 04:52 PM   #3579
Old 01-09-2005, 05:13 PM   #3580
wad
wad's Avatar
Default Re: team RC Industria!!!!
Where is your signature??
Walter Diaz
Old 01-09-2005, 05:43 PM   #3581
What is the new and best body to use ryt now?
Old 01-09-2005, 05:55 PM   #3582
wad
wad's Avatar
If you want to make your car to work, you know what you need
Anyway, try the Mazda 6
Walter Diaz
Old 01-09-2005, 06:00 PM   #3583
dct147's Avatar
Hello all.
Like some opinions of V1 RR evo and the FW05R.
In comparison of quality and handling, basically which of the 2 would be a preferred choice?
I`m new to this hobby and thinking of getting either 1 of them.
Can anyone advice?
Thanks!
Cheers
dct147 is offline   Reply With Quote
Old 01-09-2005, 06:21 PM   #3584
Mazda 6 again,is der a new one?I already used dis 1 last rd logc champ.well I just look for some I guess and try,walter r u runnin dis wikend?
Old 01-09-2005, 06:27 PM   #3585
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
