Like Tree2Likes
Kyosho FW-05R
Old 01-04-2005, 11:07 AM
  #3541
uaerc's Avatar
Default Alain
I think most of the guys are doing a mistake by taking the RR conversion like me ....why... !!
Well... the most important thing is that front shock stay which is completely different and not available in the market from even the aftermarket guys and which if broken you dont have any more replacements ?? I heard its still under production and not readlly available.
I would suggest that for guys who are not having parts in hand and live far off places like me... to do the following.. .
if not converting....
change the upper deck to CF
change the front and rear hubs to RRR , till such time the front stay is avial.
i dont know how many of the guys use the different holes in the front shock stay but the manual of rr still says to use hole no. 1 but if you are not the setup freak sort then i think you can do the above and live with it.
Honestly i got the rr kit and liked it a lot but the track i have it has to break something or the other which scares the sh#$ out of me coz no parts so i am still on the R. till my LHS has the parts
But hey there is no harm in getting it get it use it and if something breaks and no parts you can always go back to the R !
Just my opinion.....as i almost experienced it.
I got it from Japan aswell email in my earlier post.
Cheers
ZiiZ - 0
uaerc is offline
Old 01-04-2005, 06:20 PM
  #3542
BundyMan's Avatar
I think the most crucial part of the RR conversion is the new upper bulk head and shock tower. You could adjust the front RC with the new conversion kit, and also have more set up options, which after trying it, does make a difference when you are entering/exiting a corner.
I dont think the shock tower will break unless you have a massive crash. But then again, I dont think it will be long before companies like 3racing come out with some aluminium stuff
BundyMan is offline
Old 01-05-2005, 05:11 AM
  #3543
NiMo's Avatar
Default Re: Alain
Cheers
ZiiZ - 0
RR Shock Tower set
NiMo is offline
Old 01-05-2005, 06:22 AM
  #3544
esham's Avatar
Default Re: Re: Alain
Originally posted by NiMo
RR Shock Tower set
You are fast ...
esham is offline
Old 01-05-2005, 07:12 AM
  #3545
uaerc's Avatar
Wink Re: Re: Re: Alain
Originally posted by esham
You are fast ...
Yes He sure is.....
Look what the site said....
This product was added to our catalog on Wednesday 05 January, 2005.
Thanks Nimo I just ordered a few ~
The brake pads you were talking about in the earlier post where can i get those.......so i can order from the same site.
cheers
ZiiZ-o
Ps how do you keep track man...... ??
uaerc is offline
Old 01-05-2005, 08:24 AM
  #3546
NiMo's Avatar
Default Re: Re: Re: Re: Alain
Yes He sure is.....
cheers
ZiiZ-o
Here's a clue: UK time is 15:24
NiMo is offline
Old 01-05-2005, 08:27 AM
  #3547
NiMo's Avatar
Different place for the brake pads
Brake Pads
NiMo is offline
Old 01-05-2005, 02:25 PM
  #3548
Super Moderator
Marcos.J's Avatar
Trader Rating: 201 (100%+)
Default bumper
this is what i installed for more front end protection.
Marcos.J is offline
Old 01-05-2005, 03:10 PM
  #3549
NiMo's Avatar
I used to run a full width bumper but found the ends were prone to bending down with only the slightest of knocks, and once down would scrape on the ground and take away my steering, shame really as with the wide bumper I actually had more front end grip as it gave a better under car air flow.
NiMo is offline
Old 01-05-2005, 03:16 PM
  #3550
Super Moderator
Marcos.J's Avatar
it has worked good so far i guess time will tell
Marcos.J is offline
Old 01-05-2005, 03:23 PM
  #3551
NiMo's Avatar
Do you have grass edges to your tracks? that is what caused my problems with it.
NiMo is offline
Old 01-05-2005, 03:30 PM
  #3552
Super Moderator
Marcos.J's Avatar
no grass edges ,there is only one track with grass edges but i havent raced at thet track yet
Marcos.J is offline
Old 01-05-2005, 03:44 PM
  #3553
NiMo's Avatar
Here's my local track, as you can see, grass edges (and kerbs on the chicane)
NiMo is offline
Old 01-05-2005, 03:46 PM
  #3554
Sow&Steady's Avatar
And if you go here you can download videos from this track. You might even get a glimpse of NiMo's car going very hear the grass edges as well as the kerbs.
Sow&Steady is offline
Old 01-05-2005, 03:52 PM
  #3555
NiMo's Avatar
It's what's called 'using the full width of the track'
NiMo is offline
