Old 12-29-2004, 03:29 AM   #3526
BrainTeased's Avatar
racing4evo's trick works perfectly but if your in a rush you could still do it by turning your car upside down on your lap and move the gears till you see that hole on an angle then move your front wheels till you see the 2mm hex head. its also much easier to fit in a 2mm allen key rather than a hudy wrench. but either tools will work.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 12-29-2004, 03:36 AM   #3527
There is a good indication for the position when the screw is at about the right position: the pins of the brake-disc-holder align with the shaft of the screw-driver.
Best regards
Robert
Robert-FW05 is offline   Reply With Quote
Old 12-29-2004, 06:37 AM   #3528
uaerc's Avatar
Originally posted by BrainTeased
dont get the hyper head they cost like 40-50 USD
i got the 11 fin carlson head from rc mart they are half the price 21 USD.
Hi
Cant seem to find it on RC MART... found on rcmodel.hk but if you dont mind can you give me the link for this for the OS TR T engien....
Cheers
ZiiZ
uaerc is offline   Reply With Quote
Old 12-29-2004, 06:54 AM   #3529
TRAJ's Avatar
http://www.rcmart.com/catalog/produc...oducts_id=5268
there it is
TRAJ is offline   Reply With Quote
Old 12-29-2004, 08:12 AM   #3530
NiMo's Avatar
Same trick as me, also same method used for adjusting clutch.
I have found the 2mm hex a pain to get in the slot, but have found an American A/F size hex a little smaller than the 2mm that finds the slot first time.
NiMo is offline   Reply With Quote
Old 12-29-2004, 12:53 PM   #3531
Default access
Perhaps Kyosho should put a little hair around it!!!!!!
Originally posted by 3434
How are you guys adjusting your two speed? I have an FW05T and there doesn't seem to be any access to the adjusting screws unless I remove the radio tray or the engine.
opposite lock is offline   Reply With Quote
Old 12-29-2004, 07:42 PM   #3532
opposite,
It might have hair around it you just can't get to it. Its more like I haven't got the pants off yet. lol Looks like I have to tear the car apart to ajust it.
3434 is offline   Reply With Quote
Old 12-29-2004, 07:58 PM   #3533
Default 3434
I have the fw05r and even though it is in a difficult position and size,you can still adjust it.
You need good light so you can spot the hex screw spot on.
Old 12-30-2004, 03:30 AM   #3534
Taylor-Racing's Avatar
Old people with poor vision like me usually put a dab of white paint on the hex head.
Taylor-Racing is offline   Reply With Quote
Old 12-30-2004, 04:13 AM   #3535
If I only had access to the hole. Once I get access to that then I will see how tough the screw is to find.
Old 12-31-2004, 07:34 AM   #3536
Like what was said above, flip it over and adjust from below.
HKmaxx is offline   Reply With Quote
Old 01-02-2005, 08:23 AM   #3537
uaerc's Avatar
Hi
has anyone driven the RR yet. any reports updates etc ??
Regards
Aziz
Old 01-02-2005, 06:26 PM   #3538
BundyMan's Avatar
Drove it during the race yesterday. Didnt have time to set it up properly, luckily there were 5 heats and manage to tweak it between heats, manage to set my fastest lap during the last heat. The car has a lot more grip and feel stiffer (due to the CF upper deck?). I had to replace the front springs from black to green (kyosho option springs) and replace the rear springs from yellow to blue. I am currently using 3k oil for the rear diff, will try 5k since there is so much traction.
This helps the minimize the push when exiting from corners. The car definitely feels more stable and more nimble with the conversion kit and saves about 18g of weight.
Rgds
BundyMan is offline   Reply With Quote
Old 01-03-2005, 05:45 PM   #3539
Trader Rating: 15 (100%+)
Default fw-05rr conv. kit
Hi, do you know if he have somes dealers in north america where i can buy the FW-05rr conversion kit, I'm from Canada, thank you.
Alain
1/10 Durango DEX 410 V3
Alain Patry is offline   Reply With Quote
Old 01-04-2005, 07:37 AM   #3540
NiMo's Avatar
Default Re: fw-05rr conv. kit
Alain
I got mine direct from Japan
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
