Old 12-03-2004, 10:00 AM   #3421
NiMo's Avatar
Originally posted by franknitty69
does the conversion kit come with front upper and lower arms?
what about the rear lower arms?
when i look at the picture i only see one pair of arms (can't tell if they are front or rear).
Only rear upper and lower
NiMo is offline   Reply With Quote
Old 12-03-2004, 01:23 PM   #3422
[QUOTE]Originally posted by NiMo
[B]Pictures curtesy of my good buddies at 3hobby.com
Car came straight from a wet test day session at Aldershot.
Hey Nimo proof of those beautiful UK seasons-sudafed and
some other form of flu drugs in background of photos [priceless]
Are you using the 05r off road?????? Those pics show some serious grit.
Just kidding!
opposite lock is offline   Reply With Quote
Old 12-03-2004, 01:44 PM   #3423
NiMo's Avatar
[QUOTE]Originally posted by opposite lock
[B]
Just kidding!
You should've seen the water splash whenever I slid on to the grass/mud, not even D20 wets work properly this time of year, just hope it warms a little for the race this Sunday.
Now you know why Mark Green was able to do so well in the wet at the Worlds.
Old 12-03-2004, 01:58 PM   #3424
Now you know why Mark Green was able to do so well in the wet at the Worlds. [/B][/QUOTE]
I have a new 05r with a few goodies arriving this week.
I will post some pics ig I can work out how to do it.
Any tips??????????????Thanks
Old 12-03-2004, 02:04 PM   #3425
NiMo's Avatar
Any tips??????????????Thanks [/B][/QUOTE]
take your time with the shimming of the diffs, or if you can get them, get the upgraded steel diffs, they dont have to be shimmed as tight.
I have been running on a few different size tracks and have found the Kawahara diffs to work at all of them with my JP motor, so you may want to get the 37T diffs.
Old 12-03-2004, 02:11 PM   #3426
I have been running on a few different size tracks and have found the Kawahara diffs to work at all of them with my JP motor, so you may want to get the 37T diffs. [/B][/QUOTE]
I have gone for the 39 t rings with front one way and 45,46t
and 50,51t spurs with 20,21.22t and 25,26,27t pinions,
So I have a few options there.
Old 12-03-2004, 02:21 PM   #3427
Default Weight transfer
Hey NiMo,
I like the idea of moving the battery forward as I always had trouble with on power understeer.
More forward weight will certainly help.
Any other setup ideas?
Old 12-03-2004, 03:06 PM   #3428
BrainTeased's Avatar
opposite lock : you run at dandynong yea?
also why do people use one piece engine mounts?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 12-03-2004, 03:12 PM   #3429
NiMo's Avatar
Default Re: Weight transfer
Hey NiMo,
Not sure if my set ups would help you as most of the time I have to run on Rubber or wets due to our cold wet climate
(that's why we love those sexy brown Californian girls)
Since I started running the Protoform MG ZS I have been able to soften the car up, I now use the soft Kyosho Spider Mk2 springs with 35wt shock oil. the car has plenty of body roll but it feels so predictable that I can go faster with it.
I moved the battery pack forward as I found the car had more power on understeer turning left than it does turning right which would lose me precious 10ths on the infield at my local track, so I'm hoping this will give me some steering back.
I got the idea from the forum talk about the RRR, which has the battery a little more forward than most other cars, and a good inch forward over earlier V-one models (which may be why it didn't grip roll like other cars).
Old 12-03-2004, 03:27 PM   #3430
NiMo's Avatar
Why not?
My way of thinking is:
if I can get more heat away from the motor then I can run it leaner for longer therefore using less fuel as well as a little more power.
The one piece mount is not only larger, it spreads the heat over a larger area.
Buit there again I could be talking absolute crap
Old 12-03-2004, 05:41 PM   #3431
Default 05r
No I am in Sydney
Old 12-03-2004, 06:22 PM   #3432
Why not?
AHHH! thanks for the tip NiMo now i know why people use 1 piece engine mounts ill have to get one myself!
Old 12-03-2004, 09:04 PM   #3433
jeffreylin's Avatar
R/C Tech Charter Subscriber
It also stiffen the chassis a little. Probably has a bigger effect on the RRR than the FW05R.
jeffreylin is offline   Reply With Quote
Old 12-04-2004, 05:56 AM   #3434
ohhh ok
Old 12-04-2004, 03:33 PM   #3435
Hi!
I need some advise to improve the rigity of my car. While the only parts i broke are the rear lower arms, i often bend the rear hinge-pins (original part-no. vz-18). There are some extra-hard hinge-pins aroung, as well as the titanium-ones made by kyosho. Which ones are the most rigid ones?
Also i need a hint where to buy the steel ring gears at a reasonable price.
Thank you!
Robert
Robert-FW05 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
