Old 11-20-2004, 11:37 PM   #3376
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I am not worried about that. i just wanteed to have an idea of the total amount so I could save up for it.
Racing4Evo is offline   Reply With Quote
Old 11-22-2004, 09:20 AM   #3377
ttso's Avatar
http://www.pro-s-futaba.co.jp/newitem.htm
The page is updated with preorder info of FW-05RR kit, and ESTIMATED RELEASE DATE.
I know someone must trying to find the JP-EN translator, try this: http://world.altavista.com/
ttso is offline   Reply With Quote
Old 11-22-2004, 09:42 AM   #3378
NiMo's Avatar
That's the one I use
NiMo is offline   Reply With Quote
Old 11-22-2004, 07:19 PM   #3379
BundyMan's Avatar
Great stuff NImo..
Rgds
BundyMan is offline   Reply With Quote
Old 11-24-2004, 06:15 AM   #3380
TRAJ's Avatar
Default Re: Price for the FW-05 RR and conversion kit
Originally posted by Masa
Here is our price for the RR and Conversion kit. If you guys are interesting to preorder this, please mail to [email protected]
FW-05RR Coversion kit Discount price 4704Yen
FW-05RR chassis kit Form tyre version Discount price 29400Yen
With OS 12TR(P)T 45500Yen.
RC Adviser Champ
Masa
when i converted the price into US dollars it was US$45.70 from MASA's quote of 4704 Yen
but Futaba pro has it different!?!? what is the correct price on the conversion kit??
TRAJ is offline   Reply With Quote
Old 11-25-2004, 03:50 AM   #3381
Shop Owner
Default About conversion kit
For our price, it is same price as I said. I don't know about Proshop Futaba. If you have any question, please let's me know.
Masa
Masa is offline   Reply With Quote
Old 11-25-2004, 04:44 AM   #3382
esham's Avatar
Default Advantages
Sorry guys, I missed this.
Any advantage to convert the FW05R to FW05RR ? I checked Josh comment at CEFX but i didn't get any pro cons comparison between the R and RR handling much. Any input guys..
Thank you
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 11-25-2004, 01:05 PM   #3383
Trader Rating: 43 (100%+)
Default Pipe for FW-05R / Fw-05RR
Here is the pipe you will like for fw-05R and Fw-05RR
http://www.skylinercracing.com/store/P_35.htm
monokenny is offline   Reply With Quote
Old 11-29-2004, 04:28 AM   #3384
BrainTeased's Avatar
Hi guys i was wondering how often do you guys replace your fuel tanks? and fuel line
also guys who are running the RRR rear hubs and foams what rear camber are you guys running? im running +4 degrees seems to give an even tyre wear surface.
also last weekend i decided to change my front and rear bulk heads as the screws that screw on the top deck couldnt be tighten anymore
with the bulk head sets it included the blocks so i changed them to. but with the rear theres 2 sets of blocks
one says H and one says L
is this the rear roll center thingy? if so what does H do and what does L do?
thanks in advance guys and are you guys still running your FW's or have you neglected them for your new 3R's
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 11-29-2004, 02:21 PM   #3385
Racing4Evo's Avatar
Use as much camber as necessary to get a slight inward cone on your tires. I am using 3.5 deg.
The H rear arm holder raises the roll center and decreases rear traction. The "L" lowers the roll center for more rear traction. I use the L most of the time so I can get away with less rear toe.
I will be going back to my FW-05R in a little bit since it works so good on high traction days.
Old 11-29-2004, 04:29 PM   #3386
NiMo's Avatar
I've been doing it wrong for the last 15 months then, I've been running L front and H rear, never had an issue with rear grip, in fact I have too much.
Old 11-29-2004, 06:02 PM   #3387
Racing4Evo's Avatar
I knew a few guys that did that and the other war around. I would love to have as much grip as you. Must be those rubber tires!
Old 11-30-2004, 02:22 AM   #3388
thanks racing4evo, my rear traction is fine at the moment as well but will change the blocks to see the differences, like racing4evo i may get away with less rear toe!
do you guys use much of your TX features like steering punch on different steering stages/curves... if ya know what i mean
Old 11-30-2004, 02:29 AM   #3389
do you also have to have the same inward coning effect for the front tyres as well?
also can you use different camber angles for each side? example
4 deg Rear left and 3.5 rear right.
as my left hand side tire always gets the most punishment, most camber use and tire wear. so i always had my left side flat and my right side with a slight inward cone.
Old 11-30-2004, 02:34 AM   #3390
NiMo's Avatar
RRR rear hubs need a different set up, strange thing is, I can now go from Foam to Rubber to Wets with no set up changes front or rear.
I use -10 on Steering curve, just makes straight line overtaking a little easier (less nervous) and I have steering lock and brake adjusment set in to the 2 dials (KO Esprit II) so they can be adjusted while racing using just one finger without looking.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
