Old 11-13-2004, 04:39 PM   #3346
rjl
rjl's Avatar
The drive cups are new. All the FWs seemed to have it to some degree.
rjl is offline   Reply With Quote
Old 11-13-2004, 04:43 PM   #3347
NiMo's Avatar
I don't
NiMo is offline   Reply With Quote
Old 11-13-2004, 04:52 PM   #3348
rjl
rjl's Avatar
On this particular track, I qulified fifth out of about thirty or so and was the best Kyosho. I was bettered by an MTX and three 710s and not by much. It is just annoying and probably adds to rear tyre wear. Has anyone tried anti squat?
Old 11-13-2004, 10:32 PM   #3349
InitialD's Avatar
Which drive cups are you referring to? I was referring to ones on the wheel hubs and the ones where it attaches to the rear diff.
Old 11-14-2004, 03:54 AM   #3350
rjl
rjl's Avatar
CVs all round and the diff out drives are replaced when worn, this is not a hacks car, this is not the problem, it's more like an oscilation that sets in under very hard accelleration? I normally use shock oils between 350 and 600 wt. The 600 damped it out a little better than the softer oil but did not remove the effect.
Does anyone know if the ball diff for the FW04 can be addapted to the FW05? I'm thinking that perhaps a slipper in the diff might help.
Old 11-14-2004, 04:17 AM   #3351
Taylor-Racing's Avatar
Could the chassis be too flexible?
Maybe it's that "BLOODY RABBIT" in your avatar . . . they hop a bit.
Seriously though . . . we used to get some bouncing at Lilydale and harder rear springs helped, I reckon. Also think the harder rear diff oil helped.
Hadn't thought of harder shock oil and bigger piston holes to go with it, but maybe that might start to upset the F/R balance?
Is the body scraping? It was in that video from Franky, wasn't it?
Taylor-Racing is offline   Reply With Quote
Old 11-14-2004, 06:08 AM   #3352
NiMo's Avatar
Try running dog bones in the rear instead of the CV's.
I had CV's in my V-one R and had hopping rear, changed the rear back to dogs and the hopping stopped.
Old 11-14-2004, 12:45 PM   #3353
Sp Racer's Avatar
Anti squat will only make matters worse Rob..
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 11-15-2004, 05:49 AM   #3354
rjl
rjl's Avatar
Your car was hopping too Gav, and Cliff's was worst of all. As for the body scraping this will happen on 55mm tyres.
Old 11-15-2004, 06:16 AM   #3355
True - you reckon the bigger holes and harder oil is worth a try?
There was a lot wrong with Cliffies car, I reckon.
And you won't be runing 55mm tyres at the new track - not for long anyway.
Don't tell DC.
Old 11-15-2004, 12:46 PM   #3356
Perhaps you guys can help me, I have what can only be described as axle tramp under hard accelleration out of corners. The rear end hops? I went harder in the rear shock oil and it helped but did not remove the problem. It has been suggested to open up the piston holes to reduce the pack. What are your thoughts?
Rob.
What about putting thinner rear diff oil in gear so inside wheel does not have as much drive.
opposite lock is offline   Reply With Quote
Old 11-15-2004, 02:34 PM   #3357
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Rob.
Sounds like your diff oil is too light. Go to harder diff oil and it will remove the rear end hoping.
Racing4Evo is offline   Reply With Quote
Old 11-15-2004, 09:46 PM   #3358
Default Flywheel diameter
Anyone have problems with the flywheel extending beyond the bottom of the chassis when installed? It's the one that came with the hop-up version kit.
i300i is offline   Reply With Quote
Old 11-15-2004, 09:56 PM   #3359
Racing4Evo's Avatar
No I haven't had that problem or heard of it. Are you sure it's protruding past the chassis? Can you take a straight edge and place it along the bottom? If the flywheel doesn't interfere with the straght edge you are fine.
Old 11-17-2004, 10:49 PM   #3360
franknitty69's Avatar
Send a message via AIM to franknitty69 Send a message via Yahoo to franknitty69
Default rebound (stop)
hey fellaz. quick question on adjusting rebound stop.
the manual says to make sure the front set screws are even, then adjust the stabilzer cam. (setting data sheet ver1.00)
but the section on 'how to read settings data sheet' (same sheet) states that rebound stop is only adjusted with the set screw.
which one is correct?
is this (rebound stop) the same as droop?
thanks,
only 12 more pages to go...
franknitty69 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
