Old 11-09-2004, 03:21 PM   #3331
VZ082
3434 is offline   Reply With Quote
Old 11-10-2004, 01:39 AM   #3332
ziggy12345's Avatar
Originally posted by 3434
Ziggy do you know the part number that accepts the bearings? In the manual it looks like ball ends on both ends of the upper rear camber link.
Its not listed in the manual but i found it in the box. It looked like it would fit so put it on!. You can just see it in this pic on the rear right side
You need to fit 4 bearings to get it to work
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 11-10-2004, 07:08 AM   #3333
Thanks Ziggy,
I had an idea what the looked like but I want to install them on my FW. Trying to figure out what parts tree they come on so I can order a set.
Old 11-11-2004, 07:56 AM   #3334
rjl
rjl's Avatar
Ziggy, your plumbing, she's no good.
rjl is offline   Reply With Quote
Old 11-11-2004, 08:04 AM   #3335
franknitty69's Avatar
Send a message via AIM to franknitty69 Send a message via Yahoo to franknitty69
does anybody now where i can i get square products. the only place that i've seen some products are rc-union.com
anywhere else???
thanks
franknitty69 is offline   Reply With Quote
Old 11-11-2004, 11:16 AM   #3336
dougday's Avatar
Ziggy,
Where did you get the front body mount and front bumper?
What are the part nos?
dougday is offline   Reply With Quote
Old 11-11-2004, 01:50 PM   #3337
Default Re: FW-05R
Originally posted by mikecatts
heres the car......
mikecatts,
what are the those gold colored aluminum things your rear hubs are attached to?
what about the gold drive washers. where did you get those?
thanks.
Old 11-12-2004, 04:38 PM   #3338
Originally posted by B
The rear swaybar is made by Five Stars. I heard it is a bit sloppy (needs shimming), but otherwise is not bad. It certainly looks good!
You can order from Harmony in HK or from Japan. The Kawahara front end makes the front suspension tougher (stock is weak), and it also changes the geometry a bit to be more suited for foam tires (at least thats what kawahara claims it does)
where can i find five stars products. they were on some of the pics you posted here
Old 11-13-2004, 01:49 AM   #3339
ziggy12345's Avatar
It was all the tubing i had left. I fixed it now. Cheers anyway!
Sponsored by:
Norfolk and Chance
Old 11-13-2004, 01:51 AM   #3340
ziggy12345's Avatar
Originally posted by dougday
Ziggy,
Hi the front bumper was from the RR but it is too wide and only fits on with one screw at the front. It was just so I could get the body to fit.
The number for the correct bumper is on this thread a page or so back.
The roll bar is the RR bottom with a bit of 3mm spring wire bent over.
Cheers
Sponsored by:
Norfolk and Chance
Old 11-13-2004, 02:36 AM   #3341
NiMo's Avatar
If I translated correctly (and I got the order right), my FW05R3 will shortly become FW05RR.
NiMo is offline   Reply With Quote
Old 11-13-2004, 04:23 AM   #3342
rjl
rjl's Avatar
Perhaps you guys can help me, I have what can only be described as axle tramp under hard accelleration out of corners. The rear end hops? I went harder in the rear shock oil and it helped but did not remove the problem. It has been suggested to open up the piston holes to reduce the pack. What are your thoughts?
Rob.
Old 11-13-2004, 04:44 AM   #3343
NiMo's Avatar
Rob.
you need softer oil and springs.
also check the drive cups for wear.
Old 11-13-2004, 08:10 AM   #3344
Is the conversion kit out? Or are you buying the 05RR parts?
Old 11-13-2004, 09:09 AM   #3345
InitialD's Avatar
The rear end hops?
The rear end hops under hard accelleration out of corners? What about when you gas on the starter box?
It could be the rear outdrives wearing out.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
