Old 11-04-2004, 10:41 AM   #3316
jeffreylin's Avatar
R/C Tech Charter Subscriber
Excellent Marcos! Looks great! Let us know how they work for you. Thanks, Jeff
jeffreylin is offline   Reply With Quote
Old 11-05-2004, 05:39 AM   #3317
rjl
rjl's Avatar
Some suggestions Marcos, the countersunk screws holding the upper arm bracket should not be too tight, use locktite on the nuts but just nip them up, if you put pressure on them the bracket will fail.
If you run the caster all the way back (both spacers at front) then remove the eye on the spacer so that the diff outdrive does not grab it and rip it out.
rjl is offline   Reply With Quote
Old 11-05-2004, 08:14 AM   #3318
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
thanks for the tips!
Old 11-08-2004, 03:49 AM   #3319
BrainTeased's Avatar
Originally posted by ziggy12345
You mean camber links? I use the V0neRR camber links as they are stiffer. The RRR ones with 6x3x2.5 bearings in are the best
Cheers
hey ziggy do you have any pics of the RR camber links as i dont know which way to fit them on as they have a knob on the side. so i dont know which ones left or right etc...
thanks in advance
will also be testing my new RRR front and rear hubs this wednesday! look foward to this as nimo said he had to change his setup so i've also done the same
-2.5 camber front
-3 camber rear
o toe front
3 toe in rear
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 11-08-2004, 05:26 PM   #3320
tunerjetta29's Avatar
Can anyone tell me where i can get the FW05RR?? I dont want to have to purchase the regular FW05 and the extra parts.
tunerjetta29 is offline   Reply With Quote
Old 11-09-2004, 01:42 AM   #3321
ziggy12345's Avatar
thanks in advance
-2.5 camber front
-3 camber rear
o toe front
3 toe in rear
This is the links
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 11-09-2004, 01:58 AM   #3322
Thanks Ziggy!
also may i ask why we use 3mm shims in between the camber links and rear upright?
thanks in advance again
Old 11-09-2004, 03:58 AM   #3323
ziggy12345's Avatar
Thanks Ziggy!
More shims will give you more camber angle change for better rear grip cornering.
For example on smooth track: More shims stiffer rear roll bar and springs
Bumpy track: Less shims softer rear end no roll bar
Cheers
Sponsored by:
Norfolk and Chance
Old 11-09-2004, 04:16 AM   #3324
Cheers
ahhh! thanks Ziggy
Old 11-09-2004, 09:53 AM   #3325
NiMo's Avatar
Not yet released to the public
NiMo is offline   Reply With Quote
Old 11-09-2004, 12:40 PM   #3326
I have posted a pic and some info on the FW-05RR in the thread for the RR you can pre-order them at rc-champ in Japan the kit will be out this month but as far as the conversion kit kyosho have not yet given out any dates for release.
retrochef is offline   Reply With Quote
Old 11-09-2004, 03:06 PM   #3327
Ares17's Avatar
HI, with the stock FW05R, can I fit a Lola on it without any modification to the body post? Thanx.
Ares17 is offline   Reply With Quote
Old 11-09-2004, 03:07 PM   #3328
Cheers
Ziggy do you know the part number that accepts the bearings? In the manual it looks like ball ends on both ends of the upper rear camber link.
3434 is offline   Reply With Quote
Old 11-09-2004, 03:09 PM   #3329
You need to change the front bumper and front mounts
Old 11-09-2004, 03:12 PM   #3330
Ares17's Avatar
HI, so wat bumper and mount do i change them to for the lola to fit in nicely?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
