Old 10-31-2004, 12:40 AM   #3301
TRAJ's Avatar
Arrow
Hey Guys
i raced my FW05R on the weekend and came 4th in the B final
but the question i want to ask is has anyone ever had any drive train slippage? its when your cars is reving but not moving.
the clutch it perfect.
what could it be?
any help would be greatly appreciated.
TRAJ is offline   Reply With Quote
Old 10-31-2004, 12:47 AM   #3302
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
It could ve one of two things: 1) The center shaft pins have been flung out at the diff end or 2) You stripped the ring gears( probably if you haven't gone to the steel)
Racing4Evo is offline   Reply With Quote
Old 10-31-2004, 01:23 AM   #3303
TRAJ's Avatar
i have the 39T steel ring gears installed
i think it might be the pin.
does anyone know where to get the pin from? cause the only ones i have are for the wheel hexes and they are to long.
Thanks Racing4Evo
Old 10-31-2004, 01:35 AM   #3304
Default slipping
I'm not sure of the size of the pin but you could cut one down from the wheel hexes or use an allen key that you have laying around and cut it to size.Usually high tensile steel so strength wont be an issue.
opposite lock is offline   Reply With Quote
Old 10-31-2004, 01:42 AM   #3305
Default racing
Traj ' where did you race?????
Old 10-31-2004, 01:46 AM   #3306
TRAJ's Avatar
yer i have cut an alen key and thats whats in there atm
but i dont think thats the prob as i checked it and it was still in there
its been happening for the past 2 race meet.
it will run fine then when i get to a corner its just revs and goes nowhere, a martial has to give me a push in order for it to hook up again.
Old 10-31-2004, 01:50 AM   #3307
It must be the clutch settings or associated clutch problem then!
Old 10-31-2004, 05:09 AM   #3308
rjl
rjl's Avatar
Your first gear one way bearing is slipping, the one way runs on a hardened sleeve, use 400 grit or finer wet and dry paper and lightly rub the surface of the sleeve along it's length.
rjl is offline   Reply With Quote
Old 10-31-2004, 05:35 AM   #3309
TRAJ's Avatar
thanks rjl
will that fix the problem? cause i have a spare one way
so the sandpaper should roughen up the sleeve so the one grips better?
Old 11-03-2004, 03:17 AM   #3310
BrainTeased's Avatar
Hi guys was wondering if any of you guys have used the 3 racing front one way? would you think it would work and last just as good as the genuine kyosho ones?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 11-03-2004, 08:58 AM   #3311
kidDynomite's Avatar
Hey Brain, I'm not a big 3Racing fan, but I do use some of their "proven" products. And their one-way has lasted over 2 years in my V-one. Kyosho actually private labels some of 3Racings parts. Like the new FW aluminum front shock tower...that's 3Racing.
kidDynomite is offline   Reply With Quote
Old 11-04-2004, 02:12 AM   #3312
thanks for that kidDynomite! as i can get the 3 racing one way for half the price of the geunine kyosho set
Old 11-04-2004, 02:40 AM   #3313
Default One way
Brain-teased,where do you get your FW 05R parts?
Old 11-04-2004, 03:06 AM   #3314
opposite lock: i have 2 main suppliers one from my local track and one from another track.
Old 11-04-2004, 09:51 AM   #3315
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Hey Jeffrey here is my FW-05R with the parts that you sent me
(Kawahara front conversion and RRR hubs front and rear.
Thanks!
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
