Old 10-26-2004, 04:40 AM   #3286
ziggy12345's Avatar
Originally posted by BrainTeased
hey Ziggy
may i ask why you have to use RRR rear arms for the RRR hub conversion?
Finally my supplier has access to these so i ordered the Front and Rear RRR hubs and rear arms
You mean camber links? I use the V0neRR camber links as they are stiffer. The RRR ones with 6x3x2.5 bearings in are the best
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-26-2004, 04:43 AM   #3287
BrainTeased's Avatar
Cheers
no no i meant the actually VoneRRR rear arms do i need them to convert the rears to RRR rear hubs? as the FW-05RR come with RRR rear arms as well.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-26-2004, 04:52 AM   #3288
ziggy12345's Avatar
No you dont need those
Cheers
Sponsored by:
Norfolk and Chance
Old 10-26-2004, 04:54 AM   #3289
and on the camber link topic i got a pair of the RR camber link as you said a few pages back it has no slope! i will be installing these next time i work on the car.
where are the bearings installed? as the RR and FW-05R doesnt come with bearings so i assume this is a new generation technology thing?
Old 10-26-2004, 04:57 AM   #3290
Cheers
oh okay thanks! ziggy
do you know why the FW-05RR has the RRR rear arms then?
Old 10-26-2004, 05:17 AM   #3291
ziggy12345's Avatar
I think its to run the new roll bar same as the RRR. To use the RRR arms you need to put a spacer in.
I use MTX-3 rear hubs on my FW-05 and i put the RRR ones on the RR (Confused!) I also have the RRR completed kit so will compare them all together.
I have to rememeber which bit comes off what car as I'll end up with an FRW-RRM Evo and a V-F-1-RRM
Sponsored by:
Norfolk and Chance
Old 10-26-2004, 05:35 AM   #3292
your model naming is very confusing! FRW-RRM EVO i just cant work it out and thanks for ya input ziggy hope you'll still like the FW-05 more once you start playing with the RRR
Old 10-26-2004, 06:41 AM   #3293
ziggy12345's Avatar
I still love the RREvo!
Sponsored by:
Norfolk and Chance
Old 10-26-2004, 07:02 AM   #3294
NiMo's Avatar
I worked it out
NiMo is offline   Reply With Quote
Old 10-27-2004, 05:09 AM   #3295
TRAJ's Avatar
hey guys
i just installed the steel ring gears (39T) and ive noticed that they are not a smooth as the stock 40T.
is this common?
will they wear in after using them?
any help would be appreciated.
TRAJ is offline   Reply With Quote
Old 10-27-2004, 08:04 AM   #3296
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally posted by TRAJ
hey guys
is this common?
you might want to check the gear mesh !
Old 10-27-2004, 10:55 AM   #3297
NiMo's Avatar
hey guys
is this common?
The Steel Diff Rings do not need to be meshed as tight as the kit rings, also I found it sits across more than the kit ones so you will have to re-shim them.
Old 10-28-2004, 12:45 AM   #3298
TRAJ's Avatar
any ideas on where i should shim it? and how should i do it? less or more shims?
its only the rear one as the front one is fine.
sorry for the stupid questions i dont know much about the gears
Old 10-28-2004, 04:39 AM   #3299
NiMo's Avatar
No quick job:
You first need to shim the input shaft then the diff unit.
You need to get it so it runs as free as possible and with as little play as possible.
Old 10-28-2004, 08:59 AM   #3300
Default fw-05r for sale
almost brand new. driven two times. i do not have the time to maintain two cars. car looks like brand new. car was built by abraham horta, one of the best mechanics in the country. comes with a turbo II inline pipe (looks like it was never used). a custom painted body--- very good condition. used set of tires. $300 or best offer. 305-807-9529.
Joe Chaplow is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
