Old 10-21-2004, 05:52 AM   #3271
Bundy_Bear's Avatar
Originally posted by NiMo
The RRR rear hubs were unstable at first as it would not accept the set up I had for the original hubs, I have now found the setting and they are better, the only change I make to change from rubber to foam is to increase the camber from 1.5 degree to 3 degree.
The RRR front hubs are a must for rubber though as they allow more steering lock but does not throw the rear end.
NiMo: Thank you... advice always appreciated.
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 10-22-2004, 02:23 PM   #3272
Default First run
I have just bought a slightly used FW05R and pulled it down and rebuilt how I would normally set up my cars.
Well,this thing is a snack to drive,fast,direct and precise
ON A CARPARK THAT IS.
Now looking forward to hitting the track and see what it is really like.
Any set up sheets or advice would be great.
opposite lock is offline   Reply With Quote
Old 10-22-2004, 11:25 PM   #3273
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Default SOLID FRONT AXLE
I had a chance today to test the car with RRR fornt hubs and a spool in the front. I liked it a lot! The car had steering where I lacked it with the oneway but it was still stable transitioning from on power to off power steering inputs. Only thing I changed was the rear roll center and 2 deg. of toe out in the front. The track was high bite and the car was pretty much flat throughout the track. It was faster than the RRR today.
I think it could use a couple of changes, first one being increasing the viscosity of the rear diff oil from 10,000 to 20,000, second: decreasing front toe out to 1 deg. and lastly changing out the rear hubs for RRR rear hubs with 4mm spacers on the camber link.
Racing4Evo is offline   Reply With Quote
Old 10-23-2004, 02:28 AM   #3274
ziggy12345's Avatar
I have the Mugen rear hubs and it makes a real difference. I use 3 mm spacers.
Did you try the one way with the RRR front hubs? I changed over the hubs and got a lot more steering but still use the one way. Its the hubs that make the difference. I havent tried a spool yet
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 10-23-2004, 09:09 AM   #3275
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Kawahara Front End Conversion
Guys, my Kawahara front end conversion is in eBay now. Auction ends Sunday. Click here if you are interested. It's kinda cheap now as I post this ($26).
jeffreylin is offline   Reply With Quote
Old 10-23-2004, 11:34 AM   #3276
Racing4Evo's Avatar
Cheers
Yes, I had used the RRR hubs with the oneway. This setup is just as good but easier to drive.
Old 10-23-2004, 07:33 PM   #3277
Send a message via ICQ to vaspey
Default Kyosho one piece pipe
hi guys
can u tell me where to find the Kyosho one piece pipe online?
i wanna get one too, plz help on this!!!!
also i got a OS tr(P)t .12 and i want to get some modified parts without changing the whole engine, anyone knows where to get those modded parts?
and what is the website for mspeed i forgot, so plz help on that!!!
vaspey is offline   Reply With Quote
Old 10-23-2004, 08:35 PM   #3278
Racing4Evo's Avatar
www.rc-union.com has the pipe. I have to say that you should think about the RD Turbo II pipe. It's half the price and better than the 5.2mm pipe from Kyosho.
Old 10-24-2004, 12:03 AM   #3279
hemi's Avatar
Default DIFF OIL
Need some help with what diff oil to use.
I have been using a oneway but need brakes at my track,
it's a good size track with one good bent but the rest is tight.
I use foam tyres & track surface is average.
Help will be appreciated.
sorry if this subject has been covered before
but please tell which page.
hemi is offline   Reply With Quote
Old 10-24-2004, 04:25 AM   #3280
BrainTeased's Avatar
Default Re: SOLID FRONT AXLE
Hey i tried the front spool this weeekend as well, without the RRR front hubs though. Car feels like junk! to much understeer... i know setup could cure it but im just very comfortable with the one way. i can really hug the corners and still drive fast.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-24-2004, 05:00 AM   #3281
so where can i buy the Mspeed modified engine online?
or even modifed parts from them?
also where to buy RD Logic 2 pipe?
please specify for me, thx
Old 10-26-2004, 03:44 AM   #3282
TRAJ's Avatar
i got my RD logics turbo II from ebay for US$54 new
his user name is ALUBAPOWER IMPORTS
also guys i got the new X5 starterbox and i have tried to set it up for the FW05R but it seems to still bind.
has anyone experienced this? any one got tips on how to set up for FW?
TRAJ is offline   Reply With Quote
Old 10-26-2004, 03:58 AM   #3283
ziggy12345's Avatar
If your running foam use the RRR rear and front hubs.
Change the ring gears to 37T
Cheers
Sponsored by:
Norfolk and Chance
Old 10-26-2004, 04:05 AM   #3284
Cheers
hey Ziggy
may i ask why you have to use RRR rear arms for the RRR hub conversion?
Finally my supplier has access to these so i ordered the Front and Rear RRR hubs and rear arms
Old 10-26-2004, 04:22 AM   #3285
Originally posted by rjl
Traj, I had the Kawahara conversion in at the Nats, 22-27 pinions are as big as you would ever need. I have tried a 28 but the car went no faster and the motor got very hot.
The big advantage with the Kawahara is the very slight overdrive, about 2mm split is all you need.
Rob
may i ask why with the 28 pinion that your motor ran hotter? as im thinknig about putting my kawahara center conversion back in to lean the motor off more as to my very little amount of knowledge i thought the more that the engine is at top speed the hotter the engine would get so adding more gears to bring the top speed in later would result in a cooler running engine?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
