Old 09-27-2004, 03:55 PM   #3016
rjl
rjl's Avatar
Originally posted by NiMo
Had to take the rear diff apart on Sunday as one of the cups got badly hooked (original part - 1 year old), while it was apart I inspected the wear on the Kawahara Diff ring and ......... it looks like new, not even a scratch.
Either it's made if good stuff or the Tamiya Moly grease (the black stuff) really works.
Mine also look brand new but only use light machine oil, often.
I do have a slight weep of diff oil from one side of the diff, this works its way into one of the diff support bearings and slows it down.
rjl is offline   Reply With Quote
Old 09-28-2004, 09:39 PM   #3017
TRAJ's Avatar
hi guys i need some help on gearing
the stock gearing on the FW is 21/26??(pinions) That is fine for a smaller track, but i also race at a larger track (please see pic)
what gearing would be good for it? 22/27 or 23/28?
oh and im also running the steel machined 39T ring gears.
please help guys
main straight
TRAJ is offline   Reply With Quote
Old 09-28-2004, 09:40 PM   #3018
TRAJ's Avatar
please help, i would really appreciate it
Old 09-28-2004, 09:50 PM   #3019
jeffreylin's Avatar
R/C Tech Charter Subscriber
I would suggest that you run 22/28. I would also strongly recommend that you use the 5.2mm Kyosho pipe.
jeffreylin is offline   Reply With Quote
Old 09-28-2004, 09:52 PM   #3020
TRAJ's Avatar
Thanks jeffreylin
i will order 22/28
also will the RD logics pipe do? as i bought one 2days ago its the Turbo II version with 5mm stinger.
Old 09-28-2004, 09:56 PM   #3021
jeffreylin's Avatar
Originally posted by TRAJ
Thanks jeffreylin
i will order 22/28
i have not tried the RD pipe but others seems to have good results with it. I know that the Kyosho 5.2mm works well.
Old 09-28-2004, 10:00 PM   #3022
TRAJ's Avatar
thanks again
Old 09-28-2004, 10:27 PM   #3023
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
hey jeffreylin ,have you tried the 37t ring gears? if so whats the difference between the 39t ring gears as as overall ratio?
Old 09-28-2004, 10:31 PM   #3024
jeffreylin's Avatar
I have tried the 37T and my gearing is a little too tall now. With 22/27 & 50/45 I now have final drive of 6.47 & 4.74. However, at the end of 30min main when tires are worn down to the last few mm the car worked just about perfect.
Old 09-29-2004, 12:41 AM   #3025
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default fw gearing
TRAJ. i see that you are running at the stewart gtant track in moorebank. are you running in the nats this week?
try and use 22/ 28 45/56..with the 37 ring gears...they are going to vht the track so use 42. to 45 shore tyres..the best would be the active 43 shore long life multi rings...c rick bart for the tyres...you are going to have to cut the tyres to about 61 mm...lots traction at that track.
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 09-29-2004, 12:42 AM   #3026
mikecatts's Avatar
Default gears
sorry.
one more thing..wind the clutch in..this will help sling shot ti out of the corners..
good luck..
Old 09-29-2004, 12:45 AM   #3027
TRAJ's Avatar
thanks mike but im not running in the nats
i only just got a new engine(JP X12) and have not yet run it in
but i will bring my FW with x12 to run in at the nats
will you be going? racing?
oh and what do you use for lube on your ring gears?
Old 09-29-2004, 06:13 PM   #3028
Motorman's Avatar
everyone asked for stronger stingers.
fw05 turboII
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 09-29-2004, 07:17 PM   #3029
esham's Avatar
Default Front suspension Arm RRR
Does the suspension arms of V1RRR can fit to FW05R? Is anybody experience with it.? Any comment - Is it improve the handling must better?
Currently I'm happy with how it was, the handling is good to me after i change the pipe mount stay to just screw and nut ( Which is lower and let the right steering arm ( secure the fuel tank) go /turn over/above the screw. So i have an option to turn the steering to max. If i need that. And adjust the ride height and droop accordingly. And yes i used Mugen rear upright ( Just an habit to be different..not so sure what it done to me.. but i like it. )
Not just wonder about what the V1RRR front arms got to do with FW05R..
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 09-29-2004, 07:28 PM   #3030
Sow&Steady's Avatar
Default Re: Front suspension Arm RRR
NiMo posted some pictures at 3hobby.com of the various things he's tried on his FW05 from V1-RRR suspension parts.
If I remember correctly, the rear hubs and steering block. I've seen him with the suspension arms too.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
