Like Tree2Likes
Kyosho FW-05R
Old 09-21-2004, 12:43 AM
  #2941
NiMo's Avatar
Default Re: Re: Air Filter Question
Originally posted by jeffreylin
Make sure you rotate the engine cooling head by 90 degrees.
You beat me again
Some head only have a air passage in one direction.
NiMo is offline
Old 09-21-2004, 07:00 AM
  #2942
kidDynomite's Avatar
Originally posted by NiMo
I run the stiffest gold rear bar, and the front bar flat, this allows me to plant the power without a front wheel lifting (or to put it another way - prevents the front from diffing out).
Thanks, if you don't mind me picking your brain again, what shock hole settings are you using? I have the front sway flat, 40wt and soft orange snake springs all around. Do you run stightly thicker oil in the rear?
I don't have chunking tire problems, unless I run too many kerbs.
The rear camber is still at 3 degrees, it's the upper arm in the upper hole to reduce camber change.
Have you tried applying 'Fender Mender' to the tire walls?
I also have the rear camber at 3 degrees. I don't normally get chunking, but since you mentioned you use less camber, I thought it was vertical angle change. I'll try the upper hole.
As you posted before, the 3R front hubs are amazing.
kidDynomite is offline
Old 09-21-2004, 07:09 AM
  #2943
Originally posted by Racing4Evo
How big are you running your tires? Anything above 62mm is prone to chunking. Also what brand tires are you using? Try Mono Tuning tires, the compound has been improved for better grip.
If all that fails, run some CA glue around the tires walls with a Q-tip although it will take away some side bite.
I'm using Twisters. Me and most guys at the track run 40 shore all around. I do put CA around the walls and cut them down before the first qualifier to 62mm, then round the edges with a file to keep a little bit of side bite.
There's a couple turns on our track that run perpendicular to these tire eating cracks. Most of the time I change my line to avoid them but some times it's the perfect place for passing. Next season it will be re-asphalted.
Old 09-21-2004, 07:16 AM
  #2944
NiMo's Avatar
Shock Holes - 2x 1mm and 40wt all round.
Shock position: front laid down, rear upright.
NiMo is offline
Old 09-21-2004, 07:25 AM
  #2945
Thanks!
Old 09-21-2004, 11:16 AM
  #2946
Racing4Evo's Avatar
those craks seem like the reason. We had a corner that would cut up the tires if you took it too tight. Looks like you'll have to wait till next year to fix the problem.
Racing4Evo is offline
Old 09-21-2004, 11:08 PM
  #2947
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default some tips
hi all.
ive been talking to josh cyrul.
here's what he has to say about the us nats.
mike
hi again josh, simon camalleri sent me a couple of pics of your fw that you ran , i noticed that the front-upper arm holder is different to the stock one,, it looks like its lower and wider? correct? and the rear end camber links look stronger..my question is can we get them yet or are you still developing.. ive tried the kawaharra front conversion, and it semms to make the car want to push in the corners, i put the standard front upper on and its better but the car isnt too goo at high speed. it pushes no matter what i do. ( brisbane australia off the main back straight comming into the centre tight section) what kind of rear wheel blocks do you use..the RRR or the stock fw...i see that people are talking about the mugen rear..will it work...i seem to have to run a lot of front and rear camber for the car to work..
sorry for the long letter, but i am getting frustrated with the car,, simon and i spent a week in brisbane state titles on the car and it still had the pushing issue..i dont want to buy the rrr..(i gave mine to rick bartolozzie as he wanted to try before he ran out of time for the aust. nats and kyosho was running late). i do like the ease of maintenance of the fw...
mike
REPLY
I understand your frustration as this is the same problem I have had here in the US. Check out my set-ups area in the next few days as I will be posting my FW-05R set-up from the ROAR Nationals - it's the best my car has been so far. The front end was the prototype that Kyosho sent me - should be out very soon. The rear hubs are off the RRR and the camber links are also included with the new front end (same plastic tree anyway). One my car I run 4 degrees of rear camber and 2.5 in the front.... I agree that this is extreme but it's how the car likes to run...
QUESTIONS
hi again josh.
thanks for the quick reply.
one thing i di not ask, is you are using the RRR front steering blocks as well?
when i put the RRR on the front and rear, to make it 199 front and 198 rear i have to use the front drive axles#VZ013. and the swing shaft wide tyre #VS033. have you noticed the same?.
i also see that your setups you favour a heavy rear and a lighter front,,is this to aid turning?.simon and i set it with silvers all round..350 front and 500 rear oil..black sway..it was twitchy but it was the best we could get..
we want to get the parma or the losi alfas, but cant get in aus..rick wants to try as well. were can we purchase some of these?
ive found 190mm but not 200mm.
are you using by choice or sponser?, we have found the kawaharra honda and the active shortere mazda 6 to be the best so far,,any thoughts?
sorry for the long letter again..
REPLY
Mike - I used the RRR steering blocks as well.... I don't know about what axles we use (I think the short ones) because Kyosho built my car and sent it so I didn't have to do anything but install radio gear. I was lucky with that one!!! I like the heavy rear bar because it allows me to use a more forgiving rear shock set-up which makes the car less sensitive but still has good steering.... I'm not sure where you can get the 200mm bodies. Check a few US based on-line shops (kthobbies is a good one). I used the Parma because I liked it and I thought it was better than the others..... I've never seen or used the Kawahara or Active bodies....
mikecatts is offline
Old 09-22-2004, 12:56 AM
  #2948
NiMo's Avatar
Palma Alfa ?
Guess we missed that one.
The rear upper links a very similar to the one that come with the RRR rear suspension arms (not yet tried), they allow the use of 3x6 bearings between the screw and the plastic.
NiMo is offline
Old 09-22-2004, 01:22 AM
  #2949
NiMo's Avatar
New Rear Suspension Arm? (translated from Japanese)
No.VZ004C rear suspension arm set \ 630 (including tax) 9/24 (gold) sale The rear suspension arm (VZ004B) the 9mm suspension ball it approaches and in order to be able to install deeply, it improves. * For V-One S/V-One RR/FW-05R/FW-05S.
NiMo is offline
Old 09-22-2004, 03:12 AM
  #2950
rjl
rjl's Avatar
Mike, I have asked for the Parma Alpha from Dawn, they are on the way.
rjl is offline
Old 09-22-2004, 03:46 AM
  #2951
mikecatts's Avatar
Default att nimo
hi nimo.
can you please post the page link.
im having trouble finding it
mike
Old 09-22-2004, 04:13 AM
  #2952
BrainTeased's Avatar
hi can someone please tell me what josh cyrul's site is again i lost it along with my busted harddrive.
BrainTeased is offline
Old 09-22-2004, 05:54 AM
  #2953
NiMo's Avatar
Default Re: att nimo
Originally posted by mikecatts
hi nimo.
mike
Kyosho Japan
http://www.kyosho.co.jp/web/new_prod...parts00-j.html
NiMo is offline
Old 09-22-2004, 11:50 AM
  #2954
Tech Legend
Marcos.J's Avatar
Trader Rating: 192 (100%+)
http://www.cefx.net
Marcos.J is offline
Old 09-22-2004, 04:22 PM
  #2955
Racing4Evo's Avatar
Jeff is in Taiwan right now and I asked him to pick up the new front end if it's out next month and he comes across it.
My friend has already fitted the RRR hubs and likes it a lot. There is a big race down here in SoCal this week and hopefully between the two of us be able to put at least one FW-05R in the A-main. The car is fast enough, we're just having to sort out motor issues.
