Old 09-20-2004, 02:24 AM   #2926
NiMo's Avatar
Originally posted by Chanhonam2k
Hi guys. Just a quick question
a friend of mine want to ask, can the pull start .12 engine fit in the FW 05R?
also can the NovaRossi LS15PS2 fit in the FW 05R ?
thanks
andy
You will need to put spacers under the motor mounts to fit a pull start motor.
If the 15 has the same crankcase size as the 12 then it should fit, but where would you race with a 15?
NiMo is offline   Reply With Quote
Old 09-20-2004, 06:48 AM   #2927
BrainTeased's Avatar
Originally posted by ziggy12345
Just back from the track running the FW-05M in a comp.
I get 18 laps for the first time in 309.84 and took .7 secs off of my best lap time. 16.29
I won the a final but david Hall (sponsored) lost 2nd gear half way through. We were within 3 secs of the heat times
It goes like a rocket!!!
Hey Ziggy
i tried searching all the pages yet cant find your post that you have posted for the parts needed to convert our FW-05R to FW-05M using mtx-3's rear uprights. Is it possible for you to announce them again please im switching to FW-05M as well
thanks in advance
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 09-20-2004, 07:39 AM   #2928
NiMo's Avatar
Originally posted by BrainTeased
Hey Ziggy
thanks in advance
Why not an FW05R3 ?
RRR rear hubs work great, just set it up for minimum camber change and 1.5 degree toe in, same set up works for Foam and Rubber.
Old 09-20-2004, 07:50 AM   #2929
Originally posted by NiMo
Why not an FW05R3 ?
thanks nimo
i actually just found the page! "47" i almost gave up!!! lol
i just hope my supplier can get them! as they ussually order from rc mart only.
Old 09-20-2004, 11:29 AM   #2930
V1R racer's Avatar
Default Re: Re: Pipes
[QUOTE]Originally posted by Buggy Master
[B]i never tried the kyosho versions. i was using the os 1031 but now i use the rd logics turbo 2. it woke up my engine from bottom to top.
Could you tell me where you got the rd logics pipe from?
V1R racer is offline   Reply With Quote
Old 09-20-2004, 12:27 PM   #2931
kidDynomite's Avatar
Nimo, I was wondering what sway bar you're running in the back. I'm also running a soft suspension.
You mentioned that you can run less camber in the rear with the new uprights. Do the tires chunk a little more than normal. My track isn't the smoothest on some sections.
kidDynomite is offline   Reply With Quote
Old 09-20-2004, 01:13 PM   #2932
NiMo's Avatar
I run the stiffest gold rear bar, and the front bar flat, this allows me to plant the power without a front wheel lifting (or to put it another way - prevents the front from diffing out).
I don't have chunking tire problems, unless I run too many kerbs.
The rear camber is still at 3 degrees, it's the upper arm in the upper hole to reduce camber change.
Have you tried applying 'Fender Mender' to the tire walls?
Old 09-20-2004, 01:38 PM   #2933
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I will be getting one of the RD Turbo II pipes to try out and I will let you know how it compares to the Kyosho 5.2mm pipe.
On a different topic, Jeffrey Lin won the B-Main at the recent Taiwan Kyosho Cup with Kyosho factory drivers also attending the race. Congrats to Jeff! By the way, I told you those 37T gears make a big difference. Now I have to watch out for you when you get back.
Racing4Evo is offline   Reply With Quote
Old 09-20-2004, 01:48 PM   #2934
Racing4Evo's Avatar
How big are you running your tires? Anything above 62mm is prone to chunking. Also what brand tires are you using? Try Mono Tuning tires, the compound has been improved for better grip.
If all that fails, run some CA glue around the tires walls with a Q-tip although it will take away some side bite.
Old 09-20-2004, 05:18 PM   #2935
jeffreylin's Avatar
R/C Tech Charter Subscriber
Thanks Peter. Just quick correction, the factory drivers are from Hon Nor, Team Magic, etc. No Kyosho drivers were there. Mr. Ito from HPI was there though. I think he is the designer for the Pro 2, Pro 3, and the Savage.
jeffreylin is offline   Reply With Quote
Old 09-20-2004, 05:22 PM   #2936
Default Air Filter Question
Hey guys,
I wanted to check if anyone has trouble with their engine overheating due to the air filter blocking the head...or is there a different type of filter that sits lower and exposes the head better...I am pretty sure noting is wrong with the motor or that the fuel tank leaks...checked that.
Dieter
KiwiRacer is offline   Reply With Quote
Old 09-21-2004, 12:47 AM   #2937
Trader Rating: 37 (100%+)
Default Re: Re: Re: Pipes
[QUOTE]Originally posted by V1R racer
[B]
i got it from ebay but you could purchase it off their website. make sure you get the turbo 2 version.
Buggy Master is offline   Reply With Quote
Old 09-21-2004, 12:50 AM   #2938
jeffreylin's Avatar
Default Re: Air Filter Question
Originally posted by KiwiRacer
Hey guys,
Dieter
Make sure you rotate the engine cooling head by 90 degrees.
Old 09-21-2004, 12:58 AM   #2939
Hey guys,
Dieter
i wondered about that. on my fw, i use the older version of the motor saver air filter and it does look like it blocks the whole head. i wanted to keep this air filter so i replaced the original nova head with a crazy nut head and temps went down.
Old 09-21-2004, 01:03 AM   #2940
Originally posted by jeffreylin
What's up Wayne. How's going? i wonder how the rd pipe compares with the kyosho ones. anyone tried both?
what's up jeff. looks like your still doing good with your fw. as for me with the pipes, i don't plan on trying anything else right now. i am very impressed with the turbo 2.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
