Kyosho FW-05R
#2911
28T Gear - VZ116-28
#2913
FW05R hop up edition
hi guys,
anybody knows the difference between the regular kit and hop up edition kit?
what hop ups worth the money if i decided to get the regular kit?
thanks for your inputs
#2914
from wat i quote from the supplier 1 week ago.
the Regular kits: Just normal FW05R
The Hop Up kits: has One Way front, stronger graphite radio, and stronger chassis, and come with 4 original foam wheels. it's about $90-120 more, i think it worth the money.
Unless you've got the Oneway front, and buy those bit and pieces.
Actually i am trying to look for more info about it. I guess that Hop-up kits there only avialable from HK, coz many other places doesnt have it,
Hope that help
thanks
andy
Hope that help
thanks
andy
#2915
The hop-up version #31582 will be available in the US next year.
The differences are:
-Shimo Chassis
-Graphite radio tray
-Front One-way
-Different spring combo
There is also a different setup
There are 3 things you must have on the car:
-Steel ring gears(37T if you run on a medium to large track)
-Aluminum Brake Holder
-APP Brake set or the brake disk alone(the APP doesn't fade as much)
-Shimo Chassis
-Front One-way
#2916
Hi guys,
I have a very good condition FW05R for sale.
Comes with hopups and tons of spares. Will let it go if the price is close to what i have asked for. Feel free to drop me a pm for more info.
For pix, pls go to
http://www.rctech.net/forum/showthre...threadid=50316
For pix, pls go to
#2917
Just fix the on-way unit on my 05R. Haven't test run it yet? What to look for when running front one-way? I'm so used to gear diff, I find it strange driving with one way.
#2919
loss of braking power? is that good news or bad news? looks like i gotta change my driving style afterall....
#2920
Pipes
I have been testing the Kyosho 5.2mm pipe and the 6mm pipe between different tracks and different engine and gear ratio. I think I can say conclusively that the 5.2 is superior in nearly everyway. One would think the 6mm pipe will give you more top end but it seems the opposite is true in this case. It seems that you can run leaner with the 5.2mm pipe without overheating and reallly bring the top end out of the motor.
#2921
Hey guys, anybody using this starter boxes :
http://www.ofna.com/images/st-sb-10243-big.jpg
Is it better than the Trinity/Team Magic X5 ?
#2922
Hi guys. Just a quick question
a friend of mine want to ask, can the pull start .12 engine fit in the FW 05R?
also can the NovaRossi LS15PS2 fit in the FW 05R ?
thanks
andy
thanks
andy
#2923
Re: Pipes
#2924
Re: Re: Pipes
Originally posted by Buggy Master
i never tried the kyosho versions. i was using the os 1031 but now i use the rd logics turbo 2. it woke up my engine from bottom to top.
