Like Tree2Likes
Kyosho FW-05R
Old 09-04-2004, 12:11 AM
  #2821
hi, has anyone here got any links/review site for this kyosho FW 05R ? i want to read some, and want to compare with other kits
apparently it has 2 different type. 1 just a normal FW 05R, other one is Hop Up kits (which has all, front one way drive, and stronger chassis and graphite radio and other).
cheers
Chanhonam2k is offline
Old 09-04-2004, 03:21 AM
  #2822
kidDynomite's Avatar
Chanhonam, There's a 10 car shootout in the latest RCCA Touring Cars magazine:
http://www.rcstore.com/rs/general/de...TR04&catego=BO
I believe there are four versions:
http://www.kyosho.co.jp/web/products...5/index-e.html
Six if you include the 05S series.
kidDynomite is offline
Old 09-04-2004, 01:23 PM
  #2823
NiMo's Avatar
I have just realized that in running in the Foam class I can remove the 5.4mm Carb restrictor, Wow! does it go now.
NiMo is offline
Old 09-04-2004, 01:28 PM
  #2824
rjl
rjl's Avatar
Those restrictors are usually smaller than 5.4mm anyway.
rjl is offline
Old 09-04-2004, 02:27 PM
  #2825
NiMo's Avatar
I will have to check that out as I can go to 5.5mm maximum in the National championship.
NiMo is offline
Old 09-05-2004, 02:18 AM
  #2826
rjl
rjl's Avatar
The restrictor usually measures 5.1- 5.3mm, I use a reamer to open them up to just over 5.4. The engines are quite happy at that. I have not found that leaving the restrictor out actually resulted in faster lap times. Then again I only use 5mm stinger I.D. and that might be limiting the thing a bit.
Had an awesome day at the local track today, ZT TQed,FW second, left a lot of snakey people a lap down.
rjl is offline
Old 09-05-2004, 11:44 AM
  #2827
NiMo's Avatar
I ran without the restrictor today, had a lot more power but my best time equalled what was done with the restrictor in, also I found it drank a lot more fuel and 5 munites was the borderline, so I think I'll put the restrictor back in (it's a bit more relaxing to drive fast that way).
NiMo is offline
Old 09-05-2004, 03:21 PM
  #2828
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default placing
hi rob,
well done, put to the mugens,
im not going to make it to the nats.. back and money probs.
i want you to kick ass. are there any parts that you or any fw drivers need. ive heaps and becauase im not going its excess baggage,
mike
mikecatts is offline
Old 09-05-2004, 04:34 PM
  #2829
rjl
rjl's Avatar
I agree, it's not quite so peaky with the restrictor fitted. Personally I have found that you can get more out of the car by properly setting the clutch than removing the venturi. The engine is also more linier in it's responce.
rjl is offline
Old 09-05-2004, 06:21 PM
  #2830
I caved in and bought a RRR...... at first i had the intense guilt of dropping that much cash but after all i had a spare engine that needed a home. Build up is 1/2 completed. The rrr just plain looks fast! sorry for the off topic i had to share.
rcosmax is offline
Old 09-05-2004, 07:05 PM
  #2831
Okay, right now I have a Serpent 710(piece of junk). I'm getting rid of it. I here alot of good things about the Kyosho Fw-05r, although my friends run the Mugen. They are trying to get me to get that. I just need to know, is the Kyosho better?(I dont want a fight abou it) Does it drive easier? I had my mind set on it until I got around about 5 bugging Mugen drivers. I will have to order parts, is it worth it?
Please LMK,
James W.
racer6888 is offline
Old 09-05-2004, 09:25 PM
  #2832
rjl
rjl's Avatar
Please LMK,
James W.
Having run belt drive tourers for about 8 years and now switched to the shaft drive, (tried the NTC3 for about 2 weeks) I can tell you I for one will never go back to picking gunk out of the belts and pulleys. If you go with an FW you will want the 37 tooth crown wheel or the Kawahara centre conversion. I prefer the Kawahara because of the very small overdrive it offers.
rjl is offline
Old 09-05-2004, 09:58 PM
  #2833
Racing4Evo's Avatar
It's a better idea to run the 37T ring gears instead since you can still use the drive cups and center shafts that come with the car. If you want overdrive, just switch the rear pinion gear with the K-Factory 14T gear.
By the way, Chris Tossolinni(sp?) piloted the FW-05R to 3rd place at the Nationals today. I think this was his first big race with the car. Also, there were 3 FW-05R's in the A-main, out numbering all the other brands.
Racing4Evo is offline
Old 09-05-2004, 10:07 PM
  #2834
rjl
rjl's Avatar
Well shaft cars outnumbered belt cars.
rjl is offline
Old 09-05-2004, 10:23 PM
  #2835
rjl
rjl's Avatar
Sorry but the Kawahara still gives the least split.
rjl is offline
