Kyosho FW-05R
#2791
Originally posted by ziggy12345
I have had the MTX-3 hubs on the FW for some time and it makes a real difference to the rear end for foam tyres.
I was using 5 deg camber with te original hubs but now back to 1.5 deg.
The rear end is planted now!
I just changed the rears on the VoneRR EVO and it had the same effect there. I tried it yesterday and it was amazing! I got the same times as the FW. I was going to sell it but have chaned my mind now!!
Cheers
Cheers
#2792
Originally posted by NiMo
Which pillow ball do you refer to?
The steering pillow ball is about 6mm closer to the axle so you get more steering over the original hubs using the same amount of servo throw, and the best bit is you do not lose any rear end grip.
Pictures can be found here at 3hobby.com
I have not tried the MTX3 hubs and I am not happy with the RRR rear hubs, it makes the rear end loose, so I'm reverting back to the original 05 hubs.
It may be that the RRR's rear hubs work fine with the RRR's rear end, but not with the FW.
It's all a geometry thing - that's why I'm interested in the distance between those front pillow balls. Maybe they've played with the front roll centre.
#2793
Originally posted by Taylor-Racing
Sorry, I'm mean the distance between the pillow balls that screw into the upper and lower arms - see attached pic.
Hmmm . . . it may be that the MTX hubs cause you to use a shorter upper link and thus afford the greater camber change for a given suspension compression. Ziggy and others have commented favourably.
I tried the rear hubs again today, I still think the rear end is loose but Slow&Steady says the rear is loose because I'm trying to drive at Wedge shell speeds with a Touring shell, he thinks I should stay with them, so I will for a little longer just to see who prooves who right.
#2794
Not really checked that bit, all I kmow is that they work.
#2795
Originally posted by Sow&Steady
It was OK after you fixed the loose pillow balls right? Very stable and fast around the sweeper. You were hammering the car to the limit.
Shame I had no one on track with me to check it out for myself.
#2796
But it still feels slow and loose.
#2797
We could test together next Saturday if you like ...
#2798
you were there today but we never got on to the track together, I only had Latex Andy to run with.
#2799
For some strange reason, like you, I was not in a mood to run. Maybe if we had done a tank together we would have got going.
Still no reply from Brookland club.
#2800
Hey Nimo, cvccsi told me that the 3R rear hubs push out quite a bit. Did you try trimming down the arms a little? I would think that this would also make the top camber link shorter.
BTW ... I really appriciate all your input on these mods. My parts are still in HK somewhere so I'm trying to get things sorted out with your R&D.
#2801
I now have both front and rear at 199mm.
I have used a part of the RRR upper arm as this part can use bearings to smooth the action yet eliminate all play, I have yet to get the bearings so at present only have alloy bushed fitted, I think the bearing size is 3x6 which you need two off for each side.
#2802
You could be right there, I only went out twice.
#2803
Give it a few more days. If they don't reply and Les can't get hold of anyone then maybe its not worth going ... there may be no one there when we arrive!
#2804
I had no width problems, I used the 05 swing arms with front dogbones and drive cups which still allows the 30mm rear foams to fit, and when first assembled I was down to 194mm with no binding (the pillow balls would not screw in any further).
#2805
Interesting ... if you do find some hope for the 3R rear hubs, would you let me know how much you brought up the camber link on the the hubs? I just need a starting point. Right now I run soft springs and dampening. The car feels planted at the track I race at, and I'd only like to use these if there are substantial benefits. Thanks!
I run very soft springs, The green and Yellow ones from the Kyosho Spider MkII kit, with 2 hole 40wt damping.
