Like Tree2Likes
Kyosho FW-05R
Old 08-28-2004, 04:59 PM
  #2776
Sow&Steady's Avatar
Originally posted by NiMo
I have just e-mailed the Brookland club to confirm if the meeting is still on.
If so NiMo, Slow, Baz, Andy G, Andy & Iain are heading down from AMCC with possibly some others.
There ya go Ziggy ... join us.
Sow&Steady is offline
Old 08-28-2004, 10:21 PM
  #2777
Slotmachine's Avatar
Default gears
I ran the kawahara geears with the bigest gears (spur & pinion) I could get with 55mm tires and on a 200 foot straight I never ran out of gear!
Slotmachine is offline
Old 08-29-2004, 05:15 AM
  #2778
Hi, I have recieved my o5R but the hobby shop from hong kong sent me the rubber tyre version not the foam and he's not sure of the difference, I have read it preveoulsy but can't find it again he said he will send the parts over for me also its only the standard foam version no one way etc. As far as I know the only part needed is part # is VZ081. any info is appreciated.
madaz is offline
Old 08-29-2004, 05:42 AM
  #2779
BrainTeased's Avatar
Originally posted by ziggy12345
Nimo
Hope you dont mind but copied this from 3com. Its usefull
Kyosho Options
13/37 - 2.846
13/39 - 3.000
13/40 - 3.077
Kawahara Options
17/45 - 2.647
17/46 - 2.706
KFactry Option (coming soon)
14/39 - 2.785
sorry may i ask which of those gears give the most bottom end/take off power ?
is it, the higher the number (eg. 13/40 - "3.077") the more bottom end launch?
BrainTeased is offline
Old 08-29-2004, 06:20 AM
  #2780
Taylor-Racing's Avatar
Yes I did change the fronts and what a difference it makes, I can turn in when I want to and hold that tight line all round the corner, and it doesn't push anywhere like before.
RRR front hubs are a must!!
Tried the rear RRR hubs but have yet to notice any improvement, if anything it makes the rear end loose so I make take them back off.
I will try the rear hubs again tomorrow but this time with the RRR swing arms, which looks like they are adjustable for wheelbase length, not sure how to fit the roll ball to them though.
NiMo,
What is the center to centre distance of the pillow balls in the RRR front hubs, please?
Have you tried the MTX-3 rear hubs? I was speculating a couple of pages back re the length of the top link. The necessity to use a short link with the MTX hubs would likely see a greater dynamic camber change. This may not be happening with the RRR hubs.
Taylor-Racing is offline
Old 08-29-2004, 07:56 AM
  #2781
NiMo's Avatar
Originally posted by Taylor-Racing
NiMo,
Which pillow ball do you refer to?
The steering pillow ball is about 6mm closer to the axle so you get more steering over the original hubs using the same amount of servo throw, and the best bit is you do not lose any rear end grip.
Pictures can be found here at 3hobby.com
[Have you tried the MTX-3 rear hubs? I was speculating a couple of pages back re the length of the top link. The necessity to use a short link with the MTX hubs would likely see a greater dynamic camber change. This may not be happening with the RRR hubs.
I have not tried the MTX3 hubs and I am not happy with the RRR rear hubs, it makes the rear end loose, so I'm reverting back to the original 05 hubs.
NiMo is offline
Old 08-29-2004, 08:05 AM
  #2782
NiMo's Avatar
Correct.
But with the JP FX T03 I have to use 2.647 to prevent excessive wheel spin, even with foams.
NiMo is offline
Old 08-29-2004, 01:22 PM
  #2783
rjl
rjl's Avatar
Yes, running the Kawahara crown wheel and pinion had me race the Vortec in first gear. You would be very overgeared at KROMA so 13-39 would be better.
rjl is offline
Old 08-29-2004, 09:43 PM
  #2784
Default Cadilac
Well heres the Cadilac 200mm. painted in the Andy Pilgrim style road racer
Old 08-29-2004, 09:45 PM
  #2785
Default another
here
Old 08-29-2004, 09:48 PM
  #2786
Default another
I wish I knew how to put them all together!
Old 08-30-2004, 01:32 AM
  #2787
NiMo's Avatar
Default Re: another
NiMo is offline
Old 08-30-2004, 04:21 AM
  #2788
thanks NiMo and rjl
No wonder i had very little launch, also rob i had to loosen my 2 speed quite abit just to get the 2nd gear to kick in at the kroma track.
Now my next curiosty is why would
13/37 have less punch than 13/40 i thought with 37T it would make the car take off even more faster due to less amount of teeth meaning the amount of revolutions of the crown been driven by the pinion is shorten.
And rob ill take your advice and will save up for the machined steel gears ill be running 13/39 fronts and 13/40 rears.
also with the overdrive do i have to run my front tyres smaller than the rears eg.
Fronts 56mm Rears 60mm ?
Old 08-30-2004, 05:58 AM
  #2789
ziggy12345's Avatar
NiMo,
I have had the MTX-3 hubs on the FW for some time and it makes a real difference to the rear end for foam tyres.
I was using 5 deg camber with te original hubs but now back to 1.5 deg.
The rear end is planted now!
I just changed the rears on the VoneRR EVO and it had the same effect there. I tried it yesterday and it was amazing! I got the same times as the FW. I was going to sell it but have chaned my mind now!!
Cheers
ziggy12345 is offline
Old 08-30-2004, 06:12 AM
  #2790
NiMo's Avatar
thanks NiMo and rjl
The smaller the input gear and larger the output gear the taller the gearing is, for quick take off you want to run a short gear, but you will rev out a lot quicker.
Also depending on the torque your motor has decides which gear to go for, My STS need a 13/39, whilst the JP would need a 14/37 to tame the extra torque.
NiMo is offline
