Old 08-24-2004, 03:10 AM   #2686
Sow&Steady's Avatar
Default Re: Re: FW-05R
Originally posted by jeffreylin
I noted in your signature that you have both the TRF415 and the TB Evo4. So which one is the best between those 2?
There is no such thing as best car objectively. What matters is what you like and the support you will get.
FW series are shaft driven car and the V-One series are belt driven.
If you want to know how the 415 compares to the XRAY T1 Factory, go to 3hobby.com and read the article by MarkP. He is building both kits simultaneously and comparing build, quality, performance etc.
You won't see too much about the Evo4, I think its because Mark felt the Evo III was a let down for him.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-24-2004, 07:00 AM   #2687
kidDynomite's Avatar
Default Re: Re: Chassis ?
The 31582 kit comes with a Shimo chassis. It is very very strong and I haven't experienced any tweak running 2 cars for 9 months.
Thanks Jeffrey, does it use 4mm screws for mounting the engine?
kidDynomite is offline   Reply With Quote
Old 08-24-2004, 09:56 AM   #2688
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: FW-05R
Thanks, but I was really asking a rhetorical question to demonstrate a point--that there is no objetive answer to "what is the best car" type question.
jeffreylin is offline   Reply With Quote
Old 08-24-2004, 09:58 AM   #2689
jeffreylin's Avatar
Default Re: Re: Re: Chassis ?
Nope, it still uses 3mm screws for the engine. However, since it's fairly easy to adjust the engine position on the mounting block, I don't see why you couldn't just drill the holes out to 4mm if you have mounting blocks that will take 4mm screws.
Old 08-24-2004, 10:09 AM   #2690
NiMo's Avatar
I have found that once you have the mounting blocks in place you never have to touch them again, as it is so easy to just remove the motor from the blocks.
NiMo is offline   Reply With Quote
Old 08-24-2004, 10:34 PM   #2691
jbrosche's Avatar
Default tb-E4 Vs 415
I am into the shaft drive. the belt adjustments is tricky.
Alright. i ordered the Kyosho Fw-05 chassis. This comes with the sponge tires. So hear is the deal:
Can you guys suggest any hop -up parts i will need to build this out top-shelf style?
What engine do you recommend?
This is a great group! I enjoy reading the posts.
Anyone in Seattle? If so where can i find parts to this beast?
JBRO
jbrosche is offline   Reply With Quote
Old 08-25-2004, 05:54 AM   #2692
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: tb-E4 Vs 415
JBRO
http://www2.towerhobbies.com/cgi-bin...I=KYOC0479&P=Z
Old 08-25-2004, 06:57 AM   #2693
Thanks Nimo & Jeffrey, I have a micro ss clutch that I love so much. It engages extremely quick and the mounts are offset to bring it in closer to the spurs when sitting really low (.03mm from the chassis). But I think I'll stick to the stock one.
Old 08-25-2004, 10:22 AM   #2694
jeffreylin's Avatar
Kid, the stock one works quite well. You will never think about it again.
Old 08-25-2004, 11:42 AM   #2695
Thanks, guys! That's what I plan to do. The micro clutch is probably happier in the Evo anyways.
Old 08-25-2004, 01:33 PM   #2696
jbrosche's Avatar
Default Parts?
Thanks for the parts list Marcos.S710!
Onle last question/suggestion:
Before i build the car, are there any parts I should order now so I will have them? Anything worth replacing/Hoppiing up?
Any and all suggesstions welcome!
JBRO
Old 08-25-2004, 01:44 PM   #2697
Default Re: Parts?
JBRO
Try the 37t ring gears. Otherwise, the car fine. Consider it just one big hop-up.
Old 08-25-2004, 02:17 PM   #2698
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
This is what you MUST HAVE:
Steel Ring Gears( which one depends on how big your track is)
Kyosho Aluminum Brake Holder
Kyosho Optional Brake Disk
Racing4Evo is offline   Reply With Quote
Old 08-25-2004, 10:23 PM   #2699
Default FW05R w/ RRR Rear Upright
image 1
cvccsi is offline   Reply With Quote
Old 08-25-2004, 10:23 PM   #2700
Image 2
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
