Old 12-11-2003, 08:34 PM   #256
Joehwee's Avatar
I have been racing the FW05R for few months and have not break anything on the car, if you guys browse through my earlier post, i have some tips on building the car. The 1st hop up for the car will be the UJ and steel crown gear (not available yet).
The car is pretty tough for me, but some of the guys complaint that they break the front shock stay, maybe that something you want to stock. For myself I have brought everything from arms, bulk heads, shock stay, spur gears as spares.
Joehwee is offline   Reply With Quote
Old 12-11-2003, 08:36 PM   #257
Joehwee's Avatar
Also I am runnung OS TR 5 port on my FW05R and the engine is comparable with the Nova or Sirio in small to med track. If you run on bigger track the TR may not give you power and speed as those european engine, but tuning the TR is very easy.
Old 12-12-2003, 12:47 AM   #258
buboy28's Avatar
Send a message via AIM to buboy28 Send a message via Yahoo to buboy28
tcd gear
guys will the tcd gear set of the v-one series fit the fw-05R?
buboy28 is offline   Reply With Quote
Old 12-12-2003, 12:49 AM   #259
Joehwee's Avatar
yes, the LSD from V1R are able to fit into the diff of the FW05R
Old 12-12-2003, 01:36 AM   #260
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Finally, I got the parts that I need to get my car running(the 2nd gear spur). Hopefully I'll be ready to run the car through race pace on Sunday. This car will be phenomanal with the one-way. I'm trying the one-way on the other guy at my track is going to try the LSD. We're going to compare both.
Also, regarding parts that break, I did break the front shock tower at the screw location but this was at night in 45 degree weather. Certainly, temperature was a big factor. At 45 degrees, everthing is brittle and easy to break.
Racing4Evo is offline   Reply With Quote
Old 12-12-2003, 06:49 PM   #261
let us know how it dose with the new 2nd gear. How many teeth did you gear it up ? Thanks
mugenracer is offline   Reply With Quote
Old 12-13-2003, 01:10 AM   #262
Racing4Evo's Avatar
I got a bigger 1st gear but the 2nd gear wasn't with my order so I'll have to work with stock gearing. If you want to see the car, I might be there Sunday for the Toys for Tots race (if it isn't raining). I'll most likely be the only person with the car. Just come over and have a look at the car. My name is Peter.
Old 12-13-2003, 04:30 PM   #263
Send a message via AIM to mrredrsx02
what is the front one-way hub?
what is the front one-way shaft? i am buying hop up for my kit what are some good hop up that will help the car handle better? tahnx
mrredrsx02 is offline   Reply With Quote
Old 12-13-2003, 11:15 PM   #264
Racing4Evo's Avatar
For me and the track I run at, the only hop-ups to make the car handle better are stiffer springs and a one-way. The hub I guess is the main part of the one-way which houses the one-way bearings. The shafts you are reffering to are the out drives. They fit inside the bearings and feed power from the one-way to the dogbonesa and ultimately the wheels.
Old 12-14-2003, 08:28 PM   #265
Default hop up question?????
i want to order some hop up from rcmart.com and some of the hop up say it from 3racing and some of them are from kyosho i was wondering is there any different bewteen the two. the kyosho cost more then the 3racing.?
what are the 3d clutch assy?
Old 12-15-2003, 12:17 AM   #266
Trader Rating: 23 (100%+)
Default need good engine
hi all,
now that i've got the car, i need to do some shopping for a new engine. the class i'm planning on running needs a size 12 side exhaust engine. I know JP is good but i do plan on going for the open class in future (which allows rear exhaust) so i dont want to spend that much on a side exhaust. the number of ports is 4 max including exhaust port and must be pull start. so my question to you all is:
what is a great bang for buck side exhaust 12 size engine for the FW05R?
what will be a good exhaust to compliment this engine?
cheers all, and thanks for your input!
poop is offline   Reply With Quote
Old 12-15-2003, 02:31 AM   #267
Sp Racer's Avatar
no brainer...best bang for the buck, OS 12 TR-P 5 port
Sp Racer is offline   Reply With Quote
Old 12-15-2003, 02:34 AM   #268
Errrmm.... he said SIDE EXHAUST Lue .
R J M is offline   Reply With Quote
Old 12-15-2003, 06:25 PM   #269
Racing4Evo's Avatar
JP used to make the modified SE Novarossi so if you can find one, that will be the best you can get. After the JP I would reccomend the RB(if that is still made). The only engine that I know is still being made that is nova based is the Novarossi engine for Adam Drake. The CV-R is a great engine though that you can get for cheap.
Old 12-16-2003, 02:33 PM   #270
thanks for the input guys.
i need something that's good value and yet still relatively competitive (doesnt everyone?? hehe) as i do plan on moving into the open .12 class later and then, i'll buy myself a really great engine. but at the moment, the entry class needs side exhaust and pull start with nothing more than 4 ports and no forced induction
it's easy to find info about high end gear like Navarossi/JP etc. but it's the lower end stuff that i'm finding it hard to distinguish. i dont want to buy a pull start engine only for it to be on par with engines that comes as original equipment.
i'm sure you all are past the entry class in racing and are running with really good engines maybe i should ask the people in the FW-05S thread hahaha
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
