Old 08-22-2004, 03:54 PM   #2671
Sow&Steady's Avatar
Originally posted by NiMo
........and all I have is Charisma Carpenter telling me 'you got mail'
Muahaha! Never mind, at least you beat me today.
That 21 lap qualifier was very good ...
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-23-2004, 01:54 PM   #2672
V1R racer's Avatar
I run a NovaRossi 5.2mm pipe, it's a left side pipe fitted upside down on the right side.
It can be positioned with the stinger pointing slightly down which then allows the pressure nipple to be protected by the chassis, and the fuel pressure pipe cannot touch the flywheel.
Also this pipe is stronger than any made for the 05 and it has yet to be dented (I have tried).
I'm running 22/50 and 26/45 with 45T kawahara diffs, but I had another kawahara drive cup shatter today, and the replacements they sent me do not fit, so it looks like I'm going the 37T route possibly with the Kfactory 14T input gear when it becomes available.
I had a good meeting today, managed to up my time to a 21 lapper, came 2nd in the final, a few places ahead of Slow&Steady.
Hi nimo ill buy your kawahara centre conversion off you if your going with the 37T
V1R racer is offline   Reply With Quote
Old 08-23-2004, 02:06 PM   #2673
V1R racer's Avatar
My set up from the ic national at ashby
Front
Front Diff oil - one way
front shock oil - 35 wt
front caster - 2 clips at rear of arm
front camber - neg 2.0 deg
front toe out - 0 deg
droop screws- about 2m of droop
black kit springs
shock mount position
- top : lowest hole
- bottom : top hole
front anti-roll bar - Flat
Ride height - 6.0mm
wheel base - 198mm
front foams - 40 shore
Rear
Rear diff - 10,000
rear shocks - 35 wt
rear camber - neg 3.0 deg.
rear toe in - 3 deg
rear springs - gold kit springs
rear droop screws, rear arms to their full droop then screws just touching chassis
rear shock mount position
- top :highest hole
- bottom : bottom hole
Rear sway bar - no roll bar
Ride height - 7.0mm
wheel base - 198mm
rear foams - 40 shore
And centre conversion
GQ tyres
Car felt good all day plenty of speed, my gearing was 21/46-26/51:
Old 08-23-2004, 02:32 PM   #2674
Hi V1R,
Check you PM. I have a set of new center conversion.
Thanks.
cvccsi is offline   Reply With Quote
Old 08-23-2004, 02:37 PM   #2675
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Front
Front Diff: one way
Shock oil: 500wt
Caster: 10 degrees
Camber: -1.0 deg
Toe: 0 deg
Droop: +2
Spring: Gold short
Shock position: outer
Front anti-roll bar: 45 deg.
Ride height: 4.5
Track width: 198mm
Tire: Mono Tuning 40 deg
Ackerman: C (optional steering plate)
Rear
Rear diff: 10,000
Shock oil: 500wt
Camber: -3.5 deg.
Toe: -2
Spring: Black long
Droop: +3
Sus Arm Holder: Low
Roll center: Inner(low) Outer(high)
Shock position: Inner(top) upper arm position
Sway Bar: Black 3mm showing
Ride height : 5mm
Track width: 198mm
Gearing
1st gear: 21/51
2nd gear: 27/45
Ring gear: 37T
Engine and Body
Engine: Rex ReR 12
Plug: Rex 6C
Head Clearance: stock
Pipe: Kyosho 2 piece 5.2mm
Temp: 70 deg?
Humidity: High
Fuel: Mugen 30%
Clutch shoe: stock
Clutch gap: .6mm
Clutch adj nut: 2.1mm
Clutch spring: stock
Clutch Housing: Kyosho lightweight
Body: Losi Alpha Romeo
Racing4Evo is offline   Reply With Quote
Old 08-23-2004, 02:40 PM   #2676
Racing4Evo's Avatar
I set TQ and the track record with this setup. You have to use a 2mm tire split in the main or else the car starts to understeer.
Old 08-23-2004, 07:03 PM   #2677
Great job!!! Peter
Go Mono!!
MonoTuning
monotuning is offline   Reply With Quote
Old 08-23-2004, 07:11 PM   #2678
Racing4Evo's Avatar
Thanks Arron. Are the tires different now? They seem to be a lot softer? At any rate, they worked damn good.
Old 08-23-2004, 07:35 PM   #2679
jeffreylin's Avatar
R/C Tech Charter Subscriber
Peter you were flying yesterday. Too bad the plug died--sure would've be nice to see you win.
jeffreylin is offline   Reply With Quote
Old 08-23-2004, 07:44 PM   #2680
Racing4Evo's Avatar
Yeah it was too bad. Thanks for lending me your Tire Truer.
Old 08-23-2004, 07:45 PM   #2681
Racing4Evo's Avatar
This car is much better than the OFNA CD-3.
Old 08-24-2004, 12:35 AM   #2682
kidDynomite's Avatar
Default Chassis ?
Do you know which Kyosho chassis has 4mm holes for the engine mount screws? Or does one not exist?
Is anyone running the Shimo?
http://www2.towerhobbies.com/cgi-bin...?&I=LXGDE3&P=7
kidDynomite is offline   Reply With Quote
Old 08-24-2004, 12:48 AM   #2683
jeffreylin's Avatar
Default Re: Chassis ?
The 31582 kit comes with a Shimo chassis. It is very very strong and I haven't experienced any tweak running 2 cars for 9 months.
Old 08-24-2004, 12:50 AM   #2684
jbrosche's Avatar
Default FW-05R
Just read a review of this car. My HPI is old and needs to be replaced. I was wondering and this is an obvious new-guy question, so be gentle:
What is the difference between the FW-05R
and the VONE-RR?
I would like to purchase the best car, and while this might spur a great debate, which is the best car?
When were they released. Kyosho site is poor in the updates of their cars. Just a little info if you guys would.
Thanks!
jbrosche is offline   Reply With Quote
Old 08-24-2004, 01:33 AM   #2685
jeffreylin's Avatar
Default Re: FW-05R
and the VONE-RR?
Thanks!
I noted in your signature that you have both the TRF415 and the TB Evo4. So which one is the best between those 2?
There is no such thing as best car objectively. What matters is what you like and the support you will get.
FW series are shaft driven car and the V-One series are belt driven.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
