Old 08-09-2004, 05:11 PM   #2536
Default Re: up grades
Originally posted by mikecatts
hi all.
ive used and own both the kawaharra and the stock kyosho...
i feel all you need is the alumin front bulkhead..(the plastic has too much flex,,and dont over tighten the grub screws) and some 39 gears.....
the rest does it all by its self....
mike
so, the option parts from 3racing will do? the alum. center bulkhead...tnx...
cabworks is offline   Reply With Quote
Old 08-09-2004, 05:57 PM   #2537
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default parts
i use the 3 Racing front shock tower bulk head and the rear v-0ne-rr alumin camber brace.( gotta take a couple of mm off to have o nice fit)..never used anything else. i use the kyosho t-7 chassis....i made 4mm carbon fibre front shock tower. and a 3mm "red" carbon fibre radio tray (more rigid).........my standard fw-o5r with the mentioned parts is great... i bettered my lats years lap times by a sec and kept the con sistancey to .99secs per lap.
the fw is a far better car to drive smoothley and consistantly at the top level of pro notro toureser... its a far better ca in high traction than the RR...ive got the RRR now and im going to test back to back and pick my car for the auatralian national titles...
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 08-09-2004, 08:16 PM   #2538
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default great deal!
I just picked this up on e/bay for $51.00 is that a deal or what?!?!
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-09-2004, 08:51 PM   #2539
Default Back up Car!!!
Yup....got it, my back up car!!!
adlawoo is offline   Reply With Quote
Old 08-09-2004, 08:57 PM   #2540
Default YEA MAN!
Thats what I like to see, GQ. Tires on a car!
Old 08-09-2004, 09:00 PM   #2541
Originally posted by vadn1
Are universals need for this car, or standard bones are holding in just fine.
I found a kit R for $320 from tower. I figure it is not the hopped up car. It has the same model number of the ruber tire model. Are the thicker chassis, carbon upper plate and hop ups from the hopped up car helpful in durability or performance?
That car for 319.00 does not come with a 1/way or universals, try www.dinball.com I think they have the hoped up car for $380.00
Old 08-09-2004, 09:12 PM   #2542
Default Oooop`s (_*_)
This is the link for the car. $375.00 http://www.rcsquare.com/catalog/prod...oducts_id=1009
Old 08-09-2004, 10:31 PM   #2543
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Even if you never crash you still need some things to improve durabililty.
Aluminum brake holder
A stronger brake disk
Steel ring gears(especially if you decide to run 40t)
That's about it. You can decide what to else to get when you brake it.
Racing4Evo is offline   Reply With Quote
Old 08-10-2004, 03:35 AM   #2544
BrainTeased's Avatar
Default Re: Re: meshing
Originally posted by NiMo
Install the FW05 front diff but only use 1 bank of inner gears (2 gears on 1 shaft), you will need to use a thicker oil with 2 gears than you would use with 4 gears.
50K with 2 gears is similar to 30K with 4 gears.
If 30k with 4 gears is the same/simular with 2 gears and 50k... people could use 4 gears and 30k to get the simular effect? if so than the 2 gears and 50k really isnt benificial as alot of people run 30k fronts and 10k rears with 4 gears at each end. not indending to have a go at you just trying to understand the situation if there is any upsides of this facinating setup.
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 08-10-2004, 04:06 AM   #2545
FREAKAH's Avatar
Lower rotating mass.
Two metal gears and a steel shaft is plenty when it comes to rotating mass.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 08-10-2004, 04:14 AM   #2546
oh!!!!!!! so less rotating mass=faster rotation which then = quicker turn ins... i dont have a clue too technical for me but ill definetaly give it a try!
Old 08-10-2004, 05:22 AM   #2547
mikecatts's Avatar
Default fw hop ups
hers somepics of the pre-worlds winning fw..notice all he has got is the alu front bulkhead and carbon towers....everything else is how you get it out of the box..except. the gears...
mike
Old 08-10-2004, 05:30 AM   #2548
NiMo's Avatar
Also there is less rotating force that needs to change direction, so the car turns easier but does not kick out the rear.
The difference in the diff oil is to prevent the diffing out effect under power, the thicker oil is needed as there is less parts to have a friction effect on, so:
50K 2-gear diff will have a similar friction factor as a 30K 4-gear diff.
You understand now?
(I'm not sure which words you use to describe this in the American language, as English and American is not always the same language)
NiMo is offline   Reply With Quote
Old 08-10-2004, 05:33 AM   #2549
mikecatts's Avatar
Default pre-worlds car
this is how it finnished the race..
notice the front camber...you do need to use a bit ..it helps heaps to stick and drive 'in the corner'...
mike.
take note of the hop ups...not many...
Old 08-10-2004, 05:40 AM   #2550
ziggy12345's Avatar
Default Re: pre-worlds car
mike.
...Apart from the MTX-3 Rear hubs and the V-1-RR rear camber links.....
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
