Old 08-09-2004, 08:16 AM   #2506
kidDynomite's Avatar
Originally posted by NiMo
Just got back from track 20 minutes ago.
Tried overdrive with the rubbers, but you cannot come off power when cornering without the front one-way.
Tried foams with front overdrive and no one-way, 3mm difference between front and rear, comfotable push on all corners but no power on push, also braking was good as it put the brake bias to the front wheels.
Tyres were 45 front and 42 rear and the diffs are 10k 4-gear rear, 50k 2-gear front.
I found running this set up the car could not be shaken off line, I'm going to leave this set up on for the next planned meeting on the 22nd.
Slow&Steady eat my dust
Nimo, that's a really intereseting set up. I'm going to try it out in my 05R. Have you tried running only 2-gears in the back diff?
kidDynomite is offline   Reply With Quote
Old 08-09-2004, 08:18 AM   #2507
NiMo's Avatar
You should use all 4 in the back as this is the end that take most of the load and may strip when using only 2.
(FW05S only has 2 in front and rear)
NiMo is offline   Reply With Quote
Old 08-09-2004, 08:22 AM   #2508
NiMo's Avatar
Default Re: meshing
Originally posted by noobatron
thanx nimo!!
btw, i wanna try the 2 spider gear diff thingy u have going... currently using one way on a tight and technical track which is not a good idea
what do i do?
Install the FW05 front diff but only use 1 bank of inner gears (2 gears on 1 shaft), you will need to use a thicker oil with 2 gears than you would use with 4 gears.
50K with 2 gears is similar to 30K with 4 gears.
Old 08-09-2004, 09:12 AM   #2509
Sow&Steady's Avatar
... Slow&Steady eat my dust
NiMo, that's not fair. Am away and can't practise. In any case, I'll let you smoke me for a round or two just to encourage you to stay in foams and THEN you can eat my dust.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-09-2004, 09:14 AM   #2510
Sow&Steady's Avatar
Originally posted by ziggy12345
Next shell will be cool! I am fed up with throwing money at the car so have gathered up all the old bank notes I have and will stick them on the inside of the shell!
Old Nigerian, Italian, Libyan, Tunisian.....etc Notes.
I'll call it "The Money Pit!"
Cheers
Want more coins? I have some far eastern ones to weigh you down with.
Old 08-09-2004, 09:21 AM   #2511
NiMo's Avatar
Is that when I'm lapping you
Old 08-09-2004, 09:25 AM   #2512
Sow&Steady's Avatar
Yeap, the 22nd will be your only chance to lap me. After that you will be memorising what the rear end of the 710 looks like.
Old 08-09-2004, 09:29 AM   #2513
markp27's Avatar
Send a message via ICQ to markp27
And when I get there in Oct and forget about the running clockwise, he can have a quick look at a 710 front end
markp27 is offline   Reply With Quote
Old 08-09-2004, 09:30 AM   #2514
Sow&Steady's Avatar
Mark, sounds like a good plan. Me in front of NiMo and you behind him. By the end of the weekend, he'll start thinking of buying a 710 as well!
Hey wait ... I thought you're practising clockwise at your track now?!
Old 08-09-2004, 09:48 AM   #2515
markp27's Avatar
Take a look at the picture attached, the cars on the pic are running anti-clockwise. Now the problematic in running clockwise, is those nice concerete 8cm high curbstones at the outside of the last part of the left-right flick. I've drawn on the approx racing line and you can see in comming out of the right-hand section, the car goes right up against the big curbstones I brushed them a couple of times before I decided to slow my laps down a bit
Old 08-09-2004, 09:48 AM   #2516
markp27's Avatar
Oops no pic Here it is
Old 08-09-2004, 09:53 AM   #2517
Sow&Steady's Avatar
Ooops! I see what you mean! You'll need to set up for a lot of side bite to allow you a half decent chance to carry speed through to the other side without sliding into those walls!
Old 08-09-2004, 09:54 AM   #2518
Sow&Steady's Avatar
Oh and btw, good line!
Old 08-09-2004, 09:56 AM   #2519
markp27's Avatar
I tell you though, it is pretty wild drifting it through those corners - cheeks together and hold breath and when you pull it off, it's a nice feeling
Old 08-09-2004, 09:57 AM   #2520
markp27's Avatar
I have to ask myself - are those Winternats barriers really going to be worse than my tracks concerete curbs?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
