Old 08-08-2004, 04:53 PM   #2491
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default 1st run
I made my first run today with the FW05R, great corner speed, great excelleration too! The rear shock came off in the main but the car was still driveable I ran a one way 40 wt. shock oil rear pistons where opened up a bit larger than the front. O toe in front 2 deg. rear toe 2deg. front camber 3 deg. rear camber link in the highest pos. and the shortest on the 3 racing shock tower. I could put the power on very early in the turns, and the sweeper at the top of the straight was full throttle for me.I ran 10,000 rear diff lube and a P[rotoform Alfa with 35 shore tires all around.
I worked on making the car lighter, and got it down to just 2.7 oz. over weight.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-08-2004, 09:06 PM   #2492
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally posted by ziggy12345
New shell. The best cartoon there is!!
Lol...
very cool paint job bro... that makes your paint job one of the unique ones....
doki_doki is offline   Reply With Quote
Old 08-08-2004, 10:38 PM   #2493
Default Wooooh!
Needless to say I was quite disopointed with the quality of the stock gears!
Old 08-09-2004, 01:29 AM   #2494
ziggy12345's Avatar
Next shell will be cool! I am fed up with throwing money at the car so have gathered up all the old bank notes I have and will stick them on the inside of the shell!
Old Nigerian, Italian, Libyan, Tunisian.....etc Notes.
I'll call it "The Money Pit!"
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-09-2004, 04:58 AM   #2495
BrainTeased's Avatar
Originally posted by NiMo
Just got back from track 20 minutes ago.
Tried overdrive with the rubbers, but you cannot come off power when cornering without the front one-way.
Tried foams with front overdrive and no one-way, 3mm difference between front and rear, comfotable push on all corners but no power on push, also braking was good as it put the brake bias to the front wheels.
Tyres were 45 front and 42 rear and the diffs are 10k 4-gear rear, 50k 2-gear front.
I found running this set up the car could not be shaken off line, I'm going to leave this set up on for the next planned meeting on the 22nd.
Slow&Steady eat my dust
why are you running only 2 diff spider gears in the front diff?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 08-09-2004, 05:05 AM   #2496
Default Re: Wooooh!
I ran the stock gears for a long time and they are still like new.. I can't say the same for pinion gears though...
GUNPOWDER is offline   Reply With Quote
Old 08-09-2004, 06:45 AM   #2497
Send a message via ICQ to noobatron
Exclamation shimming backlash
Hey guys,
just a question, it's probably back in the thread somehwere but it's soo long i can't find it
I've purchased 39T diff gears and am about to put them in. Does anyone have any special method or way to gauge the shims needed for perfect meshing? I brougth the car 2nd hand and it runs really well, i love it!
any help appreciated
cheers
noobatron is offline   Reply With Quote
Old 08-09-2004, 06:59 AM   #2498
NiMo's Avatar
It was from an earlier test session, and it made turn in better so I just left it.
I done the same to the V-one R I used to drive, and to the Kyosho Cup V-one S, and it had the same effect there too.
And it just happens to save a little weight, both overal and rotating.
NiMo is offline   Reply With Quote
Old 08-09-2004, 07:02 AM   #2499
NiMo's Avatar
Default Re: shimming backlash
Originally posted by noobatron
Hey guys,
cheers
Get the meshing as tight as possible but with a little drag as possible.
If you got the Machined Steel diff rings then they can be run a little looser than the kit supplied cast steel diff rings.
Old 08-09-2004, 07:07 AM   #2500
AHHH!!! cool! just learnt something thanks
but do you still hold a good radius turn? and do you spin out easily with the better/aggressive turn in?
Old 08-09-2004, 07:14 AM   #2501
2 spider gears?
erhh... how does that work and wot's the effect?
Old 08-09-2004, 07:25 AM   #2502
I have been looking into the FW-05R. Any places on where to find this car at good price? Also, what hop ups are needed, I was told that internal diff gears and ring gear? What parts are needed to install a front diff and is it possible? Does this car have an option for a solid spool?
vadn1 is offline   Reply With Quote
Old 08-09-2004, 07:40 AM   #2503
NiMo's Avatar
Better radius turn, better direction change, better power on steering, zero spin out, same for both rubber and foam tyres.
Old 08-09-2004, 07:44 AM   #2504
NiMo's Avatar
You need to look in to it a bit further.
There are 3 specs of FW05R, and 2 specs of FW05S.
And if you want a solid spool then I suggest you look elsewhere as this car doesn't need it.
Old 08-09-2004, 08:04 AM   #2505
Default meshing
thanx nimo!!
btw, i wanna try the 2 spider gear diff thingy u have going... currently using one way on a tight and technical track which is not a good idea
what do i do?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
