Old 08-07-2004, 03:08 PM   #2476
rjl
rjl's Avatar
Thanks buddy.
rjl is offline   Reply With Quote
Old 08-07-2004, 03:38 PM   #2477
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default rob
hi there you bloody rabbit...cant sleep......dreaming im going to beat you aye?
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 08-08-2004, 03:06 AM   #2478
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I just ordered the 37t ring gears from RC Union. It was either that or the Kawahara so I got the cheaper alternative. I would've liked to have some overdrive though. I still can't find 23/28 pinions though. Anyone?
Racing4Evo is offline   Reply With Quote
Old 08-08-2004, 03:09 AM   #2479
Racing4Evo's Avatar
Is anyone interested in a 710 very good condition? I have too many cars and I need to make some "financial room" so I can keep up with my Delta XP-4.
Old 08-08-2004, 03:27 AM   #2480
rjl
rjl's Avatar
Default Re: rob
Tell 'im he's dreamin'. Bring it on sunshine.
Maaate.
Old 08-08-2004, 03:33 AM   #2481
rjl
rjl's Avatar
Hey Nige, did you try the Kawahara overdrive with rubber?
Old 08-08-2004, 05:36 AM   #2482
NiMo's Avatar
I was thinking of trying it this afternoon as I'm not racing today.
I going to change both diffs to 45T before my next race in two weeks.
I'm still waiting for someone to do that central one-way (like on the FW04) but it appears no one is interested, I tried to fit the FW04 one but the dimensions are all wrong by a long way.
NiMo is offline   Reply With Quote
Old 08-08-2004, 06:11 AM   #2483
ziggy12345's Avatar
Had a club meeting on Saturday and got roasted by my team mate who was running a front diff and so was outbraking me in the turns.
I have fitted the front diff and will try it next week. What diff oil are people running in the front? I am on foams
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-08-2004, 07:03 AM   #2484
BrainTeased's Avatar
Hi guys may i ask how many droop screws there are on the car? i can only find 2 on the rears (one on each side)
and i think 2 on the fronts hidden inside the bumper assembly *shrugs* tried to look at the manual but only shows them for the rears. also for the rear i unscrewed the droop screw out so that the arm is flush witth the grub screw but still my car doesnt seem to have any effect in the rear.
also has anyone tried the kyosho red springs on these cars? what springs are you guys running?
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 08-08-2004, 09:11 AM   #2485
Ares17's Avatar
Default Loose rear
Guys, need some help here. My car is set up as per the manual. Rear using 5-Stars Yellow spring. Running on foam. Keep losing traction on the rear. It looks like its not holding tight enough even for a low speed turn. Any remedy? Thank you.
Ares17 is offline   Reply With Quote
Old 08-08-2004, 09:25 AM   #2486
SupermaxxRich's Avatar
Droop screws in front are on top in the very front. The screws push down on the sway bar holder.
SupermaxxRich is offline   Reply With Quote
Old 08-08-2004, 10:05 AM   #2487
ziggy12345's Avatar
Default Re: Loose rear
Make sure you have the rear camber links at the highest angle possible. Also set the camber angle to 4 or even 5 degrees. Toe in is around 2-3 deg
For max stability change the rear hub carriers to MTX-3 and the camber links to V-1-RR
Cheers
Sponsored by:
Norfolk and Chance
Old 08-08-2004, 10:10 AM   #2488
Ares17's Avatar
thanx ziggy, will try it out the next time i'm out with the fw05r...
Old 08-08-2004, 02:04 PM   #2489
Racing4Evo's Avatar
Cheers
I run diff lock when I am running the differential. It does understeer a little bit but the advantage you get from 4 wheel braking all but negates the understeer. If you run on a moderately technical track the solid diff is much better than a one-way
Old 08-08-2004, 02:20 PM   #2490
NiMo's Avatar
Cheers
Just got back from track 20 minutes ago.
Tried overdrive with the rubbers, but you cannot come off power when cornering without the front one-way.
Tried foams with front overdrive and no one-way, 3mm difference between front and rear, comfotable push on all corners but no power on push, also braking was good as it put the brake bias to the front wheels.
Tyres were 45 front and 42 rear and the diffs are 10k 4-gear rear, 50k 2-gear front.
I found running this set up the car could not be shaken off line, I'm going to leave this set up on for the next planned meeting on the 22nd.
Slow&Steady eat my dust
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
