Old 08-04-2004, 03:46 AM   #2416
Sow&Steady's Avatar
Originally posted by NiMo
BRCA IC Scale Rubber Series
Aldershot - Short circuit track.
BRCA minimum weight 1750 Grams.
My FW05R weighed in at 1858 Grams.
I qualified 4th mainly because I could ride the kerbs the others could not.
NiMo, are you sure the limit for 200mm is 1750? I'm sure I saw somewhere that it says 1700gms. EFRA is 1750 gms.
You did VERY well at the AMCC Nationals, especially if you were 158 gms heavier than the champ.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 08-04-2004, 03:58 AM   #2417
NiMo's Avatar
Foam series 1700
Rubber Series 1750
NiMo is offline   Reply With Quote
Old 08-04-2004, 04:23 AM   #2418
Sow&Steady's Avatar
Foam series 1700
Rubber Series 1750
Ah OK, I never look at the rubber rules ...
Now that you've licked rubber, we're glad you're joining where the real boys are ... in the foams!
Old 08-04-2004, 04:18 PM   #2419
ziggy12345's Avatar
You going to the ashby foam in a couple of weeks Sow&steady?
I'm assuming your slow&steady from aldershot! LOL
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 08-04-2004, 04:31 PM   #2420
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default weight
the efra weight is 1715 with transponder...
my fw comes in at 1835gm's...heavy kyosho....i found the titanium pivot balls bend too easily.....u have to use the alumin front shocker mount as the stock plastic moves...
making a 4mm carbon radio tray to stop chassis flex...the front blue drive shaft bends...
i use a jp..it flies....
23, 28....45 50...39 teeth gears..
waiting for the 37 ring gears..this will hoot.
mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 08-04-2004, 04:37 PM   #2421
Sow&Steady's Avatar
Yup, I'm the "slow&steady" one at AMCC
No, I don't plan to do the nats this year because I missed the first 3 rounds before they even started!
Hopefully next year ... depends on work schedule.
Old 08-04-2004, 04:38 PM   #2422
ziggy12345's Avatar
Default Re: weight
mike
The 37t bevel gears are still lower geared than the centre conversion.
Sponsored by:
Norfolk and Chance
Old 08-04-2004, 06:22 PM   #2423
mikecatts's Avatar
Default centre conversion
tried both and i reckon with the 37 nt ring gears..
the car will be fast..im using the kyo instead of the kawahharra..ive both.
the kawaharra is very weak in the front end.. one touch and all over,,
ive made some imm and 2mm carbon fibre spaces to stop the flex..it works but i still think the kyo is better than the kawa car..
my personal opinion
mike
Old 08-04-2004, 09:41 PM   #2424
rjl
rjl's Avatar
Default Re: Re: weight
13-37 is 2.85:1, 17- 45 is about 2.65:1. The only problem I've encountered with the Kawahara centre conversion is that I'm overgeared on all but the larger tracks.
rjl is offline   Reply With Quote
Old 08-04-2004, 10:38 PM   #2425
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I'm currently rebuilding my car and I doubled up the front shock towers. I'm using the stock plastic bulkhead brace since I bent the 3Racing one. Hopefully the 4mm shock tower will make it stiff enough.
I think another steering post screwed behind the engine and an upper deck that wraps around the engine much like the way the front of the upper deck wraps around the the fuel tank would help.
Racing4Evo is offline   Reply With Quote
Old 08-05-2004, 04:05 AM   #2426
ziggy12345's Avatar
Default Re: centre conversion
my personal opinion
mike
Are you talking about the Kawahara front conversion? I tried it but broke it twice!
If you make a small bar that fits across the back of the original pivot pins like the kawahara and than extend the pivot pins to locate in the bar it will be more rigid. I'll try and put something together
Cheers
Sponsored by:
Norfolk and Chance
Old 08-05-2004, 04:09 AM   #2427
ziggy12345's Avatar
Default Re: Re: Re: weight
I dont seem to have this problem. In fact I am still using the 21/26 pinions and sometimes the 22/27. I have the JP FX and so have plenty of low power. I havent been at a race meeting with other FW's so cant compare the speed or accel but know i can outdrag all the 710's so cant be doing much wrong
Sponsored by:
Norfolk and Chance
Old 08-05-2004, 04:13 AM   #2428
ziggy12345's Avatar
I have only done one! I have entered Ahby and Tibshelf though. I have concentrated on the Ashby Summer Series and currently lead the Open class. No big deal as here are only 6 in it!! LOL...
Sponsored by:
Norfolk and Chance
Old 08-05-2004, 04:44 AM   #2429
rjl
rjl's Avatar
my personal opinion
mike
Hey Mike weren't you selling one of your one touch cars recently.
Old 08-05-2004, 05:05 AM   #2430
Sow&Steady's Avatar
Ziggy ... maybe that's what I'll do too next year. I mean, just join each of the national races as they come rather than trying to catch each and every one. I'll never make it all anyways.
Well done, you must be a fast driver then, or at least faster than me! Here at AMCC there seems to be only 4 open drivers in the summer and I'm last.
In an effort to increase interest in the foam class, AMCC has added a foam touring class. We've only done one race with this so time will tell if this works. Do you come down to AMCC once in a while?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
